Informations générales concernant vote véhicule
LIGNE DE PRODUIT 207
SILHOUETTE BERLINE 5PTES
FINITION PREMIUM
MOTEUR DIESEL TURBO DV6ATED4
TRANSMISSION BVM5
COULEUR DE CAISSE KMU - PEINTURE BLEU NEYSHA
TYPE D’HABILLAGE INTÉRIEUR MAILLE ZINDAL + OMNI "WV"
COULEUR DE GARNISSAGE "FX"
BOITE DE VITESSES (CARACTÉRISTIQUES) BVM BE4 L
MOTEUR (TYPE) MOTEUR TYPE DV
MONOGRAMME SANS MONOGRAMME
Caractéristiques véhicule
FINITION PREMIUM
COUPLE TACHYMÈTRE SANS C T
Alimentation moteur
FILTRE RÉSERVOIR SANS FILTRE RESERVOIR
STOP AND START SANS STOP AND START
CARBURANT GAZOLE
DÉPOLLUTION (MOTEUR) DEPOLLUTION EURO 4(MOTEUR)
CATALYSEUR CATALYSEUR 2 COMPOSES IMPR PLATINE INF 50PPM
MOTEUR REFROIDISSEMENT RADIATEUR EP:18 - 21 DM2 ALU BRASE
AUTODIAGNOSTIC EOBD AUTO-DIAGNOSTIC "EOBD" SANS ACCELEROMETRE
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE EURO 4
VENTILATEUR 1 VENTILATEUR 2 VITESSES 140W AERO AVEC ECOPE
RÉCUPÉRATION DES VAPEURS D’ESSENCE SANS RECUP VAPEUR ESSENCE
TRANSMISSION BVM5
COUPLE RAPPORT CP 19 X 70
STYLE ROUE TOLE 6 J15 4-23
DIFFÉRENTIEL (BOITE) DIFFERENTIEL 77
JANTE / PNEU DIMENSION MONTE PNEU 15 POUCES
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 185/65 R15 88H NON RENFORCE
ROUES MONTÉES ROUE 6 POUCES
ROUE (TYPE) MONTAGE ROUE TOLE
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE SANS INDICATEUR PERTE PRESSION GONFLAGE
BOITE DE VITESSES TYPE BVM BE4R
Suspension Direction Freinage
ANTIBLOCAGE ANTI-BLOCAGE ROUE
ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAM 21
FREIN TYPE DISQUES AV VENTILES/TAMBOURS AR
COURSE MÉCANISME DE DIRECTION COURSE MECANISME DIRECTION 144
SUSPENSION SUSPENSION NORMALE
VARIANTE ASSOCIÉE FREIN ABS TEVES MK70
Carrosserie Equipements
ACCÈS ET DÉMARRAGE MAINS LIBRES SANS ACCES ET DEMARRAGE MAINS LIBRES
AVERTISSEURS AVERTISSEUR STANDARD
TOIT OUVRANT (ASPECT) SANS TOIT OUVRANT
DÉCORATION (ADHÉSIVE) ENJOLIVEUR AR ENCADREMENT NOIR MAT
DÉFLECTEUR AÉRODYNAMIQUE ARRIÈRE MONTAGE SANS DEFLECTEUR AR
ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEURS LATERAUX TEINTE MASSE
ENJOLIVEMENT LATÉRAL (DIMENSION) SANS PROTECTEURS LATERAUX
ENJOLIVEUR ROUE (STYLE) HOBART 8 AJOURS 15 POUCES
PROTECTION SOUS CAISSE PROTECTION PLASTIQUE + MOUSSE SOUS MOTEUR
ENJOLIVEUR DE SORTIE D’ÉCHAPPEMENT AVEC ENJOLIVEUR SORTIE ECHAPPEMENT
INSONORISATION COTÉ MOTEUR INSONO CAPOT + PROTECTION THERMIQUE
ESSUIE-VITRE AVANT ESSUIE-VITRE AV SANS CAPTEUR DE PLUIE
ESSUIE-VITRE ARRIÈRE (FONCTIONNEMENT) EV AR INTERMITTENT AUTO MAR
VITRE VOLET ARRIÈRE VITRE VOLET AR FIXE
SONDE TEMPÉRATURE EXTÉRIEURE AVEC SONDE TEMPERATURE EXT
PARE-CHOCS P/C AV/AR SPORT NEUTRE / COULEUR CAISSE
PLAQUE POLICE SANS PLAQUE POLICE
PORTE-BAGAGES MONTAGE SANS PORTE BAGAGES
PROJECTEUR SPÉCIAL (DOUBLE-OPTIQUE) PROJECTEUR DOUBLE PARABOLE
RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETRO EXT CONDUCTEUR CDE ELECTRIQUE
ROUE DE SECOURS ROUE GALETTE
ACCESSOIRES EXTÉRIEURS POIGNEES EXT + RETRO EXT COULEUR CAISSE
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) GLACE RETRO EXT BOMBE
TOIT OUVRANT TOIT FIXE
ENJOLIVEMENT PARE-CHOCS BANDEAU DE PARE-CHOCS TEINTE MASSE
VITRE (ASPECT) TEINTEE
VITRE (TYPE) P-B FEUILL + LAT ET AR TREMPE
Equipement intérieur
PACK AMBIANCE SANS PACK AMBIANCE
SAC GONFLABLE GENOUX CONDUCTEUR SANS SAC GONFLABLE GENOUX CONDUCTEUR
PRISE AUXILIAIRE PACK AUDIO SANS PRISE AUXILIAIRE PACK AUDIO
APPUI-TÊTE AVANT APPUI-TETE AV REGLABLE
CACHE-BAGAGES TABLETTE
CEINTURE DE SÉCURITÉ ARRIÈRE CEINT SECU AR 3 ENROULEURS 3 PTS + TEMOIN BOUCLAGE
CEINTURE DE SÉCURITÉ AVANT ALARME BOUCLAGE CONDUCTEUR + PASSAGER
CLIMAT (TEMPERATURE AMBIANTE) PAYS TEMPERES
CONDAMNATION ENFANT CONDAMNATION ENFANT MANUELLE AR
COMMODITÉS (POIGNÉES) POIGNEE AV PASS + ARRIERE + CROCHET
CONDITIONNEMENT RADIO ALIMENT ANTENNE RECEPTEUR HP AV/AR TWEETER
ECLAIRAGE RANGEMENT ECLAIRAGE BOITE A GANTS
EQUIPEMENT PLANCHE DE BORD PLANCHE DE BORD SOFT DECOR JULES
FEUX INT. DIVERS LECTEUR DE CARTE
COMBINÉ (CARACTÉRISTIQUES) GRADUATION 220 KM/H 140 M/H FOND BLANC CERCL CHROM
COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE
INSONORISATION HABITACLE INSONO TABLIER 5KG
REHAUSSE ASSISE AVANT PASSAGER REHAUSSE ASSISE AV PASSAGER REGLAGE PARALLELE
COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV MANUEL PASSAGER
RÉGLAGE ASSISE AVANT CONDUCTEUR MAINTIEN LAT FIXE CONDUCTEUR
RÉGLAGE ASSISE AVANT PASSAGER MAINTIEN LAT FIXE PASSAGER
ACCOUDOIR ASSISE AVANT MONTAGE SANS ACCOUDOIR AVANT
CONSOLE PLAFOND CONSOLE PLAFOND STANDARD
LAMPES DE PROJECTEURS LAMPE HALOGENE
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR CDE MANUELLE
AFFICHEUR AFFICHEUR (RADIO+MONTRE+ET OU T°,CD) SANS MEMOIRE
MIROIR DE COURTOISIE CONDUCT OCCULT+PASSAG NON OCCULT SANS ECLAIRAGE
INDICATEUR D’HUILE RECEPTEUR TEMPORISE NIV + TEMP
MONTAGE APPUI-TÊTE ARRIÈRE MONTAGE 3 APPUI-TETE AR
ECLAIRAGE BAS HABITACLE SANS ECLAIRAGE BAS HABITACLE
RÉTROVISEUR EXTÉRIEUR RETRO EXT CHAUFFANT
COMMANDE INTÉRIEURE DE PORTE (ASPECT) COMMANDE INTERIEURE PORTE ASPECT CHROME
PLAFONNIER CDE A DISTANCE PORTES + PLAFONNIER AV
PROJECTEUR DIRECTIONNEL SANS PROJECTEUR DIRECTIONNEL
PROTECTION POSTE AVANT SANS GRILLE DE SEPARATION
RANGEMENT (POSTE CONDUITE) VIDE POCHE INFERIEUR REFRIGERE
RÉCEPTEUR RADIO SYSTEME AUDIO COMPACT DISC RDS "RD4"
RÉFRIGÉRATION REFRIGERATION SIMPLE
RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR - NUIT NON ELECTROCHROME
RANGEMENT (AUTRES) POCHES AUMONIERES
TUNER-RADIO MONO TUNER RADIO
PROTECTION INTÉRIEURE SANS PROTECTION INTERIEURE
INDICATEUR DE TEMPÉRATURE EXTÉRIEURE (GRADUATION) INDICATEUR TEMP EXT CELSIUS
DÉTECTION D’OBSTACLE SANS DETECTEUR OBSTACLE
ADAPTATION GARNITURE SOUFFLET PLASTIQUE+POMMEAU CUIR+PASTILLE CHROME
SURTAPIS SANS SURTAPIS
FRÉQUENCE RADIO FREQUENCE RADIO EUROPE OCCIDENTALE
COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION +AUTOMATIQUE
VOLANT VOLANT CUIR
VERROUILLAGE RANGEMENT VIDE-POCHES SANS VERROUILLAGE
Electricité
BATTERIE BATTERIE L2 640
DÉMARREUR DEMARREUR CLASSE 4
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FREQUENCE TELECDE CONDA 433,92 MHZ HETERODYNE
MULTIPLEXAGE MONTAGE MULTIPLEXE CAN CAN
Marques d'équipements
Divers
ATMOSPHÈRE ATMOSPHERE NORMALE
ROULAGE BONNE ROUTE
BOÎTIER SERVITUDE BSI + COM 2005 BAGUE 4 POSITIONS
