Il y a 66 utilisateurs connus et inconnus. Pour voir la liste des connectés connus, cliquez ici
Mise à jour du RT3
n°21593
lolo14
Posté le 22-09-2006 à 00:33:15  answer
J'ai réussi sans pb la mise à jour de mon RT3. Voici toutes les infos que j'ai pu trouver sur ce site et sur eurovan.
Si ça peut aider ...
A+
Important
If you want to update your RT3 yourself, you should follow these simple rules:
1. Keep the engine running! A shutdown during update will damage you RT3
2. Eject the SIM card as an incoming call can do the same!
Only update within your major version number (5.x/6.x).
Never try to update from 5.x to 6.x as you'll damage your RT3!
And don't forget that RT3 ejects the CD one time during update, and you may not take it !!!
It will be automaticaly re-inserted by the RT3, to complete update !
RT3 v5.5d b595 cdrom
Les véhicules disposant d'un système de multiplexage de type "VAN" ont des RT3 avec le logiciel 5.xx
Use this version only on VAN bus cars (807, C8, Phedra, Ulysse, C5 I, 307 I).
Check your current software version.
If you're running 5.X than use this cdrom to update.
Steps to install:
 * Unzip the downloaded file. You'll get four files ( rt3595.sub, rt3595.ccd, rt3595.img, rt3595.cue)
 * As this is a CD image you need to burn the rt3595.img file as an CD image using e.g. Nero.
 1.Activate NERO
 2.In application haul "Nero Burning ROM"
 3.Close "New compilation"
 4.Click "Recorder"
 5.Click "Burn image..."
 6.Mark file "cue"
 7.Click "Burn"
 * Your final CD should conatin 85 files.
RT3 v6.62 b880 cdrom
Les véhicules disposant d'un système de multiplexage de type "CAN" ont des RT3 avec le logiciel 6.xx
Use this version only on CAN bus cars (407, 607 II, 307 II, C4, C5 II).
If you're running 6.X than use this cdrom to update.
Never ever try to install this version on RT3s running 5.X!!!
Steps to install:
 * Unzip the downloaded file. You'll get four files.
 * As this is a CD image you need to burn the .img file as an CD image using e.g. Nero.
 1.Activate NERO
 4.Click "Recorder"
 6.Mark file "cue"
 7.Click "Burn"
   Burn this cdrom (nero image) with slow speed ( max 8x )
