kit embrayage: 2052 Z1
butée: 2041 A3
bimasse: 0532 W4
FINITION HAUTE MOYENNE PLUS
MOTEUR DIESEL TURBO DV6C
TRANSMISSION BVM PILOTEE 6 RAPPORTS STT
TYPE DE PEINTURE PEINTURE OPAQUE
COULEUR DE CAISSE EWP - PEINTURE BLANC BANQUISE
TYPE D’HABILLAGE INTÉRIEUR MI-CUIR MARSTON "3F"
COULEUR DE GARNISSAGE "FX"
BOITE DE VITESSES (CARACTÉRISTIQUES) BVM MCD
DEFINITION A VENIR GAMME INITIALE
MOTEUR (TYPE) MOTEUR TYPE DV
Caractéristiques véhicule
DIRECTION DIRECTION ASSISTEE
Alimentation moteur
CARBURANT GAZOLE QUALITE DA/DE/DE+
DÉPOLLUTION (MOTEUR) DEPOLLUTION MOTEUR SUPERIEUR L6 EURO 5
ECHAPPEMENT SILENCIEUX AR LONGITUDINAL
CYLINDRÉE 1600 CM3
CATALYSEUR CATALYSEUR INF 10PPM
REFROIDISSEMENT D’HUILE ECHANGEUR SUR MOTEUR ET BV
RÉSERVOIR DE CARBURANT RESERVOIR CARBURANT AVEC DETROMPEUR
VARIATION PUISSANCE (MOTEUR) PUISSANCE MOTEUR 82 KW - 270 NM
AUTODIAGNOSTIC EOBD AUTO-DIAGNOSTIC "EOBD"
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE EURO 5
FILTRE À PARTICULE AVEC FILTRE A PARTICULES
VENTILATEUR 1 VENTILATEUR ELECTRONIQUE BI VIT 140W
VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION SIEMENS
CHAINE DE TRACTION SANS CHAINE TRACTION HYBRIDE
STOP AND START AVEC STOP AND START
COUPLE RAPPORT CP 19 X 77
STYLE ROUE STYLE 05 17 POUCES
EMBRAYAGE SANS EMBRAYAGE
DIFFÉRENTIEL (BOITE) DIFFERENTIEL 84
JANTE / PNEU DIMENSION MONTE PNEU 17 POUCES
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 215/55 R17 94W NON RENFORCE
ROUE (TYPE) MONTAGE ROUE ALLIAGE 2
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE SANS INDICATEUR PERTE PRESSION GONFLAGE
BOITE DE VITESSES TYPE BVM MC
Suspension Direction Freinage
BARRE ANTIDÉVERS ARRIÈRE BARRE ANTI DEVERS AR DIAM 20
ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAM 22,5
SUSPENSION SUSPENSION NORMALE
CONTRÔLE DYNAMIQUE DE STABILITÉ AVEC SYSTEME ESP
VARIANTE ASSOCIÉE FREIN ESP BOSCH 8 1
DIRECTION (FONCTIONNEMENT) DIRECTION ELECTRO HYDRAULIQUE ASSISTEE
Carrosserie Equipements
ENJOLIVEMENT LATÉRAL (ASPECT) SANS PROTECTEURS LATERAUX
ENJOLIVEUR ROUE (STYLE) SANS ENJOLIVEUR DE ROUE
FEU D’ÉCLAIRAGE DE SEUIL FEU ECLAIRAGE DE SEUIL AVANT
ANNEAU D’ARRIMAGE EXTÉRIEUR (RAPPORTÉ) SANS ANNEAU ARRIMAGE EXTERIEUR RAPPORTE
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETRO EXT RABATTABLE ELECTRIQUE SANS MEMOIRE
ESSUIE-VITRE ARRIÈRE SANS ESSUIE-VITRE AR
OBTURATEUR FACE AVANT OBTURATEUR INFERIEUR FACE AV
VITRE VOLET ARRIÈRE VITRE VOLET AR FIXE
PARE-CHOCS PC AV/AR STANDARD COULEUR CAISSE + GRILLE CHROME
PARE-BOUE (BAVETTE) SANS BAVETTES AR
PORTE-BAGAGES MONTAGE SANS PORTE BAGAGES
ROUE DE SECOURS ROUE ALLIAGE + PNEU STANDARD
ACCESSOIRES EXTÉRIEURS POIGNEE EXTERIEURE ET COULISSE ENJOLIVEUR, CHROMES
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) GLACE RETRO EXT BOMBE
TOIT OUVRANT TOIT FIXE
ENJOLIVEMENT PARE-CHOCS P/C AVEC INSERT CHROME
VITRE (ASPECT) VITRE TEINTEE
VITRE (TYPE) P-B FEUILLETE ACCOUSTIQUE + AR TREMPE
ACCÈS ET DÉMARRAGE MAINS LIBRES ACCES ET DEMARRAGE MAINS LIBRES
Equipement intérieur
DETECTION ANGLEMORT SANS SURVEILLANCE ANGLE MORT
ACCOUDOIR ASSISE ARRIÈRE AVEC ACCOUDOIR AR
CEINTURE DE SÉCURITÉ ARRIÈRE CEINT SECU AR 3 ENROULEURS 3 PTS + TEMOIN BOUCLAGE
CLIMAT (TEMPERATURE AMBIANTE) PAYS TEMPERES
CHAUFFAGE ADDITIONNEL SANS CHAUFFAGE ADDITIONNEL
EQUIPEMENT PLANCHE DE BORD DECOR CUBIC MINIMAILLE
FEUX INT. DIVERS LECTEUR CARTE AV + AR A LED
GARNISSAGE VOLUME CHARGEMENT TAPIS COFFRE + COTES MOQUETTE
COMBINÉ (CARACTÉRISTIQUES) GRADUATION 260 KM/H 160 M/H MATRICE MONOCHROME
GARNISSAGE DE PORTE DECOR TISSU
HAUT-PARLEUR 4 HP AV (2 TW + 2 AV) + 4 HP AR
COMMANDE D’AUTORADIO COMMANDE AUTO-RADIO A DISTANCE STANDARD
INSONORISATION HABITACLE INSONO TABLIER 4 KG
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) SANS STORE AR
REHAUSSE ASSISE AVANT PASSAGER REHAUSSE PASSAGER REGLAGE AVANT
COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV MANUEL PASSAGER
RÉGLAGE ASSISE AVANT CONDUCTEUR REGLAGE LOMBAIRE CONDUCTEUR
RÉGLAGE ASSISE AVANT PASSAGER DOSSIER PASSAGER INCLINABLE
SYSTÈME DE NAVIGATION AVEC SYSTEME NAVIGATION ECRAN COULEUR
LAMPES DE PROJECTEURS LAMPE HALOGENE
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR ELECTRIQUE CDE SEQUENTIELLE
LÈVE-VITRE AVANT PASSAGER LEVE-VITRE AV PASSAGER CDE SEQUENTIELLE
AFFICHEUR AFFICHEUR DEV
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
INDICATEUR D’HUILE RECEPTEUR TEMPORISE NIV + TEMP
ECLAIRAGE BAS HABITACLE ECLAIRAGE CAVE A PIEDS COND + PASS AV+AR
PROTECTION PASSAGER ARRIÈRE SANS PROTECTION PASSAGER AR
PROJECTEUR DIRECTIONNEL SANS PROJECTEUR DIRECTIONNEL
RÉCEPTEUR RADIO RADIO TELEPHONE AFFICHAGE DEPORTE ’RT6’
RÉGULATEUR DE VITESSES REGULATEUR ET LIMITEUR VITESSE
REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE MANUEL
RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR-NUIT ELECTROCHROME
RÉGULATION CLIMATISATION / TEMPÉRATURE REFRIGERATION AUTOMATIQUE BI-ZONE
RANGEMENT VOLUME CHARGEMENT SANS FILET DANS COFFRE
TUNER-RADIO TRI TUNER RADIO
DÉTECTION D’OBSTACLE DETECTEUR OBSTACLE RADAR AV AR MDP
STORES LATÉRAUX SANS STORES LATERAUX
ADAPTATION GARNITURE POMMEAU CUIR RETRO ECLAIRE
FRÉQUENCE RADIO FREQUENCE RADIO EUROPE OCCIDENTALE
VOLANT VOLANT CUIR 3 BRAS
SAC GONFLABLE GENOUX CONDUCTEUR SANS SAC GONFLABLE GENOUX CONDUCTEUR
ECRAN VIDÉO ARRIÈRE SANS ECRAN VIDEO AR
PRISE AUXILIAIRE PACK AUDIO 1 PRISE JACK + USB
BOITIER TELEMATIQUE BOITIER TELEMATIQUE AUTONOME
Electricité
ALTERNATEUR ISTT50
BATTERIE L3 760 VRLA1 EN AGM
DÉMARREUR DEMARREUR CLASSE 5
ECLAIREMENT PARTICULIER ALLUMAGE AUTOMATIQUE + FEUX DIURNES AV
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FREQUENCE TELECDE CONDA 433,92 MHZ HETERODYNE
ALLUMAGE FEUX ALLUMAGE FEUX MANUEL
Marques d'équipements
Divers
ATMOSPHÈRE ATMOSPHERE NORMALE
ETIQUETTE SANS ETIQUETTE
PRISE D’ÉCOUTE RADIO PRISE ACCESSOIRES TRIPLE
