2ème partie :
Equipement intérieur
PRISE AUXILIAIRE PACK AUDIO 1 PRISE JACK + USB
BOITIER TELEMATIQUE BOITIER TELEMATIQUE AUTONOME EVOLUTION 2.0
TYPE D’HABILLAGE INTÉRIEUR TEXTILE 4 (NIV3) "9D"
APPUI-TÊTE AVANT APPUI-TETE AV REGLABLE
CACHE-BAGAGES TABLETTE
CEINTURE DE SÉCURITÉ ARRIÈRE CEINTURE SECURITE AR 3 ENROULEURS 3 POINTS
CEINTURE DE SÉCURITÉ AVANT ENROULEUR ALARME BOUCLAGE
CLIMAT (TEMPERATURE AMBIANTE) PAYS FROIDS
CONDAMNATION ENFANT CONDAMNATION ENFANT MANUELLE AR
GRADUATION VITESSES GRADUATION VITESSES EN KM/H
CONDITIONNEMENT RADIO ALIMENT ANTENNE RECEPTEUR HP AV/AR TWEETER
MIRROR LINK AVEC MIRROR LINK
ECLAIRAGE RANGEMENT SANS ECLAIRAGE BOITE A GANTS
EQUIPEMENT PLANCHE DE BORD BANDEAU NOIR + DECOR AEROTEUR CHROME SATINE
VARIATION D’HABILLAGE D’ÉQUIPEMENT INTÉRIEUR POIGNEE FREIN MAIN CUIR
FEUX INT. DIVERS LECTEUR DE CARTE
GARNISSAGE VOLUME CHARGEMENT TAPIS COFFRE MOQUETTE
COMBINÉ (CARACTÉRISTIQUES) COMBINE AVEC MATRICE
COMMANDE D’AUTORADIO COMMANDE AUTO-RADIO DIRECTE
REHAUSSE ASSISE AVANT PASSAGER REHAUSSE PASSAGER REGLAGE PARALLELE
RÉGLAGE ASSISE AVANT CONDUCTEUR REGL. ASSISE AV CONDUC. DOS INCL MAINTIEN LAT FIXE
RÉGLAGE ASSISE AVANT PASSAGER REGL.ASSISE AV PASS.DOSSIER INCL MAINTIEN LAT FIXE
ACCOUDOIR ASSISE AVANT MONTAGE AVEC ACCOUDOIR AVANT
SYSTÈME DE NAVIGATION AVEC SYSTEME NAVIGATION ECRAN COULEUR
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR ELECT CDE SEQUENT + CONDAMNAT
LÈVE-VITRE AVANT PASSAGER LEVE-VITRE AV PASSAGER CDE SEQUENTIELLE
AFFICHEUR AFFICHEUR AV ECRAN DGT7C
ACCESSOIRES INT. DIVERS SUPPORT GOBELET AVANT/ARRIERE
MIROIR DE COURTOISIE CONDUCTEUR & PASSAGER OCCULTABLE AVEC ECLAIRAGE
REPOSE-PIED SANS REPOSE PIED
INDICATEUR D’HUILE INDICATEUR NIVEAU HUILE
MONTAGE APPUI-TÊTE ARRIÈRE MONTAGE 3 APPUI-TETE AR
ECLAIRAGE BAS HABITACLE ECLAIRAGE CAVE A PIEDS COND + PASS AV
RÉTROVISEUR EXTÉRIEUR RETRO EXTERIEUR CHAUFFANT
COMMANDE INTÉRIEURE DE PORTE (ASPECT) COMMANDE INTERIEURE PORTE ASPECT CHROME
PLAFONNIER CDE A DISTANCE PORTES + PLAFONNIER AV
PLANCHER ARRIÈRE CHARGE SANS PLANCHER AR CHARGE
PARE-SOLEIL AVANT COTE CONDUCTEUR+PASSAGER AVEC PORTE CARTE+INSCRIP
WIFI AVEC WIFI
RÉCEPTEUR RADIO NAVIGATION CONNECTEE ANALOGIQUE
RÉGULATEUR DE VITESSES REGULATEUR ET LIMITEUR VITESSE PROGRAMMABLE
RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR-NUIT ELECTROCHROME
RANGEMENT (AUTRES) RANGEMENT STANDARD + POCHES AUMONIERES
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) GLACE RETROVISEUR EXT BOMBE
RANGEMENT VOLUME CHARGEMENT SANS FILET DANS COFFRE
TUNER-RADIO SANS TUNER RADIO
DÉTECTION D’OBSTACLE DETECTEUR OBSTACLE RADAR ARRIERE
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE DETECTION SOUS GONFLAGE INDIRECT SANS LOCALISATION
ADAPTATION GARNITURE SANS ADAPTATION GARNITURE
FRÉQUENCE RADIO FREQUENCE RADIO EUROPE OCCIDENTALE
COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION +AUTOMATIQUE
VITRE (TYPE) PARE-BRISE FEUILLETE ACCOUSTIQUE + VITRE AR TREMPE
VOLANT VOLANT CUIR
VENTILATEUR 1 VENTILATEUR 2 VITESSES 140W AERO AVEC ECOPE
Electricité
ALLUMAGE FEUX ALLUMAGE FEUX AUTOMATIQUE
ALTERNATEUR ALTERNATEUR CLASSE 12
AVERTISSEURS AVERTISSEUR STANDARD
BATTERIE BATTERIE L3 760 70AH EFR 760 EN EF
DÉMARREUR DEMARREUR STTD
ECLAIREMENT PARTICULIER ALLUMAGE AUTOMATIQUE FEUX
FEU DE RECUL AVEC 2 FEUX RECUL
FEU DE SIGNALISATION SIGNATURE LUMINEUSE
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVISEUR EXTERIEUR RABATTABLE ELECTRIQUE
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FREQUENCE TELECDE CONDA. 433,92 MHZ HETERODYNE
MESURE CHARGE BATTERIE AVEC MESURE CHARGE BATTERIE
PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD AVEC CORNERING LIGHT
PROJECTEUR SPÉCIAL (DOUBLE-OPTIQUE) PROJECTEUR DOUBLE OPTIQUE
Marques d'équipements
VARIANTE ASSOCIÉE FREIN ESP TEVES MK100E
VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION VALEO
Divers
MODIFICATION EN COURS D’ANNÉE MODÈLE INDICE MINEUR "03"
ATMOSPHÈRE ATMOSPHERE NORMALE
PLAQUE CONSTRUCTEUR PLAQUE CONSTRUCTION UNION EUROPEENNE + NRE
PRISE D’ÉCOUTE RADIO PRISE ACCESSOIRES SIMPLE
JOINT ANTISALISSURE JOINT ANTI-SALISSURES AMELIORE + AV PORTE AV
LIQUIDE RÉFRIGÉRANT LIQUIDE REFRIGERANT 1234 YF
ROULAGE BONNE ROUTE
ACCESSOIRES EXTÉRIEURS POIGNEE EXTERIEURE COULEUR CAISSE
BOÎTIER SERVITUDE BSI + COM 2008 + SON POLY
bonne lecture
WIFI AVEC WIFI
VOLANT VOLANT CUIR
ROULAGE BONNE ROUTE
bonne lecture
14/11 et pas 13/11 (voilà un des cas potentiels où il faut s'entendre sur "date de production")
