[TUTO] Télécodage et calibration d'un NAC / RCC / CIROCCO / CMB_NUM SANS Diagbox via Arduino
@marcins
OK, thanks. It's curious not to be able to write anymore...
I have a write log on this ECU, with DB 7.62 by choosing Peugeot 309
DB had changed BD to A5
75D:2703 Unlock Calculo
65D:6703DC29FD74 Key
75D:27046DEB7F5F Calculated Key
65D:6704 Key OK !
75D:2E2101A5 Write A5 in 2101
65D:7F2E78 Configuration Write in progress
65D:6E2101 Well write A5 in 2101
75D:222101 Read 2101
65D:622101A5 Well read 2101 = A5
I don't understand this sentence :
"where key is valid as you can unlock for download :) :xxxx: 01: 02"
Thanks for your help !
looks like you simulator works :) but that's differ to real world :) of coding ...
as you can't comment Configuration Write in progress when Negative response is send , that's make no sense
@marcins
I don't think 7F2E78 is an error message ... It's a timeout message, right ?
Only 7F 27 XX XX are négative response, no ?
By rereading the zone, DB checks that it is well written.
But with VLud's software, I can't modify this zone !
@marcins
i ready told you there 17 differ comunication protocol and 2 comunication lines diagbox use :) ...
depending of the ecu diagbox switch portocol and comunication line ...
every zone 7F is failure ....
7F2E78 est bien un message "d'attente", pas une erreur
La clé de ton AAS est bien D1F5 (basé sur tes logs), tu oublies simplement de switcher sur la bonne paire d'ID ... sans ça tu essayes de débloquer le BSI avec une clé incorrecte !
Code:
>75D:65D
puis
Code:
:D1F5:03:03
et ça fonctionnera beaucoup mieux
Code:
>75D:65D
puis
Code:
:D1F5:03:03
tried this and don't work on AAS_UDS for config works also for download :)
No issue here
Moteur coupé, contact mis, ça fonctionne parfaitement
je serai bientôt en possession d’un compteur avec matrice couleur
ayant reçu le matériel nécessaire (arduino/shield)
le vendeur n’a pas su me donner le kilométrage donc je me demandais si l’on peus l’alimenter en volant afin de connaître son kilométrage
merci
@VLud
Je viens de refaire des essais, OK pour le NAC, mais toujours un problème pour écrire dans l'AAS !
J'ai : 7F2737 ERREUR : Required Time Delay Not Expired (Que je ne comprends pas ! Ce serait "Expired", ce serait une erreur, mais "Not Expired" ! Je pige pas ! )
Si vous avez une idée, elle sera la bienvenue ! Je commence à désespérer !
Bonne fin de WE.
Sur MON NAC :
-> 1003
< 500300C80014
-> >764:664
< OK
-> : D91C:03:03
-=-=-=-=-=- En Attente de : 6704 -=-=-=-=-=-
<- 500300C80014
<- 670392E3BAEB
< 6704
-------------> Le Calculo EST Débloqué <-----------------
-> 2E21000140
-=-=-=-=-=- En Attente de : 6E2100 -=-=-=-=-=-
<- 7F2E78 : Configuration Write in Progress
< 6E2100
--------------> ÉCRITURE Zone : 2100 OK ! <-------------
-> 1001
< 500100C80014
Tout va bien...
Sur MON AAS :
-> 1003
< 5003
-> >75D:65D
< OK
-> 2703
-=-=-=-=-=- En Attente de : 6703 -=-=-=-=-=-
<- 7F2737 ERREUR : Required Time Delay Not Expired
<- RIEN !
-------------> 6703 NON Reçu ! <-----------------------
-> 1001
< 5001
NOUVELLE ÉCRITURE...
-> 1003
< 5003
-> >75D:65D
< OK
-> : D1F5:03:03
<- 5003
<- RIEN !
----------------> Le Calculo N'EST PAS Débloqué ! <---------------------
1.2.6 publiée
Déobfusqué donc plus de faux positif virus
Options manquantes ajoutées:
- Bouton tactile pour l'allumage automatique des feux - en zone 2109
- Export des informations media (pour la matrice / compteur) - en zone 2104
- Cacher les lignes de la caméra de recul - en zone 2108
Merci à @Keryan & @Hallahub
1.2.6 released
Unobfuscated so no more virus false positive
New settings added :
- Tactile button for main beams assistant - inside zone 2109
- Media informations export (for matrix / instrument panel) - inside zone 2104
- Hide rear view camera lines - inside zone 2108
Thank's to @Keryan & @Hallahub
@sound6 : cette version te permettra d'activer l'export en zone 2104 ;)
1.2.6 publiée
1.2.6 released
Oh voilà une bonne nouvelle merci
Je crois que je viens de comprendre le code 7F2737 !
Ça signifierait que le calculateur a été bloqué pour une période de XXX minutes, suite à un mauvais code de déblocage !
Mais dans la version où j'envoie 2703, je ne vois pas ce qui pourrait bloquer !
Dans la version où j'envoie : D1F5:03:03, si la clé n'était pas bonne, ça bloquerait : OK. MAIS je suis sûr de cette clé car j'ai un log d'écriture avec DB 7.62 sur CET AAS, avec une paire SEE/KEY qui correspond !
Je continue mes recherches...
with diagbox is differ story , as depend of the ecu some need tool signature... when wrong can do nothing
what's your car?
Hello. I succeeded in installing 3008 circuch on the car. A 2015 Peugeot 2008 with Griptronic and manual gearbox. I do not have the problem with ESP, switch without problems.
But I have other problems.
1. I can not put the 2008 calibration or configuration because it gives me error 0200 that it can not write a parameter. From what I read can not yet charge .ulp files, but neither the configuration?
If I save the settings, they can be loaded later.
2. I turned off Start & Stop in Cirocco, but when I put the contact, it appears. Is it possible to disable this display? I do not start & stop.
3. The sounds they pull out behind the steering column are no longer the same. I tried to reconfigure them from BSI, but it does not change.
If they give sounds with diagbox they are heard as before. Classical ones do not do with the 2008 setting or how to hear now, are probably 3008 sounds. Can these sounds be set differently?
Thanks for the tips.
I also attached pictures to be more conclusive.
Pièces jointes
    176.5 Ko · Affichages: 69
    216.3 Ko · Affichages: 65
    222.3 Ko · Affichages: 62
    239.8 Ko · Affichages: 65
Reactions: marcins
New 2008 = Visteon
3008 = Magneti Marelli
Calibrations / settings are completely different and incompatible with each other
Reactions: Corin
New face lift
308 digital cluster is also Visteon
this cluster have no extrnal eeprom to read out mileage easy...
1.2.6 publiée
1.2.6 released
bonjour la version 1.2.6 et toujours detecté menace virus ,par Windows defender
Reactions: bbksoft
Hi. Can someone help me set the sound under the steering column to be default not 2008 or 3008? With Arduino because the diagbox changes the setting but not the sound.
Hi, have you mounted the cirocco instrument panel? Did you have the instrument panel with matrix display before?
If you did not have the Matrix display panel and you have mounted cirocco, then you must activate the Matrix display option on the bsi otherwise nac will not be able to change sounds or language to the system
Hi @RuLe , yes i mounted cirocco and i have Matrix Display activated before. I test Brightenss on NAC and cirroco is not changed, themes is changed, music/map displayed. Before mounted cirocco i was using NAC from 3008 with 1 LVDS and brightens on NAC was working. Now with cirroco from 3008 i mount NAC from 5008. I used 2008 calibration and same cfg but change 2 LVSD.
Now can't change brightnes on NAC or corroco. Also the sound from steering well is not changed.
on NAC config
set 2124 disabled
cirocco 2100 -Ambience to Rheostatage
and you can controll from left button on cirocco
Reactions: Laleksss and Corin
