Hello, i curently have a problem with my Peugeot 307 2.0hdi 90hp injection type Siemens.
Since 2 days ago i chouldnt start my engine. I used the car all day and with less than 2 km until home the "Fuel level low" message appeared and i thought i will refuel tommorow.
Well at around 10:00 i chouldnt start the engine.
The "temoin du systeme antipollution" was on and fuel lvl low also.
Althought i have around 20l of fuel, i still have the "Fuel level low" msg and the fuel indicator is under the first line. We checked :
1. camshaft sensor
2. fuel rail pressure sensor
3. fuel temperature sensor
4. fuel pressure control solenoid
5. we even checked inside the tank, under the back seat
After a diagnostic, we had the errors:
1. Fuel rail pressure sensor - implausible signal, short circuit on plus
And after some assintance it started with a bit of luck run for about 10 min and we wanted to see if it whould start again and it didnt. Around 20:00 it started again after moving around some wires.
Any 1 know what's wrong ? : Pt1cable:
1. camshaft sensor
