Suite et fin
Equipement intérieur
TYPE D’HABILLAGE INTÉRIEUR VELOURS SUMMER + POINTIL "RO"
ASSISE ARRIÈRE BANQUETTE AR COUSSIN MONOBLOC DOSSIERS SEPARES
ACCOUDOIR ASSISE ARRIÈRE AVEC ACCOUDOIR AR
BAGUETTE PLANCHER DE CHARGE SANS BAGUETTE PLANCHER CHARGE
RADIO-TÉLÉPHONE SANS PRE-EQUIPEMENT TELEPHONE
CACHE-BAGAGES SANS CACHE BAGAGES
CEINTURE DE SÉCURITÉ AVANT CEINTURE PYROTECHNIQUE SANS ALARME
CLIMAT (TEMPERATURE AMBIANTE) PAYS TEMPERES
CLIMATISEUR AVEC AEROTHERME CDES ASSISTEES
CONSOLE CONSOLE LONGUE (VIDE-POCHE RAPPORTE)
EQUIPEMENT PLANCHE DE BORD PL/BORD GD VOLET V/P ENJOLIVEUR FACON RONCE NOYER
ANTIPARASITAGE ANTIPARASITAGE
FEUX INT. DIVERS LECTEUR DE CARTE
GARNISSAGE VOLUME CHARGEMENT GARNISSAGE COFFRE + VOLET AR
COMBINÉ (CARACTÉRISTIQUES) AVEC BORD DE CADRANS CHROMES
GARNISSAGE DE PORTE DECOR FACON RONCE DE NOYER
ANCRAGE SIÈGE ENFANT SANS ANCRAGE SIEGES ENFANTS
HAUT-PARLEUR MONTAGE 4 HP + 2 TWEETERS
FILTRE À POLLEN AVEC FILTRE A POLLEN
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) SANS RIDEAU PARE-SOLEIL
COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV MANUEL PASSAGER
RÉGLAGE ASSISE AVANT CONDUCTEUR DOSSIER CONDUCTEUR INCLINABLE
RÉGLAGE ASSISE AVANT PASSAGER DOSSIER PASSAGER INCLINABLE
ACCOUDOIR ASSISE AVANT MONTAGE SANS ACCOUDOIR AVANT
TÉMOIN DE FREIN DE PARKING SANS TEMOIN FREIN PARKING
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR CDE ELECTRIQUE
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE SANS ECLAIRAGE
INDICATEUR D’HUILE RECEPTEUR TEMPORISE NIV + TEMP
SAC GONFLABLE LATÉRAL AVANT SAC GONFLABLE LATERAL AV DOUBLE
LÈVE-VITRE ÉLECTRIQUE (FONCTIONNEMENT) ANTI PINCEMENT CONDUCTEUR
GRILLE HAUT-PARLEUR (COMPARTIMENT ARRIÈRE) AVEC GRILLE HP TABLETTE AR
COMMANDE INTÉRIEURE DE PORTE (ASPECT) COMMANDE INTERIEURE PORTE ASPECT CHROME
PLAFONNIER CDE PTES AV+AR PLAFONNIER AV+AR
PARE-SOLEIL AVANT COTE CONDUCTEUR+PASSAGER SANS INSCRIPTION
RÉCEPTEUR RADIO SYSTEME AUDIO COMPACT DISC RDS "RD3"
RÉFRIGÉRATION REFRIGERATION
RÉGULATEUR DE VITESSES REGULATION VITESSE
RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR - NUIT
RÉGULATION CLIMATISATION / TEMPÉRATURE AVEC REGULATION CLIMAT /TEMP
RANGEMENT (AUTRES) SANS AUTRES RANGEMENTS
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) GLACE RETRO EXT CONDUCTEUR ASPHERIQUE
PROTECTION INTÉRIEURE SANS PROTECTION INTERIEURE
CONTACT TRANSPONDEUR
TÉMOIN DE NIVEAU DE LIQUIDE DE REFROIDISSEMENT TEMOIN NIVEAU LIQUIDE REFROIDISSEMENT
ADAPTATION GARNITURE POMMEAU LEVIER VITESSE STANDARD
SURTAPIS SANS SURTAPIS
VITRE (TYPE) PARE-BRISE ATHERMIQUE
VOLANT VOLANT MOUSSE 4 BRANCHES
VENTILATEUR 1 VENTILATEUR 350W AVEC HACHEUR
Electricité
BATTERIE BATTERIE L2 400
DÉMARREUR DEMARREUR CLASSE 5
FEU D’ÉCLAIRAGE DE SEUIL SANS FEU ECLAIRAGE DE SEUIL
MULTIPLEXAGE MONTAGE MULTIPLEXE
Marques d'équipements
Divers
ATMOSPHÈRE ATMOSPHERE NORMALE
BOITE DE PREMIERS SECOURS SANS BOITE PREMIER SECOURS
ADAPTATION PAYS SANS ADAPTATION PAYS
ROULAGE BONNE ROUTE
ACCESSOIRES EXTÉRIEURS RETRO EXT ET POIGNEES EXT COULEUR CAISSE
