Il y a 92 utilisateurs connus et inconnus. Pour voir la liste des connectés connus, cliquez ici
navigation monochrome 206 406
n°29407
axl
Posté le 08-02-2008 à 22:33:00  answer
hi all :)
i got a question about the siemens vdo monochrome nav system as provided in the 206 406 and 607
does the map cd contain firmware files?
because by saying goes when you use a new map cd the system could be updated and older map cd's with perhaps different map format won't work no more.
second i updated a system a while ago witch didnt had dutch language on it and now with  the last 06/07 map cd it has dutch menu's and spoken directions. so i think it does has firmware files on the mapcd
perhaps E111111 could give me a final answer?
(i got a yes/no discussion on a other forum)
thanks for your reply
axl
n°29415
gg_le_tec
Posté le 08-02-2008 à 23:25:14  answer
hi yourself :p
when u introduce the maps cd, the reader dont take it? For the firmware : if ur navteq system is a 5.X version, not possible to upgrade to 6.X version. But the last maps cd must be read.
n°29419
axl
Posté le 09-02-2008 à 00:02:21  answer
thanks for your reply :)
the OS as you mentioned is for the RT3 systems
afaik theirs no separated OS cd's for the siemens VDO systems.
axl
n°29440
gg_le_tec
Posté le 10-02-2008 à 20:13:49  answer
i cant help you sorry.
n°29469
gps 406 fr
Posté le 12-02-2008 à 07:40:53  answer
for the VDO systems, you have all language on the map CD. You make a choise about language with the car system and you can used a new map 06/07 ans take an old one after without problems. I've gote map of France 06/07 ans GB 03 and I can used each of them when I want.
