Mais si que j'écoute!J'ai pas l'impression que tu m'écoutes ...
J'ai push la 1.0.4 vite fait :
Oui! Tout de suite quand le boutons "Thèmes" est apparu 'ai changé de thème et ça a fait réagir le ciroccoIl n'y a qu'une fois que les thèmes sont activés dans le iCockpit que tu peux changer les thèmes sur le NAC oui
Ils communiquent ensemble
Dear Vlud. Thanks for the update. But when I connected, there is no theme selection in 2300 region. I got the message unsupported your unit.@erdo_celik : 1.0.4 will fix your issue for themes on >= 2019 cars
The theme selection in the 2300 region is opened. But while writing cirocco, the program closes itself. When I start the program again and read it, I see that the ambience 7 and 8 are enabled in my cirocco 2300 region. I have enabled ambience 1 and 2. I opened the menu-4 in Region 2127. unfortunately the theme selection button disappeared. I did the back up of the ccirocco and nac. it came again.1.0.5 pushed, the position is not the same .. so complicated to have a unified config file between all variants
The theme selection in the 2300 region is opened. But while writing cirocco, the program closes itself. When I start the program again and read it, I see that the ambience 7 and 8 are enabled in my cirocco 2300 region. I have enabled ambience 1 and 2. I opened the menu-4 in Region 2127. unfortunately the theme selection button disappeared. I did the back up of the ccirocco and nac. it came again.Voir la pièce jointe 18609
Hello, I saw you have the new 2008, I have a question for you; When you change the driving mode (eco,normal,sport) does the speedometer changes colors automatically? As far as I know on the 3008 CIROCCO when you put sport mode on it turns red. I just replaced the RCC on my friend's new 208 and I was playing with combine_ev theme when I noticed that by changing driving modes, the theme of the speedometer doesn't changes. It's only possible to switch between green, blue and red using the ambiance menu on the NAC. Am I right or there's a feature to enable?Je suis à la recherche du calculateur SDCM (ouverture démarrage sans fil) il n’apparaît pas dans la list des ECU_IDs_List, l’AVAS apparaît (>5B0:5AF) mais il n’y a pas la clé
PS: I will attach some photos of what I did
If I set active DS model
When you activate sport mode, the global color of the display does not change, however there are some additional red lines next to the motor temperature and fuel level gauges.
And I think some other small details turn to red.
There's also the SPORT word (and in eco mode ECO) in red below the current gear (don't know if it's displayed when you have manual gearbox but I would expect it is still displayed somewhere)
Which one (ID) ? What is your current software version ?
Did it ever display a DS4 ?
Please provide your backup too, it would help
