[TUTO] Télécodage et calibration d'un NAC / RCC / CIROCCO SANS Diagbox via Arduino
Discussion dans 'NAC' démarrée par VLud, 2 Septembre 2020.
  1. marcins
    marcins Peugeot Addict
    Inscrit depuis le :
    23 Novembre 2020
    235
    "J'aime" reçus :
    124
    Dravos et nico1080 aiment cela.
  2. marcins
    Inscrit depuis le :
    23 Novembre 2020
    235
    "J'aime" reçus :
    124
    That's not OBD2 reader :) is a Boost controller Greddy http://www.greddy.com/products/electronics/profec/
  3. Corin
    Corin Membre régulier
    Inscrit depuis le :
    23 Octobre 2018
    40
    "J'aime" reçus :
  4. hangway2
    hangway2 Membre régulier
    Inscrit depuis le :
    15 Février 2020
    41
    "J'aime" reçus :
    7
    @nico1080
    i saw a 5008 Cirocco cluster without LVDS output, so keep it in mind when buying yours.
    Regarding the frame, LATAM had a Facelift after 2018, with a digital monochromatic cluster and this is the frame. My OEM cluster is the same as DS4, with 3 rounded gauges and a center colored matrix screen. I wish i could use this frame to build a model for 3D print.
    @marcins which software you used to create the model for 208?
    Other guys answered about the mileage.
  5. RuLe
    RuLe Peugeot Addict
    Inscrit depuis le :
    26 Août 2020
    135
    "J'aime" reçus :
    56
  6. marcins
    Inscrit depuis le :
    23 Novembre 2020
    235
    "J'aime" reçus :
    124
    @hangway2 Fusion360
    hangway2 aime votre message.
  7. nico1080
    nico1080 Peugeot Addict
    Inscrit depuis le :
    13 Mars 2021
    50
    "J'aime" reçus :
    11
    Great :bien: Is there someway of knowing the actual mileage before changing the line content? (something like HEX to decimal conversion)
    Thank for the warning, so basicaly any cirocco will work as long as it have lvds connector? (I may have found one but it have a different part number)
    For the frame, its clearer now (I was confused because it is impossible to find picture of the new cluster in google image)
    Do you have a part number for this? (frame alone, or full cluster)
    In your 3d print do you plan to integrate the rheostat switch?
    The 3008 cirocco with his frame seems wider than the C4 dashboard so I guess fitting the 3008 frame inside C4 dashboard is impossible
  8. RuLe
    RuLe Peugeot Addict
    Inscrit depuis le :
    26 Août 2020
    135
    "J'aime" reçus :
    56
    No, all versions of cirocco work, the lvds socket only serves to see the navigation map from nac, to have this you must also have nac with double lvds
    After reading the eeprom and getting the dump follow this
    #1898 RuLe, 10 Avril 2021
  9. hangway2
    Inscrit depuis le :
    15 Février 2020
    41
    "J'aime" reçus :
    7
    thanks!
    I’ll try to create models for C4B7.
  10. hangway2
    Inscrit depuis le :
    15 Février 2020
    41
    "J'aime" reçus :
    7
    I’ll include, if there is room for them.
    Fitting the cluster into C4 dashboard require adjustments (@RuLe can give more information about this, as he already made it).
    @RuLe do you think we can use your work to create 3D models of a frame to fix the cluster electronic board and the outer frame?
  11. Okalba
    Okalba Membre
    Inscrit depuis le :
    10 Juillet 2019
    "J'aime" reçus :
    Can I put on my 508 cirocco display ?
    Thanks a lot
  12. nico1080
    Inscrit depuis le :
    13 Mars 2021
    50
    "J'aime" reçus :
    11
    @Dravos Do you have the full pinout for cirocco connector, I did more digging in the schematic and I found that standard cluster also manage the parking, dead angle (orange light in rearview mirror called SAM by PSA) and AFIL (lane keeping) switch
    In yellow the pins I am missing.
    For parking and dead angle, is it still managed by cluster? Or will it require a fix like ESP switch?
    For hill assist and dynamic driving I believe theses options do not exist on the original cluster So it should be OK.
    All schematic are in my media
    @RuLe I am not sure to understand, from @marcins message I understood that line 480 and 490 contained actual mileage of the cluster encoded in a specific format.
    I was asking, out of curiosity, how to convert it to know the mileage. To verify that the donor car have not too much mileage, but I don't really need to know it.
    In all case changing these two lines to 00 and FF will reset the mileage so that is what I really needed
  13. Seb70220
    Seb70220 Peugeot Addict
    Inscrit depuis le :
    28 Septembre 2019
    47
    "J'aime" reçus :
    9
    Bonjour d'après tout ce que j'ai pu lire sur la discussion si le cirocco a un kilométrage inférieur a celui de la voiture ça sera celui de la voiture qui sera redéfini, c'est bien ça ? j'ai aussi regardé le pinout du cirocco 3008,ok je voit bien a quel pin est attribué chaque fil, mais ou se situe exactement le pin 1 dans la broche blanche sur le compteur, merci d'avance
  14. nico1080
    Inscrit depuis le :
    13 Mars 2021
    50
    "J'aime" reçus :
    11
    Non c'est l'inverse c'est le plus grand chiffre qui est appliqué partout. (Km stocké dans le BSI, le calculateur moteur et le compteur)
    Donc si on connecte un cirocco qui a plus de km, il fera monter le km de la voiture de façon irréversible... A éviter donc :fracasse:
    Pour les pins, c'est bien le connecteur 18 pins (2rangées de 9) Les numéros sont gravés un peu partout sur le plastique des connecteurs
    Seb70220 aime votre message.
  15. Seb70220
    Inscrit depuis le :
    28 Septembre 2019
    47
    "J'aime" reçus :
    9
    @nico1080 ok donc je suis bon le cirocco récupéré a 31225 Kms et ma voiture 110000, pour les pins gravés je ne les ai pas sur le cirocco, je n'ai pas encore démonté coté voiture. Merci pour ta réponse
  16. RuLe
    RuLe Peugeot Addict
    Inscrit depuis le :
    26 Août 2020
    135
    "J'aime" reçus :
    56
    Yes, sorry what @marcins wrote is correct, the video I posted is wrong, I have confused the link to the video, now I have corrected, if you select the bytes in hex, as indicated by @marcins , and it inspects or converts to binary you have the km of the car
    For the connection diagram, however, you will not be able to have anything working anymore, only the parking brake light, the other buttons, even if connected, do not work, you can activate the deactivation of the parking sensors in nac, I did a lot of tests and this is what I managed to get it to work
  17. marcins
    Inscrit depuis le :
    23 Novembre 2020
    235
    "J'aime" reçus :
    124
    @RuLe send you perfect example but is need to understand how the cluster save mileage
    is saved in 4 steps 4 differ address 5-6km difference :) cirrocco i readed eeprom see pics what's actual mileage is
    #1907 marcins, 11 Avril 2021
    nico1080 aime votre message.
  18. nico1080
    Inscrit depuis le :
    13 Mars 2021
    50
    "J'aime" reçus :
    11
    Thank it is very clear for reading mileage :bien:
    @RuLe for the button connection, it mean that I will loose the ESP, parking and dead angle physical switch
    However it is possible to have parking switch in NAC touchscreen.
    Did you find a similar setting for dead angle?
  19. RuLe
    RuLe Peugeot Addict
    Inscrit depuis le :
    26 Août 2020
    135
    "J'aime" reçus :
    56
    @nico1080 For the parking sensor button there is the option to be activated in bsi, unfortunately there is no possibility to make other buttons work on nac
  20. nico1080
    Inscrit depuis le :
    13 Mars 2021
    50
    "J'aime" reçus :
    11
    I guess it is the parameter: "Type d'acquisition du contacteur d'inhibition de l'aide au stationnement" in "aide à la conduite" inside the BSI My car is configured with " Par le Combiné"
    So changing this setting inside the BSI + activating in NAC the touch screen button in AAS section (2100) will make it work?
    Regarding the blind spot detection, on 3008 there is no physical button, and bsi 2010 does not any setting for selecting the source.
    If oem cluster is unconnected does blind spot still work? (the whole function, not the switch)
    In my case I always leave it on, so losing the switch is not an issue as long as the fonction work.
    Maybe the other solution would be to emulate the original cluster frames like @marcins is doing with ESP button.
    Upon further thought would it possible to connect only CAN and power on cirocco and keep original cluster (with can and all the button) to manage all the function originally managed by the cluster?
  21. Dravos
    Dravos Peugeot Addict
    Inscrit depuis le :
    3 Novembre 2020
    88
    "J'aime" reçus :
    Only parking sensor u can use, the rest are not working, like esp.For cirocco is new bsi2010evo, communication with esp and other are make by can and not working on bsi 2010 like u have.
  22. Okalba
    Okalba Membre
    Inscrit depuis le :
    10 Juillet 2019
    "J'aime" reçus :
    Hello,
    can eny one please tell me if I can put cirocco display on my dash bord on my 508 2014? Thanks my friends
  23. RuLe
    RuLe Peugeot Addict
    Inscrit depuis le :
    26 Août 2020
    135
    "J'aime" reçus :
    56
    In bsi you can only activate the parking sensors, while if you leave blind spot monitoring active they will remain active and in operation even after replacing the cluster
  24. hangway2
    Inscrit depuis le :
    15 Février 2020
    41
    "J'aime" reçus :
    7
    Guys, my C4 has blind spot monitor (SAM) and I can activate / deactivate it through NAC (actually, even through the old RT6 I took out).
    I must connect Lexia and the Arduino to check the parameters and share with you, but yes, it can be done
  25. RuLe
    RuLe Peugeot Addict
    Inscrit depuis le :
    26 Août 2020
    135
    "J'aime" reçus :
    56
    With arduino make a backup of the bsi configurations
  26. Dravos
    Inscrit depuis le :
    3 Novembre 2020
    88
    "J'aime" reçus :
    @RuLe how can I make backup config from bsi? Can u tell me command for arduino please?
  27. Dravos
    Inscrit depuis le :
    3 Novembre 2020
    88
    "J'aime" reçus :
    yes,u can.
  28. RuLe
    RuLe Peugeot Addict
    Inscrit depuis le :
    26 Août 2020
    135
    "J'aime" reçus :
    56
    It has been explained several times in various discussions how to read configurations via console, the commands are all explained by vlud on his github
  29. horuscurcino
    horuscurcino Peugeot Addict
    Inscrit depuis le :
    20 Août 2018
    56
    "J'aime" reçus :
    16
    All the CIROCCO panels have the pin to receive the actual buttons to turn OFF/ON the ESP and its lights like the older dashboard. There is a parameter on telecoding to activate this pin and make the panel handle the request. But at least in the 3008 calibration i was not able to make it work. Its like the calibration lacks its support. At this time I recommend to leave at least the board of the old cluster installed to keep it working. Just sharing my experience.
    #1919 horuscurcino, 12 Avril 2021
  30. joan carlos
    joan carlos Peugeot Addict
    Inscrit depuis le :
    25 Juillet 2020
    47
    "J'aime" reçus :
    5
    Hi! I had already thought about it! but to work it will have to make two connections to feed the boards!
Partager cette page
    Rejeter la notification
