Dans les tréfonds du NAC
VLud
Lion de Bronze
19 Janvier 2018
1 885
1 029
113
France
Topic dédié aux curieux, j'ai pu lister quasiment toutes les options de la base de données interne (SQLite) du NAC, j'y met aussi les paramètres attribués à une 308 (certains en binaire, d'autres en hexadécimal):
Format (si non spécifié, c'est en binaire):
NOM: VALEUR CONVERTIE (VALEUR RAW)
CDC: 0 (0)
T_EXT: 1 (1)
AAS: 1 (01)
COUNTRY: 0 (000)
OPTION_BLUETOOTH: 1 (1)
ENT_AUDIO: 0 (0)
ANTENNE_1: 1 (1)
ANTENNE_2: 1 (1)
NB_SATELLITES_FLAG: 3 (0011)
RADAR: 1 (1)
BT: 1 (1)
ATT_DG_RADIO_NUM: 3 (11)
ATT_DG_USB: 1 (1)
ATT_DG_JDA: 1 (1)
ATT_DG_RAD_SEUIL (BIN?): 0 (00)
ATT_DG_RAD_NUM_SEUIL (HEX): 80 (50)
ATT_DG_VITESSE_LIMIT: 1 (1)
ATT_DG_HIFI: 3 (011)
ATT_DG_SID (HEX): 58 (3A)
ATT_DG_INTERNET: 1 (1)
AM: 1 (1)
FADER: 1 (1)
NB_ANTENNE: 0 (0)
ATT_DG_TYPE_CLIM: 3 (011)
ATT_DG_TYPE_DIST: 0 (0)
ATT_DG_PRES_AC_MAX: 0 (0)
ATT_DG_CHX_CAL_ECRAN (HEX): 3 (3)
ATT_DG_ECRAN_SECOND: 0 (00)
ENERGY_SAVER_PUSH: 0 (0)
AIRFLOW_BY_LEVEL: 0 (0)
TEMP_ADJUST: 1 (1)
AIRFLOW_DIR_ADJUST: 1 (1)
CLIM_AUTO: 1 (1)
AIRFLOW_BY_INC: 1 (1)
SMARTAPPS: 1 (1)
DG_EXP_NAV_JVRP16: 0 (0)
ATT_DG_HY_PRESENT: 0 (0)
DAT_DG_ACV_PUSH_LED: 0 (0)
DAT_DG_CHECK_PUSH: 1 (1)
DAT_DG_WELCOMEPAGE_C: 1 (1)
DG_SAM_PUSH_POS: 6 (00110)
DG_CPAS_PUSH_POS: 0 (00000)
DG_ARTIV_PUSH_POS: 8 (01000)
DG_AFIL_PUSH_POS: 0 (00000)
DG_LKA_PUSH_POS: 0 (00000)
DG_AAS_PUSH_POS: 3 (00011)
DG_PVC_PUSH_POS: 0 (00000)
DG_CAFR_PUSH_POS: 2 (00010)
DG_MPD_PUSH_LED_POS: 0 (00000)
DG_STT_PUSH_LED_POS: 0 (00000)
DG_SAM_PUSH_PANEL: 0 (0)
DG_CPAS_PUSH_PANEL: 0 (0)
DG_DGSI_PUSH_PANEL: 0 (0)
DG_ARTIV_PUSH_PANEL: 0 (0)
DG_AFIL_PUSH_PANEL_0000: 0 (0)
DG_LKA_PUSH_PANEL: 0 (0)
DG_AAS_PUSH_PANEL: 0 (0)
DG_PVC_PUSH_PANEL: 0 (0)
DG_CAFR_PUSH_PANEL: 0 (0)
ATT_DG_EXP_NAV_ILV: 1 (1)
DAT_DG_LKA_PUSH_LED: 0 (0)
DAT_DG_UREA: 0 (0)
DAT_DG_TYRES_PRES: 1 (1)
DAT_DG_DRIVE_IVTRA: 0 (0)
DAT_DG_DRIVE_ICC_SET: 0 (0)
DAT_DG_DRIVE_ASRPLUS: 0 (0)
DAT_DG_LUM_MANAG: 1 (1)
DAT_DG_ALARM_HISTORY: 1 (1)
DAT_DG_ALARM: 0 (0)
DAT_DG_LANGUAGE: 0 (000000)
OPTION_SD_MEDIA_EVO: 0 (0)
DAT_DG_HY_BAT_LEVEL9: 100 (01100100)
DG_MPD_PUSH_PANEL: 1 (1)
DG_STT_PUSH_PANEL: 0 (0)
DG_ACV_PUSH_POS: 0 (00000)
DG_DGSI_PUSH_POS: 7 (00111)
DG_HY_BAT_HYST_DOWN: 2 (10)
DG_ACV_PUSH_PANEL: 0 (0)
DAT_DG_HY_BAT_LEVEL0: 0 (00000000)
DAT_DG_ARTIV_PUSHES: 0 (00)
DAT_DG_HY_BAT_LEVEL8: 95 (01011111)
DAT_DG_HY_BAT_LEVEL7: 83 (01010011)
DAT_DG_HY_BAT_LEVEL6: 70 (01000110)
DAT_DG_HY_BAT_LEVEL5: 57 (00111001)
DAT_DG_HY_BAT_LEVEL4: 44 (00101100)
DAT_DG_HY_BAT_LEVEL3: 31 (00011111)
DAT_DG_HY_BAT_LEVEL2: 18 (00010010)
DAT_DG_HY_BAT_LEVEL1: 5 (00000101)
DG_HY_BAT_HYST_UP: 2 (10)
CPUSH_DOMELIGHT: 0 (0)
INIT_DSGI: 1 (1)
CURRENT_PROFILE: 0 (0000)
UNITS_LANGUAGE: 1 (1)
XVV_MAX: 180 (10110100)
XVV_MIN: 40 (00101000)
MENU_AMBIANCE_8: 0 (0)
MENU_AMBIANCE_7: 0 (0)
MENU_AMBIANCE_6: 0 (0)
MENU_AMBIANCE_5: 0 (0)
MENU_AMBIANCE_4: 0 (0)
MENU_AMBIANCE_3: 1 (1)
MENU_AMBIANCE_2: 1 (1)
MENU_AMBIANCE_1: 1 (1)
FAMILY_NAME_1: 3 (011)
FAMILY_NAME_2: 2 (010)
FAMILY_NAME_3: 6 (110)
FAMILY_NAME_4: 1 (001)
NOM_ITEM4_FAMILLE__4: 24 (00011000)
NOM_ITEM3_FAMILLE__4: 28 (00011100)
REAR_VC: 0 (0)
CONF_DOP: 1 (1)
SEAT_NB: 0 (0)
CPUSH_ALARMLOG: 0 (0)
CPUSH_BLACK_PANEL: 0 (0)
CPUSH_COLORCLUST: 0 (0)
CPUSH_CHECK: 0 (0)
NOM_ITEM1_FAMILLE__1: 3 (00000011)
NOM_ITEM2_FAMILLE__1: 15 (00001111)
NOM_ITEM3_FAMILLE__1: 0 (00000000)
SOUNDHARMONY: 1 (1)
VEHICLE: 1 (1)
AMBIANCE_DEFAULT: 3 (011)
LVV_MAX: 180 (10110100)
LVV_MIN: 40 (00101000)
RVV_MAX: 180 (10110100)
RVV_MIN: 40 (00101000)
DATE_TIME_DISP: 1 (1)
DATE_TIME_MENU: 1 (1)
DATE_TIME_ZONE: 52 (00110100)
DATE_FORMAT_INIT: 0 (00)
NOT_DATE: 0 (00)
CONF_RVVI: 0 (0)
RLVV_MEMORIZATION: 0 (0)
RLVV_SELECTION: 0 (0)
ICE_WARNING_TEMP: 86 (01010110)
NOM_ITEM2_FAMILLE__4: 0 (00000000)
NOM_ITEM1_FAMILLE__4: 0 (00000000)
NOM_ITEM1_FAMILLE__3: 6 (00000110)
NOM_ITEM2_FAMILLE__3: 0 (00000000)
NOM_ITEM3_FAMILLE__3: 0 (00000000)
NOM_ITEM4_FAMILLE__3: 0 (00000000)
NOM_ITEM4_FAMILLE__2: 0 (00000000)
NOM_ITEM3_FAMILLE__2: 0 (00000000)
NOM_ITEM2_FAMILLE__2: 9 (00001001)
NOM_ITEM1_FAMILLE__2: 7 (00000111)
XVV_DMD: 1 (1)
DATE_TIME_SYNC: 1 (1)
DATE_TIME_SYNC_INIT: 1 (1)
DATE_TIME_ZONE_INIT: 52 (00110100)
ENGINEERING_MODE: 1 (1)
NB_MICRO: 0 (0)
CONNECT_WIFI_CLI: 1 (1)
CONNECT_WIFI_AP: 1 (1)
HY_HISTO_PRESENT: 0 (0)
DISPLAY_RISK_ALERT: 1 (1)
EXPORT_TUNER: 1 (01)
SELECT_CARTO_NAV: 0 (00000000)
RVC_LEGAL: 0 (0)
RVC_REF: 0 (0)
OBC_PERMANENTPAGE: 1 (1)
PVC_PUSH: 0 (0)
PVC_MENU: 1 (1)
ODO_PARTIAL: 1 (1)
OBC: 1 (1)
OBC_STT: 1 (1)
OBC_POPUPPAGE: 0 (0)
OBC_PUSH: 0 (0)
AAS_PUSH_LED: 1 (1)
PVC_LEGAL: 1 (1)
PVC_TYPE: 1 (01)
OBC_PAGE: 0 (00)
MAINTENANCE: 0 (0)
CLIM_PRECOND: 0 (0)
HW_WIFI: 1 (1)
DIAG_ML_ON_OFF: 1 (1)
CMD_TYP: 3 (0011)
DG_GREEN_CRITERIA: 0 (0)
CLIM_ACTIVATION: 1 (1)
SPEED_SVR: 254 (11111110)
PRECOND_PUSH_LED: 0 (0)
PRECOND_PUSH_PANEL: 0 (0)
PRECOND_PUSH_POS: 0 (00000)
LVDS_SPEED: 1 (1)
LVDS_BWS_CONFIG: 1 (1)
NOM_ITEM10_FAMILLE_4: 0 (00000000)
NOM_ITEM9_FAMILLE_4: 0 (00000000)
NOM_ITEM8_FAMILLE_4: 0 (00000000)
NOM_ITEM7_FAMILLE_4: 0 (00000000)
NOM_ITEM6_FAMILLE_4: 0 (00000000)
NOM_ITEM5_FAMILLE_4: 0 (00000000)
NOM_ITEM10_FAMILLE_3: 0 (00000000)
NOM_ITEM9_FAMILLE_3: 0 (00000000)
NOM_ITEM8_FAMILLE_3: 0 (00000000)
NOM_ITEM10_FAMILLE_2: 0 (00000000)
NOM_ITEM9_FAMILLE_2: 0 (00000000)
NOM_ITEM8_FAMILLE_2: 0 (00000000)
NOM_ITEM7_FAMILLE_2: 0 (00000000)
NOM_ITEM6_FAMILLE_2: 0 (00000000)
NOM_ITEM4_FAMILLE__1: 0 (00000000)
OPTION_COLORATION_MO: 1 (1)
TYPE_COLOR_MOTEUR: 1 (1)
DIPO_ON_OFF: 1 (1)
PARAM_EFF_COLOR_MOTE: 1 (01)
NOM_ITEM5_FAMILLE_2: 0 (00000000)
NOM_ITEM10_FAMILLE_1: 0 (00000000)
NOM_ITEM9_FAMILLE_1: 0 (00000000)
NOM_ITEM8_FAMILLE_1: 0 (00000000)
NOM_ITEM7_FAMILLE_1: 0 (00000000)
NOM_ITEM6_FAMILLE_1: 0 (00000000)
NOM_ITEM5_FAMILLE_1: 0 (00000000)
NOM_ITEM5_FAMILLE_3: 0 (00000000)
NOM_ITEM6_FAMILLE_3: 0 (00000000)
NOM_ITEM7_FAMILLE_3: 0 (00000000)
ATT_DG_CONF_INTERNET: 1 (01)
TYPE_ENERGIE: 0 (0000)
ATT_DG_USB_2ND: 0 (0)
ATT_DG_CAFR_PUSH: 1 (1)
ATT_DG_ARTIV_PUSH: 0 (0)
ATT_DG_AFIL_PUSH: 0 (0)
ATT_DG_MPD_PUSH: 0 (0)
ATT_DG_SAM_PUSH: 0 (0)
ATT_DG_CITYPARK_PUSH: 0 (0)
ATT_DG_STT_PUSH: 0 (0)
ATT_DG_PRES_RECYCL: 1 (1)
ATT_DG_PRES_CLIM_AR: 0 (0)
ATT_DG_EXP_NAV_CSR: 0 (0)
ATT_DG_EXP_NAV_CAR: 1 (1)
ATT_DG_EXP_NAV_JVAR: 1 (1)
ATT_DG_PRES_TYPAGE: 1 (1)
ATT_DG_PRES_AQS: 0 (0)
ATT_DG_TYPE_MIX: 1 (1)
REAR_SIDE_HOR_ENL_RA (HEX): 100 (64)
REAR_SIDE_ENL_ORIGIN: 0 (00)
REAR_SIDE_VER_ENL_RA (HEX): 100 (64)
REAR_STD_HOR_ENL_RAT (HEX): 100 (64)
DYNAMIC_MODE: 1 (1)
REAR_STD_VERT_ENL_OR: 0 (00)
REAR_STD_VERT_ENL_RA (HEX): 100 (64)
TRAILER_HOOK_HEIGHT (HEX): 506 (01FA)
TRAILER_HOOK_LENGTH (HEX): 99 (0063)
REAR_REAL_TOP_VIEW_H (HEX): 2050 (0802)
OPTION_IDVR: 0 (0)
ICALL_VHL_SPEAKER: 1 (1)
MOOD_GRID: 0 (0)
CLIM_MONO: 2 (10)
BCALL_VHL_SPEAKER: 1 (1)
AAP_ON_OFF: 1 (1)
AUDIO_PRESET_LIVE: 1 (1)
VIDEO_CODING_1: 0 (0)
VIDEO_CODING_2: 1 (1)
IDVR_LDW_PUSH_LED: 0 (0)
IDVR_LDW_PSH_LED_PNE: 0 (0)
IDVR_FCW_PUSH_LED_PN: 0 (0)
IDVR_FCW_PUSH_LED_PO: 0 (00000)
IDVR_LDW_PUSH_LED_PO: 0 (00000)
CONF_WEB_PORTAL: 1 (1)
PERSO: 0 (0)
IDVR_FCW_PUSH_LED: 0 (0)
LOI_DX: 1 (01)
TYPE_EXPORT_VIDEO: 0 (00)
EXPORT_INFO_TRAFFIC: 1 (1)
ACQ_IHM_COLOR: 0 (0)
XVV_STOPADJUST: 0 (0)
RVV_RVVI_PUSH_LED: 0 (0)
CLIM_RECALL_INFO: 1 (1)
OPTION_WIFI: 1 (1)
DAT_DG_CARLINE: 14 (1110)
DY_PARAMETER_1 (HEX): 128 (80)
DY_PARAMETER_2 (HEX): 40 (28)
RDS_FOLLOW_UP: 1 (1)
REAR_CAMERA_YAW (HEX): 1800 (0708)
REAR_CAMERA_PITCH (HEX): 487 (01E7)
REAR_CAMERA_ROLL (HEX): 1800 (0708)
REAR_CAMERA_Z (HEX): 800 (0320)
REAR_CAMERA_Y (HEX): 3059 (0BF3)
REAR_CAMERA_X (HEX): 3828 (0EF4)
RVV_RVVI_PUSH_LED_PA: 0 (0)
RVV_RVVI_PUSH_LED_PO: 0 (00000)
ATT_DG_AVC: 1 (1)
TRAJECTORY_LIN_REA_W (HEX): 6 (06)
DIST_LINE_REAR_WID_2 (HEX): 2 (02)
DIST_LINE_REAR_WID_1 (HEX): 4 (04)
REAR_BUMPER_EDGE_HEI (HEX): 598 (0256)
WHEELBASE (HEX): 1620 (0654)
REAR_OVERHANG (HEX): 620 (026C)
FRONT_OVERHANG (HEX): 712 (02C8)
DOORS_TYPE: 0 (00)
VEHICLE_WIDTH (HEX): 543 (021F)
DIST_LINE_REAR_W_03 (HEX): 8 (08)
OPTION_EXPORT_MEDIA: 1 (1)
TYPE_EXPORT_MEDIA: 0 (00)
AMPLI_SURRND_BY_CDC: 0 (0)
ASR_PUSH_LED_PANEL: 0 (0)
ASR_PUSH_LED_POS: 4 (00100)
ASR_PUSH_LED: 0 (0)
CLIM_OFF_BUTTON: 0 (0)
PRESENCE_AAS_ADJUST: 0 (0)
OPT_REMOTE_MNGT_VHL: 0 (0)
TYPE_EXP_MEDIA_CAN: 0 (00)
PANORAMIC_VC: 1 (1)
CLIM_IONISOR_CFGS: 0 (0)
CLIM_STATUSLINE: 1 (1)
BEIDOU_GPS_CHOICE: 0 (0)
CENTRAL_SPK_SETTING: 0 (0)
ODS_TYPE: 0 (00)
Il y a pas mal d'options cachés qu'on ne voit pas du tout sur Diagbox, j'ai eu l'occasion d'activer tous les thèmes (MENU_AMBIANCE_X) dont certains que je n'ai jamais vu, par exemple le thème Red mais avec les écritures et rebord en rouge au lieu de gris habituellement (d'ailleurs les thèmes n'ont même pas de nom :lol:) :
Ceux qui ont pu connaitre les modifications de la base sur RT6 et SMEG reconnaîtront bon nombre de paramètres qui n'ont pas changé de nom depuis le temps :)
Il y a certains paramètres qui m'intriguent (par ex OPTION_IDVR, PERSO, etc), je vous en dirais plus dès que j'aurai essayé :sarcastic:
Si j'ai le temps j’essaierai de documenter les paramètres :chinois: Même si pour le moment, faute de technique facile pour modifier la base en question c'est purement informatif pour le commun des mortels, peut-être qu'un jour ... :D
Au top VLUD, le fichier de paramètres cachés dont on rêvait tous ;)
Reste à trouver le programme (DiagBox pirate ?) qui permettra de les charger ;)
The connection with NAC is still telnet like smeg or is ssh? I don't see any port open on wifi or BT, but i see allocated ip
Reactions: Russian guy
Très intéressant: comment fais tu pour pousser une conf sur le NAC ?
L'option ATT_DG_RADIO_NUM: 3 (11) permet-elle d'activer le DAB ? (je me demande si l'option RNT est juste logicielle ou s'il faut aussi un peu de hardware)
Moi aussi, j'aimerai bien savoir comment notre ami VLUD a pu accédé à ces données.
Peut-on le hacker pour rajouter nos propres applies ?
L'idée serait dans un premier temps d'améliorer l'interface (en mode navigation, je me fous un peu de la station radio, j'aimerai plutot avoir le titre du morceau envoyé par RDS).
tell me how to access the NAC setup or help me. Press the button to calibrate the camera round-trip view, display the button CHEK, clock.
Vlud, bon après-midi. Aide s'il vous plaît. Connectez-vous à distance à mon NAC :) Vous devez activer l'horloge à l'écran, modifier la silhouette de la machine et afficher le bouton CHEK.
Pièces jointes
    299.3 Ko · Affichages: 249
Salut comment tu vas rentrer dans les paramètres caché du nac??
Sur le Smeg +, il fallait appuyer simultanément sur les touches ( si je me rappelle bien ) un deux trois
VLud or Mitch1234. Comment obtenir cet accès à la base de données (SQLite) pour NAC? Dites-moi un moyen.
Hello,
At first I want to apologize not to write in french.
I could use Google translate but I think writing in english would be better for understanding.
I found this topic after my research on the www.
So far as I tried to get access to the nac, I fortunately could get access.
There a photo of the filesystem:
I even could extract data from the nac and watch all files, editing them and save them.
MR. vlud, the file you showed at the beginning looks quite different to the files I found.
I found a lot of databases which were separated.
Like one for Navigation and Connected services, then one for all car settings and so on.
The Databases are verry long and there are options wich I did not know that the Nac has these options.
Here a photo of the hmi menu after changing the template:
Unfortunately the nac ssems verry buggy. When I change the templates.
I even saw that several starting images / videos could be chosen.
Anybody who did work on it too?
I have been waiting for someone to share more information so thank you FelixdeVuist.
There is option of adding gridlines to each theme in the hmi menu
Great progress
