G
Guest
Invité
MaxiScan FR704 Code Scanner
Description:
Powered by Autel Uni-SCAN™ technology, the MaxiDiag™ FR704 is an innovative multi-functional scan tool designed for technicians to troubleshoot Engine, Transmission, ABS & Airbag systems for Renault/Citroen/Peugeot. Reliable, easy-to-use and affordable, the MaxiDiag™ FR704 is a time saver and a money maker.
Features:
1.Troubleshoots Engine Transmission ABS & Airbag Systems.
2.Global OBD2 - EOBD Coverage (US, Asian & European).
3.Supports all 9 Modes ofthe latest J-1979 OBD2 test specs.
4.Retrieves generic {PO,P2, P3 & UO} and Manufacturer Specific { P1, P3, & U1} Codes.
5.Displays DTC Definitions on- screen.
6.Views FREEZE FRAME DATA.
7.Displays O2 Sensor Data, as well as Live Datastream Parameters.
8.Data Graphing 1996 and later vehicles.
9.Reads, stores and playback of Live Sensor Data.
10.Memory/ Battery backup for off vehicle data review and analysis.
11.Performs Modules Present test.
12.Retrieves Vehicle Information. - VIN - CID - CVN.
13Supports all current OBD2 Protocols, including CAN {Controller Area Network}.
14.Easy to use and highly reliable.
15.Software up-gradeable via internet.
16.Built in OBD2 code Library.
17.Prints Data via PC.
http://www.autoobd2.co.uk/wholesale/maxiscan-fr704-code-scanner-reader-for-renault-citroen-peugeot-1198.html
Description:
Features:
