A priori ce n'est pas une pack sport, mais une sport
LIGNE DE PRODUIT 406 RESTYL
SILHOUETTE BERLINE 4PTES
FINITION BASSE HAUTE
MOTEUR INJECTION EW12J4
TRANSMISSION BVM5
COULEUR DE CAISSE PEINTURE GRIS ICELAND
TYPE D’HABILLAGE INTÉRIEUR TRESSE ANDORRE + CUIR L005 "MO"
COULEUR DE GARNISSAGE FX
BOITE DE VITESSES (CARACTÉRISTIQUES) BVM ML5C
MOTEUR (TYPE) MOTEUR TYPE EW/DW
MONOGRAMME COMPLÉMENTAIRE SANS MONOGRAMME COMPLEMENTAIRE
MONOGRAMME SANS MONOGRAMME
Caractéristiques véhicule
COUPLE TACHYMÈTRE CT 25 X 20
Alimentation moteur
CARBURANT ESSENCE SANS PLOMB
PRISE VITESSES (INFORMATIONS CAPTEUR) CAPTEUR EFFET HALL
CATALYSEUR CATALYSEUR 3 COMPOSES
REFROIDISSEMENT D’HUILE ECHANGEUR EAU/HUILE MOTEUR
RÉCHAUFFAGE CIRCUIT GAZ CARTER RECHAUFFAGE CIRCUIT GAZ CARTER
COUPURE ALIMENTATION CARBURANT SANS COUPURE ALIMENTATION CARBURANT
AUTODIAGNOSTIC EOBD AUTO-DIAGNOSTIC EOBD AVEC ACCELEROMETRE
DISPOSITIF (ANTIPOLLUTION) INJECTION AIR PULSAIR
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOL TECHNIQUE VEHICULE INCITATION FISCALE EURO 4
VENTILATEUR 1 VENTILATEUR 350W
RÉCUPÉRATION DES VAPEURS D’ESSENCE RECUP VAPEUR ESSENCE PILOTE
VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION MAGNETI MARELLI
TRANSMISSION BVM5
COUPLE RAPPORT CP 16 X 69
STYLE ROUE ROUE ALLIAGE OURAGAN
VERROUILLAGE SÉCURITÉ BOITE DE VITESSES SANS VERROUILLAGE SECURITE BV
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 205X55X16 W
ROUES MONTÉES ROUE 6 POUCES 1/2
ROUE (TYPE) MONTAGE ROUE ALLIAGE
BOITE DE VITESSES TYPE BVM ML
Suspension Direction Freinage
ANTIBLOCAGE ANTI-BLOCAGE ROUE
BARRE ANTIDÉVERS ARRIÈRE BARRE ANTI DEVERS AR DIAM 22,5
ANTIVOL ANTIVOL STANDARD
ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAM 24
FREIN PRINCIPAL REPARTITION ELECTRONIQUE FREINAGE
FREIN TYPE DISQUES AV VENTILES/DISQUES AR
REFROIDISSEMENT D’HUILE POMPE DE DIRECTION AVEC REFROIDISSEMENT HUILE POMPE DIRECTION
SUSPENSION SUSPENSION NORMALE
SUSPENSION ACTIVE SANS SUSPENSION VARIABLE
CONTRÔLE DYNAMIQUE DE STABILITÉ AVEC SYSTEME ESP
AIDE AU FREINAGE D’URGENCE MONTAGE AMPLIFICATEUR TEVES
Carrosserie Equipements
ANTENNE ANTENNE PAVILLON AMPLIFIEE
BRAS RACLETTE BALAI AV AVEC DEFLECTEUR
ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEUR AVEC JONC CHROME
ENJOLIVEMENT LATÉRAL (DIMENSION) PROTECTEURS LATERAUX LARG50 +BAS DE MARCHE
ENJOLIVEUR ROUE (STYLE) STYLE FOUDRE
FEU D’ÉCLAIRAGE DE SEUIL FEU ECLAIRAGE DE SEUIL
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETRO EXT RABATTABLE ELECTRIQUE
ENJOLIVEUR DE SORTIE D’ÉCHAPPEMENT AVEC ENJOLIVEUR SORTIE ECHAPPEMENT
INSONORISATION COTÉ MOTEUR INSONORISATION CAPOT MOTEUR
ESSUIE-VITRE ARRIÈRE SANS ESSUIE-VITRE AR
PARE-CHOCS PARE-CHOCS AV/AR COULEUR CAISSE
PARE-BOUE (BAVETTE) SANS PARE BOUE
PORTE-BAGAGES MONTAGE SANS PORTE BAGAGES
RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETRO EXT CONDUCTEUR CHAUFFANT CDE ELECTRIQUE
RÉTROVISEUR EXTÉRIEUR (COTÉ PASSAGER) RETRO EXT PASSAGER CHAUFFANT CDE ELECTRIQUE
ACCESSOIRES EXTÉRIEURS RETRO EXT ET POIGNEES EXT COULEUR CAISSE
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) GLACE RETRO EXT CONDUCTEUR BOMBE
LAVE-VITRE ARRIÈRE SANS LAVE VITRE ARRIERE
TOIT OUVRANT TOIT FIXE
VITRE (ASPECT) TEINTEE
VITRE (TYPE) PARE-BRISE ATHERMIQUE
Equipement intérieur
ASSISE ARRIÈRE BANQUETTE AR COUSSIN MONOBLOC DOSSIERS SEPARES
ACCOUDOIR ASSISE ARRIÈRE AVEC ACCOUDOIR AR
BAGUETTE PLANCHER DE CHARGE SANS BAGUETTE PLANCHER CHARGE
RADIO-TÉLÉPHONE SANS PRE-EQUIPEMENT TELEPHONE
CACHE-BAGAGES SANS CACHE BAGAGES
CEINTURE DE SÉCURITÉ AVANT CEINTURE PYROTECHNIQUE SANS ALARME
CLIMATISEUR AVEC AEROTHERME CDES ASSISTEES
CONSOLE CONSOLE LONGUE GARNIE FACON EBENE
EQUIPEMENT PLANCHE DE BORD PL/BORD GRAND VOLET V/P ENJOLIVEUR FACON EBENE
ANTIPARASITAGE ANTIPARASITAGE
FEUX INT. DIVERS LECTEUR DE CARTE
GARNISSAGE VOLUME CHARGEMENT GARNISSAGE COFFRE + VOLET AR
COMBINÉ (CARACTÉRISTIQUES) GRADUATION 260 KM/H / 150 M/H FOND BLANC CL CHROM
GARNISSAGE DE PORTE DECOR FACON EBENE
ANCRAGE SIÈGE ENFANT SANS ANCRAGE SIEGES ENFANTS
HAUT-PARLEUR MONTAGE 4 HP + 2 TWEETERS
FILTRE À POLLEN AVEC FILTRE A POLLEN
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) SANS RIDEAU PARE-SOLEIL
REHAUSSE ASSISE AVANT PASSAGER SANS REHAUSSE COTE PASSAGER
COMMANDE ASSISE AVANT CONDUCTEUR CDE SIEGE AV ELECT CONDUCTEUR
COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV ELECT PASSAGER
RÉGLAGE ASSISE AVANT CONDUCTEUR DOSSIER CONDUCTEUR INCLINABLE
RÉGLAGE ASSISE AVANT PASSAGER DOSSIER PASSAGER INCLINABLE
ACCOUDOIR ASSISE AVANT MONTAGE AVEC ACCOUDOIR AVANT
TÉMOIN DE FREIN DE PARKING SANS TEMOIN FREIN PARKING
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR CDE ELECTRIQUE
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
INDICATEUR D’HUILE RECEPTEUR TEMPORISE NIV + TEMP
SAC GONFLABLE LATÉRAL AVANT SAC GONFLABLE LATERAL AV DOUBLE
LÈVE-VITRE ÉLECTRIQUE (FONCTIONNEMENT) ANTI PINCEMENT CONDUCTEUR
GRILLE HAUT-PARLEUR (COMPARTIMENT ARRIÈRE) AVEC GRILLE HP TABLETTE AR
PLAFONNIER CDE PTES AV+AR PLAFONNIER AV+AR
PARE-SOLEIL AVANT COTE CONDUCTEUR+PASSAGER SANS INSCRIPTION
RÉCEPTEUR RADIO SYSTEME AUDIO COMPACT DISC RDS RD3
RÉFRIGÉRATION REFRIGERATION
RÉGULATEUR DE VITESSES REGULATION VITESSE
REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE PARALLELE+AV
RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR-NUIT ELECTROCHROME
RÉGULATION CLIMATISATION / TEMPÉRATURE AVEC REGULATION CLIMAT /TEMP
RANGEMENT (AUTRES) UNE BOITE DE RANGEMENT DANS COFFRE
SURTAPIS (ASPECT) SURTAPIS TUFTE RASE F470
PROTECTION INTÉRIEURE SANS PROTECTION INTERIEURE
CONTACT TRANSPONDEUR
TÉMOIN DE NIVEAU DE LIQUIDE DE REFROIDISSEMENT SANS TEMOIN NIVEAU LIQUIDE REFROIDISSEMENT
ADAPTATION GARNITURE POMMEAU LEVIER VITESSE CUIR
SURTAPIS AVEC SURTAPIS
VOLANT VOLANT CUIR 4 BRANCHES
Electricité
ALTERNATEUR ALTERNATEUR CLASSE 9
BATTERIE BATTERIE L1 300
DÉMARREUR DEMARREUR CLASSE 3
MULTIPLEXAGE MONTAGE MULTIPLEXE
Marques d'équipements
Divers
ATMOSPHÈRE ATMOSPHERE NORMALE
BOITE DE PREMIERS SECOURS SANS BOITE PREMIER SECOURS
ADAPTATION PAYS SANS ADAPTATION PAYS
ROULAGE BONNE ROUTE
