2ème partie : car sur ce nouveau forum on est limité par les caractères
Equipement intérieur
TYPE D’HABILLAGE INTÉRIEUR C&T TEXTILE OXF +TEP PU "0N"
ALLUME-CIGARE SANS ALLUME CIGARE
DETECTION ANGLEMORT AVEC SURVEILLANCE ANGLE MORT
ACCOUDOIR ASSISE ARRIÈRE AVEC ACCOUDOIR AR
ARRIMAGE INTÉRIEUR AVEC ARRIMAGE INTERIEUR
CACHE-BAGAGES TABLETTE
CEINTURE DE SÉCURITÉ ARRIÈRE CEINT SECU AR 3 ENROULEURS 3 PTS + TEMOIN BOUCLAGE
CEINTURE DE SÉCURITÉ AVANT ENROULEUR ALARME BOUCLAGE CONDUCTEUR + PASSAGER
CENDRIER SANS CENDRIER
CLIMAT (TEMPERATURE AMBIANTE) PAYS FROIDS
COMMANDE DE VITESSES COMMANDE VITESSE AU PLANCHER ET AU VOLANT
CHAUFFAGE ADDITIONNEL SANS CHAUFFAGE ADDITIONNEL
MIRROR LINK AVEC MIRROR LINK
VARIATION D’HABILLAGE D’ÉQUIPEMENT INTÉRIEUR SANS PRISE ACCESSOIRES
FEUX INT. DIVERS LC AV/AR A LEDS SANS LED AMB AVEC ECL AMB
GARNISSAGE VOLUME CHARGEMENT TAPIS + FOND + COTES MOQUETTE
COMBINÉ (CARACTÉRISTIQUES) COMBINE AVEC MATRICE
GARNISSAGE DE PORTE GARNISSAGE PORTE DECOR CHROME SATIN
ANCRAGE SIÈGE ENFANT SANS ANCRAGE SIEGES ENFANTS AVEC ISO AR
HAUT-PARLEUR 4 HAUT PARLEUR AV (2 TW + 2 AV)+2 HAUT PARLEUR AR
COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE
INSONORISATION HABITACLE INSONORISATION (HABITACLE)TABLIER 2,8 KG
REHAUSSE ASSISE AVANT PASSAGER REHAUSSE PASSAGER REGLAGE PARALLELE+AV
RÉGLAGE ASSISE AVANT CONDUCTEUR REGLAGE LOMBAIRE CONDUCTEUR MANUEL
RÉGLAGE ASSISE AVANT PASSAGER MAINTIEN LOMBAIRE PASSAGER
ACCOUDOIR ASSISE AVANT ACCOUDOIR CENTRAL
SYSTÈME DE NAVIGATION NAVIGATION 2 ECRANS COULEUR
LAMPES DE PROJECTEURS LAMPE A LED
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR ELECTRIQUE CDE SEQUENTIELLE
LECTEUR D’INFORMATIONS ROUTIÈRES PREVENTION+CORRECTION TRAJECTOIRE LATERALE
AFFICHEUR AFFICHEUR AV ECRAN DGT7C
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
INDICATEUR D’HUILE INDICATEUR NIVEAU HUILE
MONTAGE APPUI-TÊTE ARRIÈRE MONTAGE 3 APPUI-TETE AR
ECLAIRAGE BAS HABITACLE ECLAIRAGE CAVE A PIEDS COND + PASS AV
PROTECTION PASSAGER ARRIÈRE SANS PROTECTION PASSAGER AR
NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION AIRBAG MANUELLE
PLANCHER ARRIÈRE CHARGE SANS PLANCHER AR CHARGE
PROJECTEUR CORRECTEUR ASSIETTE REGLAGE AUTOMATIQUE PROJECTEURS
PARE-SOLEIL AVANT COTE CONDUCTEUR+PASSAGER AVEC PORTE CARTE+INSCRIP
WIFI AVEC WIFI
RÉCEPTEUR RADIO NAVIGATION CONNECTEE NUMERIQUE
RÉGULATEUR DE VITESSES REGULATEUR ET LIMITEUR VITESSE
RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR-NUIT ELECTROCHROME
SURTAPIS (ASPECT) SURTAPIS MOQUETTE LOGO GT
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) GLACE RETRO EXT BOMBE
RANGEMENT VOLUME CHARGEMENT SANGLE GARNITURE LATERALE COFFRE
TUNER-RADIO MONO TUNER RADIO
TÉMOIN DE NIVEAU DE LIQUIDE DE REFROIDISSEMENT TEMOIN NIVEAU LIQUIDE REFROIDISSEMENT
DÉTECTION D’OBSTACLE DETECTEUR OBSTACLE RADAR AV/AR + PARK AUTO
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE DETECTION SOUS GONFLAGE INDIRECT AVEC LOCALISATION
SURTAPIS SURTAPIS AVANT+ARRIERE
FRÉQUENCE RADIO FREQUENCE RADIO EUROPE OCCIDENTALE
COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION + AUTOMATIQUE
VITRE (TYPE) PARE-BRISE FEUILLETE ACCOUSTIQUE + VITRE AR TREMPE
VOLANT VOLANT SPORT CUIR
VENTILATEUR 1 VENTILATEUR 2 VITESSES 95W AERO VOLET DYNAMIQUE
VARIANTE ASSOCIÉE ASSISE BASSE
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) MAINTIEN LOMBAIRE MANUEL
PRISE AUXILIAIRE PACK AUDIO 1 PRISE USB
BOITIER TELEMATIQUE SANS BOITIER TELEMATIQUE
Electricité
ALTERNATEUR ALTERNATEUR CLASSE 12
BATTERIE BATTERIE L3 760 70AH EFR 760 EN EF
DÉMARREUR DEMARREUR STTD
ECLAIREMENT PARTICULIER FEUX DIURNE
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVISEUR EXTERIEUR RABATTABLE ELECTRIQUE+DIODE
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FREQUENCE TELECDE CONDA 433,92 MHZ HETERODYNE
MULTIPLEXAGE ARCHITECTURE ELECTRIQUE ECONOMIQUE EVOLUEE
PROJECTEUR ANTIBROUILLARD PROJECTEUR ANTI-BROUILLARD A LED
ALLUMAGE FEUX ALLUMAGE FEUX AUTOMATIQUE+COMMUTATION AUTOMATIQUE
Marques d'équipements
VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION VALEO
Divers
ATMOSPHÈRE ATMOSPHERE NORMALE
PLAQUE CONSTRUCTEUR PLAQUE CONSTRUCTION UNION EUROPEENNE + NRE
ETIQUETTE SANS ETIQUETTE
PRISE D’ÉCOUTE RADIO PRISE ACCESSOIRES AV + AR 12V
JEUX DE CLÉS JEU DE CLES BADGE + CLE SECOURS
JOINT ANTISALISSURE JOINT ANTI-SALISSURES AMELIORE + AV PORTE AV
LIQUIDE RÉFRIGÉRANT LIQUIDE REFRIGERANT 1234 YF
ROULAGE BONNE ROUTE
ACCESSOIRES EXTÉRIEURS POIGNEE EXTERIEUR COULEUR CAISSE
BOÎTIER SERVITUDE BSI + COM 2008 + SON POLY
date de fabrication le : 07/06/2018
