I have connected the adapter between BSI and NAC. The NAC operates and sends data to cirocco and the command from the Right Stalker end sends command to NAC and cirocco.
But the adapter does not work.
In the Arduino console, the commands appear, but do not change the cluster mode.
When pressing the Separate button connected to Arduino appears Mode Changé, and when the right stalker appears, Counter + = 1Chogement Consocounter + = 1mode Changéchangment Conso and Cirocco show the Trip changing, but do not change the cluster mode.
I have activated CAN debug on can0 after which on Can1 and a lot of ID frames appear.
I tested and commanding on Stalker left with the change from
@marcins and the same shows me in the console that I give the order but does not change the cluster mode.
I reversed pins 9 with 10 that lead to CAN cards and I noticed that I can now change the cluster mode from the separate button but the right stalker can not. The ARDUINO console only appears when pressing on the separate button when the right stalker no longer appears. This means that now the CAN card on Pin 10 sends me command to BSI instead of sending it to NAC.
