Thanks so much! I misunderstood the zones. By any chance do you have a list explaining the zones of the BTA3? As I guess it's true in most cases, it was a syntax error Unfortunately the unit continues to show the status attached. The antennae being internal, they can't be disconnected. This BTA does not have an external antenna. Could the unit be broken? Has anyone encountered such a situation? @VLud allow me to express my gratitude for the awesome work you did and, most of all, for making it available for all of us. This looks like it's going of a real PSA version of the VAG-COM
Get the Y obd2 cable connect booth diagbox and arduino and you can then log all data what you read with diagbox
C'est une idée intelligente ! Je viens d'en commander un, merci ! Avez-vous une idée de la raison pour laquelle mon BTA ne fonctionne pas ?
For future reference, the commands I used to change the VIN of BTA3S.2: Code: >77C:67C 10C0 21B0 :DC3B:83:C0 3BB05646374B46524843384353353036353235 3BB0FFFD00000002122022420
3BA0FFFD00000002122022420 not 3BB0FFFD00000002122022420 Secured Traceability zone must be written after each configuration for all ECUs (but especially for BTA & AAS) -- Your BTA could be broken yes, the antenna is printed on the circuit board so ... Uninstall Arduino IDE 2.X and install Legacy Arduino IDE 1.8 instead Should fix your problem with Serial Monitor
3BA...did not work. 3B0 worked... I assumed that B0 - VIN area - should be the one to secure. Regarding my BTA, I have to assume that the information in Diagbox is wrong, because I was able to dial the support number, a nice lady answered, we chatted a bit Also, there seems to be data traffic - as I got a notification from TomTom that I have never seen before. Unfortunately, after that, the "My DS" app disappeared for some reason.
Bonjour Vlud, je suis tout nouveau, j’ai parcouru pas mal de forum ici et ton nom ressort beaucoup . Je suis un peu largué en la matière mais j’aimerais savoir je viens d’acquérir un Peugeot 2008 année 2014 j’ai remplacé le SMEG par un NAC pour le CarPlay et je souhaite savoir s’il est possible d’installer la camera de recul et comment cela peut se faire ou se font les branchements? Est ce qu’il faut absolument une caméra d’origine? Merci beaucoup d’avance pour ton aide
Thank you very much, before i start can you help me with checking if i have the same calculator as yours? Thank you very much
Hi for the BSI i received > 62230013 AAS_UDS > 622101A5 NAC > 62210C0010 But the problem is with DAE_BVH2 after i enter 21A0 i didn't receive any message
Hi i did the exact way but i have a problem: Hi for the BSI i received > 62230013 AAS_UDS > 622101A5 NAC > 62210C0010 But the problem is with DAE_BVH2 after i enter 21A0 i didn't receive any message
But the problem is with DAE_BVH2 after i enter 21A0 i didn't receive any message Alors votre DAE est différent du mien ! Et je ne peux plus vous aider.
J'essaie d'activer l'assistance aux feux de route (HBA). Après avoir lu le 222101, j'ai obtenu cette réponse 62210104BCDD. Quelqu'un peut-il m'aider ? Merci beaucoup. I'm also trying to activate the High Beam Assist(HBA). After i readed the 222101 i get this response 62210104BCDD Can anyone help me please? Thank you very much
Does anyone have the pinout of the lvds cable that goes from nac to cirocco? I bought an lvds cable on amazon but the maps don't work on the cirocco and I think it must not be the correct cable, I guess there have to be different types of lvds cables and peugeot will use a different pinout
Just worked. Thank you very much J'essaie d'activer l'assistance aux feux de route (HBA). Après avoir lu le 222101, j'ai obtenu cette réponse 62210104BCDD. Quelqu'un peut-il m'aider ? Merci beaucoup. I'm also trying to activate the High Beam Assist(HBA). After i readed the 222101 i get this response 62210104BCDD Can anyone help me please? Thank you very much
Hello, First of all, thanks a lot for all your help provided to this forum. I have a Peugeot Rifter GT 2021 and I would like to activate the cornering lights. Hope you can help me with this. I have read these are the command lines: 652 752 2E:2324:04:01 652 752 2E:23AE:04:01 However, I am receiving error "7F2722" (Unlocking - Conditions not correct) as soon as I unlock BSI. That is, this is the list of commands (with answer): >764:664 --> OK 1003 --> 500300C80014 >752:652 --> OK 222324 --> 62232400 :B4E0:03:03 --> 7F2722 It seems the unlocking command is not working. Could you please try to help me? Which unlock command should I use instead? Merci beacoup! Eduardo
Quelqu'un peut-il m'aider à activer l'assistant feux de route? Après avoir lu le 222101, j'obtiens cette réponse 62210104BCDD Merci beaucoup ------------------------------------------- Anyone can help me to activate the high beam assist? After i readed the 222101 i get this response 62210104BCDD Thank you very much
Salut pouvez-vous m'aider à activer l'assistant de feux de route? Après avoir lu le 222101, j'obtiens cette réponse 62210104BCDD Si je comprends bien, j'aurais besoin d'écrire 2E210104B8CD ? Merci beaucoup ------------------------------------------- hi can you help me to activate the high beam assist? After i readed the 222101 i get this response 62210104BCDD If i understand correctly i would need to write 2E210104B8CD ? Thank you very much
Hello! I will respond myself to this. Finally I had to swith off the engine of the car before doing the unlock command in Arduino so I did not receive the error answer. Afterwards, I was able to continue with the rest of the commands and activated the cornering lights. Just in case this helps other people. Thanks! Eduardo
Chers amis! Si la voiture (à partir de 2017 3008) a une fonction de reconnaissance des panneaux, mais pas d'assistance de voie et de régulateur de vitesse adaptatif. Avez-vous besoin d'une autre caméra ou simplement de codage ? Merci et salutations Hello Friends! If the car (3008 from2017) has sign recognition function but do not have lane assist and adaptive criuse control. Is is need a different camera or only coding? thanks Regards
