Suspension Direction Freinage
BARRE ANTIDÉVERS ARRIÈRE BARRE ANTI DEVERS AR RAIDEUR 30000 NM/RAD
ANTIDÉVERS AVANT BARRE ANTI DEVERS AV RAIDEUR 35000 NM/RAD
ANGLE VOLANT AVEC CAPTEUR ANGLE VOLANT
SUSPENSION SUSPENSION NORMALE
CONTRÔLE DYNAMIQUE DE STABILITÉ AVEC SYSTEME ESP
DIRECTION (FONCTIONNEMENT) DIRECTION ELECTRIQU ASSISTE DOUBLEPIGNON LOW POWER
PÉDALIER (TYPE) PEDALIER ALU
Carrosserie Equipements
BRAS RACLETTE BRAS RACLETTE STANDARD
DÉCORATION (PEINTE) BECQUET COULEUR CAISSE
ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEURS LATERAUX CHROME
ENJOLIVEMENT LATÉRAL (DIMENSION) SANS PROTECTEURS LAT BAS DE MARCHE AV ALU AR PLAST
SORTIE D’ÉCHAPPEMENT SORTIE ECHAPPEMENT DOUBLE
PROTECTION SOUS CAISSE DEFLECTEUR COURT SOUS PLANCHER AVD
ETANCHÉITÉ AÉRODYNAMIQUE SANS ETANCHEITE AERODYNAMIQUE
ANNEAU D’ARRIMAGE EXTÉRIEUR (RAPPORTÉ) SANS ANNEAU ARRIMAGE EXTERIEUR RAPPORTE
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RABATTABLE ELECTRIQUE+MARCHE AR+MEMO+PROJN IMAG E
INSONORISATION COTÉ MOTEUR INSONO TABLIER + CAPOT + PASS ROUE + GMP
PAVILLON (ASPECT EXTÉRIEUR) PAVILLON COULEUR NOIR PERLA NERA
VITRE PARE-BRISE (GENRE) VITRE PARE BRISE STANDARD
ESSUIE-VITRE ARRIÈRE AVEC ESSUIE-VITRE AR
PARE-CHOCS PC COUL CAISSE+GRILLE6 ENJ PAB CHROME+SABOT INOX
PLAQUE POLICE SANS PLAQUE POLICE
PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI-BROUILLARD A LED +CORNERING LIGHT
ROUE DE SECOURS SANS ROUE DE SECOURS
ACCESSOIRES EXTÉRIEURS POIGNEE EXTERIEUR COULEUR CAISSE
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) GLACE RETROVISEUR EXTERIEUR BOMBE
VITRE (ASPECT) VITRE TEINTEE + SURTEINTEE
ACCÈS ET DÉMARRAGE MAINS LIBRES ACCES AVANT + COFFRE + DEMARRAGE MAIN LIBRE
Equipement intérieur
TYPE D’HABILLAGE INTÉRIEUR TEP B OU C
ACCOUDOIR LATÉRAL (TYPE) ACCOUDOIR LATERAL AVANT ARRIERE TEP
ALLUME-CIGARE SANS ALLUME CIGARE
ASSISE SUPPLÉMENTAIRE 2 SIEGES SEPARES SUPPLEMENTAIRES
DETECTION ANGLEMORT AVEC SURVEILLANCE ANGLE MORT
CACHE-BAGAGES TENDELET
CEINTURE DE SÉCURITÉ ARRIÈRE CEINT SECU AR ENROULEUR LAT PYRO + CENTR 3 POINTS
CLIMAT (TEMPERATURE AMBIANTE) PAYS FROIDS
CLIMATISEUR AVEC AEROTHERME RECYCLAGE AUTO
CONDAMNATION ENFANT CONDAMNATION ENFANT MANUELLE AR
GRADUATION VITESSES GRADUATION VITESSES EN KM/H
COMMANDE DE VITESSES COMMANDE VITESSE AU PLANCHER SURELEVEE + AU VOLANT
CHAUFFAGE ADDITIONNEL SANS CHAUFFAGE ADDITIONNEL
MIRROR LINK AVEC MIRROR LINK
ECLAIRAGE RANGEMENT ECLAIRAGE VIDE POCHE + BOITE A GANTS LED
ECLAIRAGE DE COFFRE VOLUME CHARGEMENT CDE AUTO ECLAIRAGE COFFRE + VOLUME CHARGEMENT LED
EQUIPEMENT PLANCHE DE BORD EQUIPEMENT PLANCHE BORD DECOR TEXTILE SURPIQUE
FEUX INT. DIVERS PLAFONNIER LECTEUR AV LED + 2 PLAFONNIERS AR LED
TABLETTE DE TRAVAIL AVEC TABLETTE TRAVAIL
GARNISSAGE VOLUME CHARGEMENT MONTAGE TAPIS + FOND COFFRE MOQUETTE
COMBINÉ (CARACTÉRISTIQUES) COMBINE NUMERIQUE 29 VOYANTS
GARNISSAGE DE PORTE GARNISSAGE PORTE AVEC DECOR TEXTILE
HAUT-PARLEUR 4 HAUT PARLEUR AV (2 TW + 2 AV)+2 HAUT PARLEUR AR
PULSEUR ADDITIONNEL AVEC PULSEUR ADDITIONNEL
INSONORISATION HABITACLE INSONO TABLIER 7KG + PASSAGE DE ROUE+TUNNEL+AUVENT
REHAUSSE ASSISE AVANT PASSAGER REHAUSSE ASSISE AV PASSAGER REGLAGE PARALLELE
COMMANDE ASSISE AVANT CONDUCTEUR CDE ASSISE CONDUCTEUR MANUELLE+RELAX
COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV MANUEL + RELAX
RÉGLAGE ASSISE AVANT CONDUCTEUR DOSSIER INCLINABLE MAINTIEN LOMBAIRE CONDUCTEUR
RÉGLAGE ASSISE AVANT PASSAGER REGLAGE ASSISE AV PASSAGER DOSSIER INCLINABLE
RABATTEMENT ASSISE AVANT PASSAGER RABATTEMENT ASSISE AV PASSAGER PORTEFEUILLE
ELÉMENTS DE GARNISSAGE INTÉRIEUR GARNISSAGE INT MISTRAL PAVILL+MONTANT BAIE+CUSTODE
ACCOUDOIR ASSISE AVANT ACCOUDOIR CENTRAL FLOQUE + TEP
SYSTÈME DE NAVIGATION AVEC SYSTEME NAVIGATION ECRAN COULEUR
LAMPES DE PROJECTEURS LAMPE A LED
LECTEUR D’INFORMATIONS ROUTIÈRES PREVENTION+CORRECTION TRAJECTOIRE LATERALE
AFFICHEUR ECRAN DIGITAL TACTILE
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
INDICATEUR D’HUILE SANS RECEPTEUR NIVEAU HUILE
NAPPE CHAUFFANTE SIEGE CHAUFFANT
ECLAIRAGE BAS HABITACLE ECLAIRAGE CAVE A PIED AVEC LED
PROTECTION PASSAGER ARRIÈRE SANS PROTECTION PASSAGER AR
PROJECTEUR CORRECTEUR ASSIETTE REGLAGE AUTOMATIQUE PROJECTEURS
WIFI AVEC WIFI
RANGEMENT (POSTE CONDUITE) VIDE POCHE + PALETTE CHROMEE
RÉCEPTEUR RADIO NAVIGATION CONNECTEE ANALOGIQUE
RÉGULATEUR DE VITESSES REGULATEUR ET LIMITEUR DE VITESSE ADAPTATIF
RÉTROVISEUR INTÉRIEUR RETROVISEUR INTERIEUR JOUR-NUIT ELECTROCHROME
SURTAPIS (ASPECT) SURTAPIS TWIST YARM G287 GANS V072 PE
TUNER-RADIO BI TUNER RADIO
TÉMOIN DE NIVEAU DE LIQUIDE DE REFROIDISSEMENT SANS TEMOIN NIVEAU LIQUIDE REFROIDISSEMENT
DÉTECTION D’OBSTACLE DETECTEUR OBSTACLE RADAR AVANT ARRIERE
STORES LATÉRAUX STORES LATERAUX "RANG 2"
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE DETECTION SOUS GONFLAGE INDIRECT AVEC LOCALISATION
ADAPTATION GARNITURE SANS ADAPTATION GARNITURE
SURTAPIS SURTAPIS AV + AR
FRÉQUENCE RADIO FREQUENCE RADIO EUROPE OCCIDENTALE
COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION +AUTOMATIQUE
VOLANT CUIR PLNE FLEUR PERF INS CARBO
VENTILATEUR 1 VENTILATEUR 2 VITESSES 140W AERO VOLET DYNAMIQUE
PRISE AUXILIAIRE PACK AUDIO 1 PRISE USB+PRISE VIDEO LVDS2
BOITIER TELEMATIQUE SANS BOITIER TELEMATIQUE
Electricité
ALTERNATEUR ALTERNATEUR CLASSE 18
BATTERIE BATTERIE L3 760 70AH EFR 760 EN EF
DÉMARREUR DEMARREUR STTD
ECLAIREMENT PARTICULIER FEU DIURNE AVANT (DRL)
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FREQUENCE TELECDE CONDA 433,92 MHZ HETERODYNE
MULTIPLEXAGE ARCHITECTURE ELECTRIQUE ECONOMIQUE EVOLUEE
MESURE CHARGE BATTERIE AVEC MESURE CHARGE BATTERIE
ALLUMAGE FEUX ALLUMAGE FEUX AUTOMATIQUE+COMMUTATION AUTOMATIQUE
Marques d'équipements
Divers
ATMOSPHÈRE ATMOSPHERE NORMALE
PLAQUE CONSTRUCTEUR PLAQUE CONSTRUCTION UNION EUROPEENNE + NRE
ETIQUETTE SANS ETIQUETTE
PRISE D’ÉCOUTE RADIO PRISE 220V + ACCESSOIRE TRIPLE
JEUX DE CLÉS JEU DE CLES BADGE + CLE SECOURS
JOINT ANTISALISSURE JOINT AV PORTE AV+INF PORT AV/AR
LIQUIDE RÉFRIGÉRANT LIQUIDE REFRIGERANT 1234 YF
EQUIPEMENT DE SECOURS KIT ANTI CREVAISON
ROULAGE BONNE ROUTE
BOÎTIER SERVITUDE BSI + COM 2008 + SON POLY + DECOR CHROME
