@ever89
308 (T9) BERLINE 5PTES 2.0 HDi 150 FAP (DW10FD) BVM 6 RAPPORTS TYPE STT
Caractéristiques du véhicule
Ligne de produit 308 (T9)
N°APV/PR 13687 89 1 0427
NRE e2*2007/46*0405*02
Informations générales
LIGNE DE PRODUIT 308 (T9)
SILHOUETTE BERLINE 5PTES
FINITION ALLURE
MOTEUR DIESEL DW10FD FAP 110KW
TRANSMISSION BVM 6 RAPPORTS TYPE STT
TYPE DE PEINTURE PEINTURE METALLISEE VERNIS
COULEUR DE CAISSE KTV - PEINTURE NOIR PERLA NERA
TYPE D’HABILLAGE INTÉRIEUR TISSU MARSTON "1T"
COULEUR DE GARNISSAGE "FX"
BOITE DE VITESSES (CARACTÉRISTIQUES) BVM ML6 CL
MOTEUR (TYPE) MOTEUR TYPE EW/DW
MONOGRAMME COMPLÉMENTAIRE, DIVERS BLUE HDI
Caractéristiques véhicule
FINITION ALLURE
COUPLE TACHYMÈTRE SANS COUPLE TACHYMETRE
Alimentation moteur
ALIMENTATION INJECTION TURBO ECHANGEUR DIRECT
CARBURANT GAZOLE QUALITE DA/DE/DE+
DÉPOLLUTION (MOTEUR) DEPOLLUTION EURO 6(MOTEUR)
CYLINDRÉE 2000 CM3
CATALYSEUR CATALYSEUR SUP 50PPM
RÉSERVOIR DE CARBURANT RESERVOIR CARBURANT AVEC DETROMPEUR
MOTEUR REFROIDISSEMENT RADIATEUR 28DM2 EP: 28 ALU BRASE
RÉCHAUFFAGE CIRCUIT GAZ CARTER AVEC RECHAUFFAGE CIRCUIT GAZ CARTER
SONORITE GMP SPECIFIQUE DYNAMIQUE
AUTODIAGNOSTIC EOBD AUTO-DIAGNOSTIC "EOBD"
DISPOSITIF (ANTIPOLLUTION) RECIRCULATION GAZ ECHAPPEMENT "EGR" + ECHANGEUR
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE EURO6
FILTRE À PARTICULE AVEC FILTRE PARTICULE
VENTILATEUR 1 VENTILATEUR 2 VITESSES 140W AERO VOLET DYNAMIQUE
VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION DELPHI
CHAINE DE TRACTION HYBRIDE SANS CHAINE TRACTION HYBRIDE
STOP AND START AVEC STOP AND START ALTERNO DEMARREUR
COUPLE RAPPORT CP 19 X 70
STYLE ROUE JANTE RUBIS 17"
JANTE / PNEU DIMENSION MONTE PNEU 17 POUCES
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 225/45 R17 91V NON RENFORCE
ROUES MOTRICES 2 ROUES MOTRICES
ROUE (TYPE) MONTAGE ROUE ALLIAGE 1
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE DETECTION SOUS GONFLAGE INDIRECT AVEC LOCALISATION
BOITE DE VITESSES TYPE ML6C
Suspension Direction Freinage
BARRE ANTIDÉVERS ARRIÈRE RAIDEUR 26000 NM/RAD
ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAMETRE 21 CREUSE
FREIN TYPE DISQUES AV VENTILES/DISQUES AR
SUSPENSION SUSPENSION NORMALE
SUSPENSION (TYPE ARCHITECTURE) SUSPENSION METALLIQUE
CONTRÔLE DYNAMIQUE DE STABILITÉ AVEC SYSTEME ESP
DIRECTION (FONCTIONNEMENT) DIRECTION ELECTRIQUE ASSISTEE
PÉDALIER (TYPE) PEDALIER STANDARD SIMPLE
Carrosserie Equipements
ANTENNE ANTENNE PAVILLON COURTE + INTEGREE
ENJOLIVEMENT LATÉRAL (DIMENSION) SANS PROTECTEURS LATERAUX
ENJOLIVEUR ROUE (STYLE) SANS ENJOLIVEUR DE ROUE
PROTECTION SOUS CAISSE SANS PROTECTION SOUS CAISSE
FEU DE RECUL AVEC 2 FEUX DE RECUL
ANNEAU D’ARRIMAGE EXTÉRIEUR (RAPPORTÉ) SANS ANNEAU ARRIMAGE EXTERIEUR RAPPORTE
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVISEUR EXTERIEUR RABATTABLE ELECTRIQUE+DIODE
PARE-BOUE PARE-BOUE STANDARD AVEC MOUSSE AV
INSONORISATION COTÉ MOTEUR INSONO TABLIER + CAPOT + PASS ROUE + GMP AC
VITRE PARE-BRISE (GENRE) VITRE PARE BRISE STANDARD
ESSUIE-VITRE ARRIÈRE AVEC ESSUIE-VITRE AR
VITRE PAVILLON AVEC VITRE PAVILLON FIXE
PARE-CHOCS PARE-CHOCS AV CC + JONC CHROME ET PC AR CC
PARE-BOUE (BAVETTE) AVEC PARE BOUE AV
PLAQUE POLICE SANS PLAQUE POLICE
PORTE-BAGAGES MONTAGE SANS BARRES DE TOIT LONGITUDINALES
ROUE DE SECOURS AVEC ROUE SECOURS ROUE ALLIAGE + PNEU STANDARD
ACCESSOIRES EXTÉRIEURS POIGNEE EXTERIEUR COULEUR CAISSE
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) GLACE RETRO EXT BOMBE
VITRE (ASPECT) VITRE TEINTEE AV/AR+ SURTEINTEE VOLET
VITRE (TYPE) PARE-BRISE FEUILLETE ACCOUSTIQUE + VITRE AR TREMPE
ACCÈS ET DÉMARRAGE MAINS LIBRES SANS ACCES/DEMARRAGE MAINS LIBRES
Equipement intérieur
ALLUME-CIGARE SANS ALLUME CIGARE
DETECTION ANGLEMORT SANS SURVEILLANCE ANGLE MORT
ACCOUDOIR ASSISE ARRIÈRE AVEC ACCOUDOIR AR
ARRIMAGE INTÉRIEUR AVEC ARRIMAGE INTERIEUR
CACHE-BAGAGES TABLETTE
CEINTURE DE SÉCURITÉ ARRIÈRE CEINT SECU AR 3 ENROULEURS 3 PTS + TEMOIN BOUCLAGE
CEINTURE DE SÉCURITÉ AVANT ENROULEUR ALARME BOUCLAGE CONDUCTEUR + PASSAGER
CENDRIER SANS CENDRIER
CLIMAT (TEMPÉRATURE AMBIANTE) PAYS FROIDS
COMMANDE DE VITESSES COMMANDE VITESSE AU PLANCHER
CHAUFFAGE ADDITIONNEL SANS CHAUFFAGE ADDITIONNEL
VARIATION D’HABILLAGE D’ÉQUIPEMENT INTÉRIEUR SANS PRISE ACCESSOIRES
FEUX INT. DIVERS LC AV/AR A LEDS SANS LED AMB AVEC ECL AMB
GARNISSAGE VOLUME CHARGEMENT TAPIS + FOND + COTES MOQUETTE
COMBINÉ (CARACTÉRISTIQUES) COMBINE AVEC MATRICE
GARNISSAGE DE PORTE GARNISSAGE PORTE DECOR CHROME SATIN
ANCRAGE SIÈGE ENFANT SANS ANCRAGE SIEGES ENFANTS AVEC ISO AR
HAUT-PARLEUR 4 HAUT PARLEUR AV (2 TW + 2 AV)+2 HAUT PARLEUR AR
COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE
INSONORISATION HABITACLE INSONORISATION (HABITACLE)TABLIER 2,8 KG
REHAUSSE ASSISE AVANT PASSAGER REHAUSSE PASSAGER REGLAGE PARALLELE+AV
RÉGLAGE ASSISE AVANT CONDUCTEUR REGLAGE LOMBAIRE CONDUCTEUR MANUEL
RÉGLAGE ASSISE AVANT PASSAGER DOSSIER PASSAGER INCLINABLE
ACCOUDOIR ASSISE AVANT ACCOUDOIR CENTRAL
COMPACT DISQUE MONTAGE COMPACT DISQUES
SYSTÈME DE NAVIGATION NAVIGATION 2 ECRANS COULEUR
LAMPES DE PROJECTEURS LAMPE A LED
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR ELECTRIQUE CDE SEQUENTIELLE
AFFICHEUR ECRAN DIGITAL TACTILE
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
INDICATEUR D’HUILE INDICATEUR NIVEAU HUILE
MONTAGE APPUI-TÊTE ARRIÈRE MONTAGE 3 APPUI-TETE AR
ECLAIRAGE BAS HABITACLE ECLAIRAGE CAVE A PIEDS COND + PASS AV
PROTECTION PASSAGER ARRIÈRE SANS PROTECTION PASSAGER AR
NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION AIRBAG MANUELLE
PLANCHER ARRIÈRE CHARGE SANS PLANCHER AR CHARGE
PROJECTEUR CORRECTEUR ASSIETTE REGLAGE AUTOMATIQUE PROJECTEURS
PARE-SOLEIL AVANT COTE CONDUCTEUR+PASSAGER AVEC PORTE CARTE+INSCRIP
RÉCEPTEUR RADIO RECEPTEUR RADIO SMEG ANALOGIQUE
RÉGULATEUR DE VITESSES REGULATEUR ET LIMITEUR VITESSE PROGRAMMABLE
REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE PARALLELE+AV
RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR-NUIT ELECTROCHROME
RANGEMENT VOLUME CHARGEMENT SANGLE GARNITURE LATERALE COFFRE
TUNER-RADIO BI TUNER RADIO
TÉMOIN DE NIVEAU DE LIQUIDE DE REFROIDISSEMENT SANS TEMOIN NIVEAU LIQUIDE REFROIDISSEMENT
DÉTECTION D’OBSTACLE DETECTEUR OBSTACLE RADAR AVANT + ARRIERE
STORES LATÉRAUX SANS STORES LATERAUX
SURTAPIS SANS SURTAPIS
COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION + AUTOMATIQUE
VOLANT VOLANT CUIR PLEINE FLEUR
VARIANTE ASSOCIÉE ASSISE BASSE
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) MAINTIEN LOMBAIRE MANUEL
PRISE AUXILIAIRE PACK AUDIO 1 PRISE JACK + 2 USB
Electricité
ALTERNATEUR ALTERNATEUR ISTT52
BATTERIE BATTERIE L3 760 VRLA2 EN AGM
DÉMARREUR DEMARREUR CLASSE 6+
ECLAIREMENT PARTICULIER FEUX DIURNE AV
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FREQUENCE TELECDE CONDA 433,92 MHZ HETERODYNE
MULTIPLEXAGE ARCHITECTURE ELECTRIQUE FULL
FRÉQUENCE RADIO FREQUENCE RADIO EUROPE OCCIDENTALE
ALLUMAGE FEUX ALLUMAGE FEUX AUTOMATIQUE
BOITIER TELEMATIQUE BOITIER TELEMATIQUE AUTONOM
Marques d'équipements
Divers
ATMOSPHÈRE ATMOSPHERE NORMALE
PLAQUE CONSTRUCTEUR PLAQUE CONSTRUCTION UNION EUROPEENNE + NRE
ETIQUETTE SANS ETIQUETTE
PRISE D’ÉCOUTE RADIO PRISE ACCESSOIRES AV + AR 12V
JEUX DE CLÉS 1 CLE PLIP HAUTE FREQUENCE+1 CLE PRINCIPALE UNIQUE
JOINT ANTISALISSURE JOINT ANTI-SALISSURES AMELIORE + AV PORTE AV
LIQUIDE RÉFRIGÉRANT LIQUIDE REFRIGERANT 1234 YF
ROULAGE BONNE ROUTE
voilà
