I solved it with Diagbox calibration.J'ai finalement résolu les problèmes de contact et changé l'appareil photo car j'ai réalisé que l'appareil photo que j'avais acheté n'était pas pour mon modèle. Cependant, j'ai toujours l'image agrandie. J'ai une diagbox, mais non officielle. Puis-je calibrer la caméra avec ou dois-je acheter un jeton et installer une diagbox officielle et calibrer avec le VIN d'une autre voiture ? Ma caméra est entraînée en NAC mais pas en BSI....
With an official version of diagbox ?I solved it with Diagbox calibration.
No. Offline version.With an official version of diagbox ?
Interesting! which version did you use?No. Offline version.
RCC A2 is not supporting reversing camera, do you remember which RCC versions are supporting it?
I was fighting with RCC A2 in Proace to get working camera without any luck, after swap to NAC camera start to work without any issue, and i think somebody has confirmed in the past that A2 is not supporting reversing camera but i have problems to find that post.
oh yes, i remember VLuD saying this too. You're right.For panoramic camera you dont have to change BSI config.
*at least with NAC
No they should not be missing so the ECU can be accessible using Diagbox. (and it is probably sending few messages on the network for other ECUs)
Full PINOUT:
10: +12V
16: Ground
17: CAN High
18: CAN Low
6: Output Video - (to the NAC)
15: Output Video + (to the NAC)
11: +12V for Rear camera
14: Ground for Rear Camera
12: Input Video + Rear camera
3: Input Video - Rear Camera
2: +12V for Front camera
5: Ground for Front Camera
4: Input Video - Front Camera
13: Input Video + Front Camera
I had the same problem in my rcc a2. you need to configure the camera in diagbox while in the parking lot next to the parking linesBad config probably. You have to code BSI too.
Here's my result:
Thanks for the info! I'm already planning to buy a diagbox soon and program it properly.I had the same problem in my rcc a2. you need to configure the camera in diagbox while in the parking lot next to the parking lines
Just do what the diagbox displays, it's easy.Thanks for the info! I'm already planning to buy a diagbox soon and program it properly.
I guess it's pretty intuitive, right?
