Hello, You should activate them on BSI also. Otherwise it doesn't work. Do you have memory seat? Because mirror tilt needed.
Hello Dursun! No I do not have memory seat, and programming BSI is "chinese" for me. I read the tutorial by VLud but it is far away from my knowledge. I do not know what to write to where So I forget these options Thanks, Regards
Seat memory needed only for mirrors memory ) (but, in Peugeot 508, in fact it used it's own memory)))) But, as I understand, Dursun want to fold mirrors vian NAC...
bonjeur j'ai coché tout dans la zone 2106 mais image de camera ne pas affache. bonjeur oui j'ai fait tout mais image de caméra ne s'affiche pas.
Hi @Laleksss I want to do fold mirrors when i use gear. Somebody said before, there should be memory seat to do it.
No, it does not need the memory of seats for this option, my car (c4 b7) has no seats memory and has this feature
I do not know which accessory you should have for this function, I think that if you have the mirrors that can be closed with the key you can also have this function, for the hardware you must have a control unit in the door, in my citroen c4 b7 it is positioned in the passenger door
Hello to everyone. Thank you for the work done. it was nice. I have a request. I want to install radar and lane tracking camera on peugeot 2008 2020 model. I need electrical diagram. I will be glad if you help. You can contact us at dijitor@hotmail.com . thank you for everything.
Dear Rule Can you please tell me what and where did u set to have the tilt function. i had set it in nac, thats all for the time beeing Regards
The control unit in the passenger door is to memorize the mirror position for the passenger door. The other control unit to memorise the position of the driver mirror is the driver window scitch unit itself. Mirror with memory usually come with memory seats (except some cases like your C4 apparently), and this is the case on 3008, 5008, 508 and many other PSA cars: no memory seats, no memory mirrors, no mirror folding down when in reverse.
Hello Dursun, Sorry for the late reply,..please find attached photo about the parameter that i changed (sorry but it's in portuguese...). Regarding the area, I believe it was in "BSI2010: Driving comfort" (not completely sure). Just for reference, my previous DS4 had this functionality (and didn't have memory seats).. my current vehicle where I tried to activate this functionality (DS5) has memory seats but I still wasn't able to activate it.. Thank you. Cheers, Bruno
Hello Skeletiko, Thank you for replying. I don't have Mirror with memory Which comes with memory seats. So it will not work.
Wanted to thank you all for the help! Yesterday night I was able to test and HBA worked perfectly. When a car was coming shutting off the long lights, when I approached to a car, and when coming back to street lights. Also, i tested how to stop the function and worked too.
hello, i have peugeot 407 with bsi ev2 from peugeot partner but it still bsi2004, how configure cirocco display? i cant connect to display with arduino adapter i have upa usb too, i can read cirocco eeprom.
Hi, has someone worked on extended traffic sign recognition? i am working on this and now after activation in cvm and nac, i am not able to see them, so maybe i am missing something? i will keep posting if any update.
Hi Gentelmen, I need your help with the wave4 configuration. Few days ago i was change Wave2 on Wave4 at the Citroen C3 mk3. I done calibration base on the 308 config file and configuration base on the oryginal wave2 settings. In the same time i modyfied Parktronic Vision for 180deg panoramic (i knew i need to have panoramic module which is not yet instaled) and i was changed camera from 130deg to 180deg. Partronic is working fine but problem is with the contrast/color/brightnes. Description of the file: kamera 130 wave2 - oryginal camera with wave2 kamera 180 wave2 - changed camera with wave2 kamera 180 wave4 - changed camera with wave4 - issue with the resolution/contrast/brigthnes Please help me how to solve those issiue.
It was already documented on Github. There you are, custom calibration: C3_AIRCROSS_WAVE4-9693044280.cal
C'est simple, tu as pris un NAC Wave4 HD alors qu'il en faut un SD (cad sans mention HD) .. Les thèmes ne sont pas les même entre les deux variantes "hard" et ce n'est pas recodable.
