Bonjour, lorsque ma 307 est froide, ma BVA saute et un voyant anomalie apparait au tableau de bord.
Le code de panne qui ressort est P1167.
Le code veut dire :
P1167
This fault code for AL4 is often generated along with P0745. It relates to pressure regulation and is very often caused by hydraulic block failure, usually caused by solenoid swarf. Make sure you have the latest Borg Warner solenoids fitted and software to match. The solenoids are included in the new hydraulic block assembly. Also be aware that the pressure sensor may be at fault. Unfortunately this does not mean the gearbox as a whole is not faulty, as the swarf damage very often causes the box to fail internally or the brake bands and gear bearings also wear and cause contamination. Depending on age and mileage etc. it maybe prudent to just opt for a new gearbox, especially if coupled with 'slip' faults.
Si j'éteins et rallume la voiture, tout disparait et je suis de nouveau tranquille pour la journée.
Que faut-il faire ? Une vidange de la BVA pourrait être utile ?
D'avance merci.
Le code veut dire :
P1167
D'avance merci.
