[TUTO] Télécodage et calibration d'un NAC / RCC / CIROCCO SANS Diagbox via Arduino
Discussion dans 'NAC' démarrée par VLud, 2 Septembre 2020.
  1. nico1080
    nico1080 Peugeot Addict
    Inscrit depuis le :
    13 Mars 2021
    50
    "J'aime" reçus :
    11
    Basically you suggest to just connect CAN and power to cirocco on additional harness and leave the electronic or the old cluster to manage all the original function.
    Would it cause any issue to have 2 cluster connected at the same time?
    If cirocco is only "listening" on CAN it should be Ok but if he send messages it could become an issue.
  2. Dravos
    Dravos Peugeot Addict
    Inscrit depuis le :
    3 Novembre 2020
    88
    "J'aime" reçus :
    Cirocco don't have pin for esp!!! Check schematic. I check for 508 and 3008 and don't have.
    Miguel Angel aime votre message.
  3. Dravos
    Inscrit depuis le :
    3 Novembre 2020
    88
    "J'aime" reçus :
    Sorry for disturb you... I just not understand how to use it... My apologies...
  4. RuLe
    RuLe Peugeot Addict
    Inscrit depuis le :
    26 Août 2020
    135
    "J'aime" reçus :
    56
    @Dravos It didn't disturb me at all but it's just annoying and useless to fill the discussion with things that have already been said
    #1924 RuLe, 12 Avril 2021
    Dravos aime votre message.
  5. marcins
    marcins Peugeot Addict
    Inscrit depuis le :
    23 Novembre 2020
    235
    "J'aime" reçus :
    124
  6. marcins
    Inscrit depuis le :
    23 Novembre 2020
    235
    "J'aime" reçus :
    124
    Without connecting the ESP button , esp still owrks :) ESP button is just to deactivate ESP for some period of time in normal cars and all the time in GTI until is turned on again with button or you restart engine again ...
    At start ESP is fully functional and 98%ppl don't need to think about , i have GTi and need sometimes to deactivate it :) thats why im searching solution ..
    parking sensor OFF/ONN can be set to work on NAC
    tyre pressure initialization also can be set to work in NAC
    the buttons without funcion can be wired to 2 push buttons on 3008 ciroccoto change ilumination and to ''check -display ''
    hangway2 aime votre message.
  7. hangway2
    hangway2 Membre régulier
    Inscrit depuis le :
    15 Février 2020
    41
    "J'aime" reçus :
    7
    I have performed some tests today. I don't know why, but if the SAM virtual switch is enabled in 2119 tab, NAC will show the ON/OFF switch, but it won't work. However, if the switch is enabled throug 2127 tab, it will be showed under Safety options and work.
    Even if I have both enabled simultaneously, only the 2127 works.
    I couldn't backup BSI parameters, as i don't know the steps to follow.
    The attached pictures are exactly the current parameters in my NAC and SAM can be turned ON/OFF through it's virtual switch.
    Pièces jointes:
      Taille du fichier:
      106.8 Ko
      Affichages:
      64
      Taille du fichier:
      53 Ko
      Affichages:
      62
  8. hangway2
    Inscrit depuis le :
    15 Février 2020
    41
    "J'aime" reçus :
    7
    Nice to know that I can "recycle" these switches, because I was wondering how to reallocate the brightness and maintenance switches from Cirocco. Just need to reuse the 2 boards, right?
  9. hangway2
    Inscrit depuis le :
    15 Février 2020
    41
    "J'aime" reçus :
    7
    I tried to enable video playback through USB stick, but couldn't find an option to do it.
    I'm using a NAC Wave 4 SD with DAB.
    I used the "search" function and filtered the results in this topic, other members already asked for it, but I didn't found the answer.
    Anybody knows how to do it?
    Thanks in advance.
  10. horuscurcino
    horuscurcino Peugeot Addict
    Inscrit depuis le :
    20 Août 2018
    56
    "J'aime" reçus :
    16
    When the official document says "track not connected" it is related to limitations on the vehicle you are viewing. For example when you search for the pins descriptions under C4 Gran Picasso it says "track not connected" to many other pins which are already described on this 3008 page. CIROCCO was used in a variety of cars such as 508 II, DS7, DS9, Chinese C5 and C6, 5008, Corsa etc. I can not tell exactly which pin needs to be triggered to turn ESP ON/OFF but is certainly one of those "not connected" pins which all CIROCCO have despite its calibration. I was planning to discover by myself once the telecoding was done but was not.
    Btw, the parameter is called "CFG_EI2_CMB_WIRE_IN_ESP_PUSH_000".
  11. VLud
    VLud Lion de Bronze
    Inscrit depuis le :
    19 Janvier 2018
    1 931
    "J'aime" reçus :
    1 039
    CFG_EI2_CMB_WIRE_IN_ESP_PUSH_000 data byte 2 or 6 on zone 2101
    All wires settings seem to be inside 2101 zone (IN & OUT)
    #1931 VLud, 13 Avril 2021
    marcins aime votre message.
  12. Lubvic
    Lubvic Membre
    Inscrit depuis le :
    5 Mars 2021
    9
    "J'aime" reçus :
    [QUOTE = "Hallahub, post: 2614073, member: 114118"] Ora hai solo 4 sensori posteriori, se scambi l'ecu AAS con 6 + 6 uno e non ti connetti un totale di 12 sensori, vedere l'errore di assistenza al parcheggio sul cruscotto. La codifica manuale dell'AAS_UDS_gen6 (che è la centralina di parcheggio della nuova Peugeot 208/2008 opel corsa ecc.) Non è possibile, non c'è nemmeno un menu all'interno di diagbox per questo. Penso che se non aggiungi tutti i sensori extra il sistema non funzionerà.
    modifica: hai solo 6 sensori posteriori, sei sicuro? Mi sembra strano. [/ QUOTE]
    Ciao Hallahub, mi dispiace disturbarti di nuovo, non riesco a trovare un modo corretto per procedere con l'installazione dei miei sensori ... ora ho AAS 12x, telaio posteriore con 6 sensori, sto acquistando il telaio anteriore con 6 sensori, ma. .. ho bisogno di sapere se, una volta installato tutto, cosa devo fare davvero, riprogrammare solo BSI? come è possibile in una 2010-evo, magari usando qualche altro VIN di un'auto donatrice?
    Non voglio installare tutto e perdere gli 8 sensori che ora funzionano bene, se non riesco a portare a termine il lavoro.
    Grazie!
  13. Dravos
    Inscrit depuis le :
    3 Novembre 2020
    88
    "J'aime" reçus :
    THIS ZONE CAN BE MODIFIED ?
  14. Kaiserssosse
    Kaiserssosse Membre
    Inscrit depuis le :
    23 Mars 2021
    7
    "J'aime" reçus :
    @VLud, Est-il possible dans un Traveler 2018 de désactiver le son émis lors de l'ouverture ou de la fermeture de la porte latérale automatique? Toute aide appréciera. (Sorry for my French)
    English: Is it possible in a Traveller 2018 to disabled the sound made when automatic side door is opening or closing? Any help will appreciate
  15. Ricardo Santos
    Inscrit depuis le :
    11 Janvier 2021
    7
    "J'aime" reçus :
    Is it possible to install a nac wave 2 in a Peugeot RCZ?
    Wich calibration file should I use?
  16. BR308
    BR308 Membre
    Inscrit depuis le :
    30 Novembre 2020
    9
    "J'aime" reçus :
    Bonjour, ma femme a un C4 Grand Picasso 2017 avec l'assistance au parc 360. Le problème est que chaque fois qu'elle engage la marche arrière, le système demande quelle vue afficher (comme dans la première photo ci-jointe), et c'est ennuyeux. Est-il possible que le NAC automatique affiche cette autre manière (avec vue d'oiseau et vue arrière - deuxième image)? Dois-je uniquement télécoder ou dois-je effectuer des modifications de connexion dans le faisceau de la caméra? Merci et désolé pour le pauvre français.
  17. RuLe
    RuLe Peugeot Addict
    Inscrit depuis le :
    26 Août 2020
    135
    "J'aime" reçus :
    56
    You need to duplicate the video signal from the instrument cluster to the nac
    BR308 aime votre message.
  18. hangway2
    Inscrit depuis le :
    15 Février 2020
    41
    "J'aime" reçus :
    7
    Hi guys! After upgrading from a NAC Wave 2 to a NAC Wave 4, i'm facing some issues.
    Today I spent some time trying to figure out why the NAC is assuming there are obstacles in front and behind my vehicle, even if I'm in a open field and there is nothing around my car.
    The point is: every time I engage the R gear, the Visiopark shows the zoom view and the virtual top view shows red alerts like if there are obstacles close to both bumpers.
    I tried to restore the original config file, change the vehicle and compared the W2 and W4 backups but couldn't identify different parameters.
    The BSI parameters are correctly set as if I reinstall the W2, the issue go away.
    There are no errors on AAS or any BSI related module.
    Anybody can think about something I'm missing or had similar issue?
    Attached pictures and my W4 config file.
    AAS_1 picture was shot while I was parked with any obstacles close to the car.
    AAS_2 picture was shot immediately after AAS_1, but I switched the gear lever from R to N.
    AAS_3 picture shows the 2 right sensors working properly (the front right yellow and rear right white alerts).
    AAS_4 picture show the 2 center front and 2 center rear sensors not working properly.
    Thanks.
    Pièces jointes:
      Taille du fichier:
      86.8 Ko
      Affichages:
      76
      Taille du fichier:
      117.2 Ko
      Affichages:
      76
      Taille du fichier:
      96.7 Ko
      Affichages:
      74
      Taille du fichier:
      73.1 Ko
      Affichages:
      72
    • NAC_W4.txt
      Taille du fichier:
      856 octets
      Affichages:
      17
  19. BR308
    BR308 Membre
    Inscrit depuis le :
    30 Novembre 2020
    9
    "J'aime" reçus :
    merci!
  20. Dravos
    Inscrit depuis le :
    3 Novembre 2020
    88
    "J'aime" reçus :
    How?
  21. zakariam
    zakariam Nouveau membre
    Inscrit depuis le :
    31 Mai 2018
    "J'aime" reçus :
    Bonsoir j ai besoin ponout bsi pour connecter le nac sur tabale merci
  22. zakariam
    Inscrit depuis le :
    31 Mai 2018
    "J'aime" reçus :
    Tu peux m envoi le pinout bsi pour connecter nac sur table
  23. marcins
    Inscrit depuis le :
    23 Novembre 2020
    235
    "J'aime" reçus :
    124
    Latest cirocco.exe app not works with load .cal/.ulp same problem here ...
  24. Dravos
    Inscrit depuis le :
    3 Novembre 2020
    88
    "J'aime" reçus :
    Please send me calibration for 508 if u can, thank you!
  25. erdo_celik
    erdo_celik Membre
    Inscrit depuis le :
    7 Décembre 2020
    20
    "J'aime" reçus :
    Why are we processing the 2901 area when the writing process is finished?
    > 2E2901FD000000010101 ????
    < 6E2901 ????
  26. marcins
    Inscrit depuis le :
    23 Novembre 2020
    235
    "J'aime" reçus :
    124
    writing of variant coding traceability last 6 digit is date...
  27. marcins
    Inscrit depuis le :
    23 Novembre 2020
    235
    "J'aime" reçus :
    124
    read private msg ...
  28. Dursun
    Dursun Membre
    Inscrit depuis le :
    10 Mai 2020
    21
    "J'aime" reçus :
    Hello,
    Is it possible to use lexia cable to use vlud program.
  29. marcins
    Inscrit depuis le :
    23 Novembre 2020
    235
    "J'aime" reçus :
    124
    No ....
  30. zakariam
    Inscrit depuis le :
    31 Mai 2018
    "J'aime" reçus :
    You can share pinout bsi to nac thank you
Partager cette page
    Rejeter la notification
