[cpp]
Ligne de produit 406 RESTYL
N°APV/PR 08296 89 6 0012
Date de Début de Garantie 10/09/1999
NRE e2*93/81*0188*01
Informations générales
LIGNE DE PRODUIT 406 RESTYL
SILHOUETTE BERLINE 4PTES
FINITION NIVEAU 2
MOTEUR DIESEL TURBO DW10ATED SANS FAP
TRANSMISSION BVM5
COULEUR DE CAISSE PEINTURE BLEU SAMARKAND
TYPE D’HABILLAGE INTÉRIEUR VELOURS FOCH + POINTILLON "GR"
COULEUR DE GARNISSAGE "FZ"
BOITE DE VITESSES (CARACTÉRISTIQUES) BVM ML5T
MOTEUR (TYPE) MOTEUR TYPE EW/DW
MONOGRAMME COMPLÉMENTAIRE HDI
MONOGRAMME ST
Caractéristiques véhicule
FINITION NIVEAU 2
COUPLE TACHYMÈTRE CT 25 X 20
Alimentation moteur
CARBURANT GAZOLE
DÉPOLLUTION (MOTEUR) DEPOL CEE 95 (MOTEUR)
PRÉFILTRE MONTAGE SANS PREFILTRE
PRISE VITESSES (INFORMATIONS CAPTEUR) CAPTEUR EFFET HALL
CATALYSEUR CATALYSEUR 2 COMPOSES
REFROIDISSEMENT D’HUILE ECHANGEUR EAU/HUILE MOTEUR
COUPURE ALIMENTATION CARBURANT AVEC COUPURE ALIMENTATION CARBURANT
AUTODIAGNOSTIC EOBD SANS AUTO-DIAGNOSTIC "EOBD"
DISPOSITIF (ANTIPOLLUTION) SANS DISPOSITIF ANTIPOLLUTION
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE L3
VENTILATEUR 1 VENTILATEUR 350W
RÉCUPÉRATION DES VAPEURS D’ESSENCE SANS RECUP VAPEUR ESSENCE
VARIANTE ASSOCIÉE INJECTION SANS VARIANTE ASSOCIEE INJECTION
TRANSMISSION BVM5
COUPLE RAPPORT CP 16 X 65
STYLE ROUE ROUE TOLE
VERROUILLAGE SÉCURITÉ BOITE DE VITESSES SANS VERROUILLAGE SECURITE BV
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 195X65X15 H
ROUES MONTÉES ROUE 6 POUCES
ROUE (TYPE) MONTAGE ROUE TOLE
BOITE DE VITESSES TYPE BVM ML
Suspension Direction Freinage
ANTIBLOCAGE ANTI-BLOCAGE ROUE
BARRE ANTIDÉVERS ARRIÈRE BARRE ANTI DEVERS AR DIAM 22
ANTIVOL ANTIVOL STANDARD
ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAM 23
FREIN PRINCIPAL REPARTITION ELECTRONIQUE FREINAGE
FREIN TYPE DISQUES AV VENTILES/DISQUES AR
REFROIDISSEMENT D’HUILE POMPE DE DIRECTION AVEC REFROIDISSEMENT HUILE POMPE DIRECTION
SUSPENSION SUSPENSION NORMALE
SUSPENSION ACTIVE SANS SUSPENSION VARIABLE
AIDE AU FREINAGE D’URGENCE MONTAGE AMPLIFICATEUR BOSCH
Carrosserie Equipements
ANTENNE ANTENNE PAVILLON AMPLIFIEE
BRAS RACLETTE BALAI AV AVEC DEFLECTEUR
ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEUR AVEC JONC CHROME
ENJOLIVEMENT LATÉRAL (DIMENSION) PROTECTEURS LATERAUX LARG=50
ENJOLIVEUR ROUE (STYLE) STYLE JAZZ 7 AJOURS 15 POUCES
FEU D’ÉCLAIRAGE DE SEUIL SANS FEU ECLAIRAGE DE SEUIL
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETRO EXT SANS FONCTION COMPLEMENTAIRE
INSONORISATION COTÉ MOTEUR INSONORISATION CAPOT MOTEUR
ESSUIE-VITRE ARRIÈRE SANS ESSUIE-VITRE AR
PARE-CHOCS PARE-CHOCS AV/AR COULEUR CAISSE
PARE-BOUE (BAVETTE) SANS PARE BOUE
PORTE-BAGAGES MONTAGE SANS PORTE BAGAGES
RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETRO EXT CONDUCTEUR CHAUFFANT CDE ELECTRIQUE
RÉTROVISEUR EXTÉRIEUR (COTÉ PASSAGER) RETRO EXT PASSAGER CHAUFFANT CDE ELECTRIQUE
ACCESSOIRES EXTÉRIEURS RETRO EXT ET POIGNEES EXT COULEUR CAISSE
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) GLACE RETRO EXT CONDUCTEUR BOMBE
LAVE-VITRE ARRIÈRE SANS LAVE VITRE ARRIERE
TOIT OUVRANT TOIT FIXE
VITRE (ASPECT) TEINTEE
Equipement intérieur
ASSISE ARRIÈRE BANQUETTE AR COUSSIN MONOBLOC DOSSIERS SEPARES
ACCOUDOIR ASSISE ARRIÈRE AVEC ACCOUDOIR AR
BAGUETTE PLANCHER DE CHARGE SANS BAGUETTE PLANCHER CHARGE
RADIO-TÉLÉPHONE SANS PRE-EQUIPEMENT TELEPHONE
CACHE-BAGAGES SANS CACHE BAGAGES
CEINTURE DE SÉCURITÉ AVANT CEINTURE PYROTECHNIQUE SANS ALARME
CLIMAT (TEMPERATURE AMBIANTE) PAYS FROIDS
CLIMATISEUR AVEC AEROTHERME CDES ASSISTEES
CONSOLE CONSOLE LONGUE (VIDE-POCHE RAPPORTE)
EQUIPEMENT PLANCHE DE BORD PL/BORD GD VOLET V/P ENJOLIVEUR FACON RONCE NOYER
ANTIPARASITAGE ANTIPARASITAGE
FEUX INT. DIVERS LECTEUR DE CARTE
GARNISSAGE VOLUME CHARGEMENT GARNISSAGE COFFRE + VOLET AR
COMBINÉ (CARACTÉRISTIQUES) SANS BORD CHROMES COMPTE-TOURS GRADUATION INF
GARNISSAGE DE PORTE SANS DECOR FACON BOIS SANS CUIR
ANCRAGE SIÈGE ENFANT SANS ANCRAGE SIEGES ENFANTS
HAUT-PARLEUR MONTAGE 4 HP + 2 TWEETERS
FILTRE À POLLEN AVEC FILTRE A POLLEN
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) SANS RIDEAU PARE-SOLEIL
COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV MANUEL PASSAGER
RÉGLAGE ASSISE AVANT CONDUCTEUR DOSSIER CONDUCTEUR INCLINABLE
RÉGLAGE ASSISE AVANT PASSAGER DOSSIER PASSAGER INCLINABLE
ACCOUDOIR ASSISE AVANT MONTAGE SANS ACCOUDOIR AVANT
TÉMOIN DE FREIN DE PARKING SANS TEMOIN FREIN PARKING
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR CDE MANUELLE
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE SANS ECLAIRAGE
SAC GONFLABLE LATÉRAL AVANT SAC GONFLABLE LATERAL AV DOUBLE
LÈVE-VITRE ÉLECTRIQUE (FONCTIONNEMENT) ANTI PINCEMENT CONDUCTEUR
GRILLE HAUT-PARLEUR (COMPARTIMENT ARRIÈRE) AVEC GRILLE HP TABLETTE AR
ORDINATEUR DE BORD SANS ORDINATEUR DE BORD
PLAFONNIER CDE PTES AV+AR PLAFONNIER AV+AR
PARE-SOLEIL AVANT COTE CONDUCTEUR+PASSAGER SANS INSCRIPTION
RÉCEPTEUR RADIO SYSTEME AUDIO CASETTE RDS "RM2"
RÉFRIGÉRATION REFRIGERATION
REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE PARALLELE+AV
RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR - NUIT
RÉGULATION CLIMATISATION / TEMPÉRATURE AVEC REGULATION CLIMAT /TEMP
RANGEMENT (AUTRES) UNE BOITE DE RANGEMENT DANS COFFRE
RANGEMENT VOLUME CHARGEMENT SANS FILET DANS COFFRE
PROTECTION INTÉRIEURE SANS PROTECTION INTERIEURE
CONTACT TRANSPONDEUR
TÉMOIN DE NIVEAU DE LIQUIDE DE REFROIDISSEMENT TEMOIN NIVEAU LIQUIDE REFROIDISSEMENT
TÉMOIN D’ANOMALIES ANTIPOLLUTION SANS TEMOIN ANOMALIE ANTIPOLLUTION
ADAPTATION GARNITURE POMMEAU LEVIER VITESSE STANDARD
VOLANT VOLANT MOUSSE 4 BRANCHES
Electricité
BATTERIE BATTERIE L2 400
DÉMARREUR DEMARREUR CLASSE 6
Marques d'équipements
Divers
ATMOSPHÈRE ATMOSPHERE NORMALE
BOITE DE PREMIERS SECOURS SANS BOITE PREMIER SECOURS
ROULAGE BONNE ROUTE
TRIANGLE DE PRÉSIGNALISATION CONDITIONNEMENT TRIANGLE PRESIGNALISATION[/cpp]
