J'ai trouvé!
Apparemment le 120 BlueHDI a l'alterno-demarreur!
Ligne de produit 308 (T9)
N°APV/PR 14471 89 1 0590
NRE e2*2007/46*0405*12
Informations générales
LIGNE DE PRODUIT 308 (T9)
SILHOUETTE BERLINE 5PTES
FINITION GT LINE
MOTEUR DIESEL TURBO DV6FC FAP 88KW
TRANSMISSION BVA 6 RAPPORTS TYPE STT
TYPE DE PEINTURE PEINTURE METALLISEE TRI COUCHE NACRE
COULEUR DE CAISSE KWE - PEINTURE BLANC NACRE
TYPE D’HABILLAGE INTÉRIEUR C&T TEXTILE OXF +TEP PU "0N"
COULEUR DE GARNISSAGE "FJ"
BOITE DE VITESSES (CARACTÉRISTIQUES) BVA AT6
DEFINITION A VENIR ANCIENNE GAMME
MOTEUR (TYPE) MOTEUR TYPE DV
MONOGRAMME COMPLÉMENTAIRE, DIVERS GT LINE
Caractéristiques véhicule
FINITION GT LINE
COUPLE TACHYMÈTRE SANS COUPLE TACHYMETRE
Alimentation moteur
ALIMENTATION INJECTION TURBO ECHANGEUR DIRECT
CARBURANT GAZOLE QUALITE DA/DE/DE+
DÉPOLLUTION (MOTEUR) DEPOLLUTION EURO 6(MOTEUR)
CYLINDRÉE 1600 CM3
CATALYSEUR CATALYSEUR SUP 50PPM
RÉSERVOIR DE CARBURANT RESERVOIR CARBURANT AVEC DETROMPEUR
MOTEUR REFROIDISSEMENT RADIATEUR 28DM2 EP: 18 ALU BRASE
RÉCHAUFFAGE CIRCUIT GAZ CARTER AVEC RECHAUFFAGE CIRCUIT GAZ CARTER
SONORITE GMP SPECIFIQUE DYNAMIQUE
AUTODIAGNOSTIC EOBD AUTO-DIAGNOSTIC "EOBD"
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE EURO6
FILTRE À PARTICULE AVEC FILTRE PARTICULE
VENTILATEUR 1 VENTILATEUR 2 VITESSES 95W AERO VOLET DYNAMIQUE
CHAINE DE TRACTION HYBRIDE SANS CHAINE TRACTION HYBRIDE
STOP AND START AVEC STOP AND START ALTERNO DEMARREUR
COUPLE RAPPORT CP 15 X 58
STYLE ROUE JANTE RUBIS 17"
EMBRAYAGE SANS EMBRAYAGE
JANTE / PNEU DIMENSION MONTE PNEU 17 POUCES
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 225/45 R17 91V NON RENFORCE
ROUES MOTRICES 2 ROUES MOTRICES
ROUE (TYPE) MONTAGE ROUE ALLIAGE 1
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE DETECTION SOUS GONFLAGE INDIRECT AVEC LOCALISATION
BOITE DE VITESSES TYPE BVA AT6 3
Suspension Direction Freinage
BARRE ANTIDÉVERS ARRIÈRE BARRE ANTI DEVERS AR RAIDEUR 25000 NM/RAD
ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAMETRE 22 CREUSE
FREIN TYPE DISQUES AV VENTILES/DISQUES AR
ANGLE VOLANT AVEC CAPTEUR ANGLE VOLANT
SUSPENSION SUSPENSION NORMALE
SUSPENSION (TYPE ARCHITECTURE) SUSPENSION METALLIQUE
CONTRÔLE DYNAMIQUE DE STABILITÉ AVEC SYSTEME ESP
DIRECTION (FONCTIONNEMENT) DIRECTION ELECTRIQU ASSISTE SIMPLEPIGNON LOW POWER
PÉDALIER (TYPE) PEDALIER ALU
Carrosserie Equipements
ENJOLIVEMENT LATÉRAL (DIMENSION) SANS PROTECTEURS LATERAUX + BAS MARCHE PEUGEOT
ENJOLIVEUR ROUE (STYLE) SANS ENJOLIVEUR DE ROUE
PROTECTION SOUS CAISSE SANS PROTECTION SOUS CAISSE
FEU DE RECUL AVEC 2 FEUX DE RECUL
ANNEAU D’ARRIMAGE EXTÉRIEUR (RAPPORTÉ) SANS ANNEAU ARRIMAGE EXTERIEUR RAPPORTE
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVISEUR EXTERIEUR RABATTABLE ELECTRIQUE+DIODE
PARE-BOUE PARE-BOUE STANDARD AVEC MOUSSE AV
INSONORISATION COTÉ MOTEUR INSONO TABLIER + CAPOT + PASS ROUE + GMP
VITRE PARE-BRISE (GENRE) VITRE PARE BRISE STANDARD
ESSUIE-VITRE ARRIÈRE AVEC ESSUIE-VITRE AR
PARE-BOUE (BAVETTE) AVEC PARE BOUE AV
PLAQUE POLICE SANS PLAQUE POLICE
PORTE-BAGAGES MONTAGE SANS BARRES DE TOIT LONGITUDINALES
PROJECTEUR ANTIBROUILLARD PROJECTEUR ANTI-BROUILLARD A LED
ROUE DE SECOURS SANS ROUE DE SECOURS
ACCESSOIRES EXTÉRIEURS POIGNEE EXTERIEUR COULEUR CAISSE
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) GLACE RETRO EXT BOMBE
VITRE (ASPECT) VITRE TEINTEE + SURTEINTEE AR
VITRE (TYPE) PARE-BRISE FEUILLETE ACCOUSTIQUE + VITRE AR TREMPE
ACCÈS ET DÉMARRAGE MAINS LIBRES AVEC ACCES/DEMARRAGE MAINS LIBRES
Equipement intérieur
ALLUME-CIGARE SANS ALLUME CIGARE
DETECTION ANGLEMORT AVEC SURVEILLANCE ANGLE MORT
ACCOUDOIR ASSISE ARRIÈRE AVEC ACCOUDOIR AR
ARRIMAGE INTÉRIEUR AVEC ARRIMAGE INTERIEUR
CACHE-BAGAGES TABLETTE
CEINTURE DE SÉCURITÉ ARRIÈRE CEINT SECU AR 3 ENROULEURS 3 PTS + TEMOIN BOUCLAGE
CEINTURE DE SÉCURITÉ AVANT ENROULEUR ALARME BOUCLAGE CONDUCTEUR + PASSAGER
CENDRIER SANS CENDRIER
CLIMAT (TEMPERATURE AMBIANTE) PAYS FROIDS
COMMANDE DE VITESSES COMMANDE VITESSE AU PLANCHER ET AU VOLANT
CHAUFFAGE ADDITIONNEL SANS CHAUFFAGE ADDITIONNEL
MIRROR LINK SANS MIRROR LINK
VARIATION D’HABILLAGE D’ÉQUIPEMENT INTÉRIEUR SANS PRISE ACCESSOIRES
FEUX INT. DIVERS LC AV/AR A LEDS SANS LED AMB AVEC ECL AMB
GARNISSAGE VOLUME CHARGEMENT TAPIS + FOND + COTES MOQUETTE
COMBINÉ (CARACTÉRISTIQUES) COMBINE AVEC MATRICE
GARNISSAGE DE PORTE GARNISSAGE PORTE DECOR CHROME SATIN
ANCRAGE SIÈGE ENFANT SANS ANCRAGE SIEGES ENFANTS AVEC ISO AR
HAUT-PARLEUR 4 HP AV (2TW+2HP) + 5 HP AR (2TW+2HP+1C BASSE)
COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE
INSONORISATION HABITACLE INSONORISATION (HABITACLE)TABLIER 2,8 KG
REHAUSSE ASSISE AVANT PASSAGER REHAUSSE PASSAGER REGLAGE PARALLELE+AV
RÉGLAGE ASSISE AVANT CONDUCTEUR REGLAGE LOMBAIRE CONDUCTEUR MANUEL
RÉGLAGE ASSISE AVANT PASSAGER MAINTIEN LOMBAIRE PASSAGER
ACCOUDOIR ASSISE AVANT ACCOUDOIR CENTRAL
COMPACT DISQUE MONTAGE COMPACT DISQUES
SYSTÈME DE NAVIGATION NAVIGATION 2 ECRANS COULEUR
LAMPES DE PROJECTEURS LAMPE A LED
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR ELECTRIQUE CDE SEQUENTIELLE
LECTEUR D’INFORMATIONS ROUTIÈRES SANS SURVEILLANCE TRAJECTOIRE LATERALE
AFFICHEUR ECRAN DIGITAL TACTILE
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
MONTAGE APPUI-TÊTE ARRIÈRE MONTAGE 3 APPUI-TETE AR
ECLAIRAGE BAS HABITACLE ECLAIRAGE CAVE A PIEDS COND + PASS AV
PROTECTION PASSAGER ARRIÈRE SANS PROTECTION PASSAGER AR
NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION AIRBAG MANUELLE
PLANCHER ARRIÈRE CHARGE SANS PLANCHER AR CHARGE
PROJECTEUR CORRECTEUR ASSIETTE REGLAGE AUTOMATIQUE PROJECTEURS
PARE-SOLEIL AVANT COTE CONDUCTEUR+PASSAGER AVEC PORTE CARTE+INSCRIP
WIFI SANS WIFI
RÉCEPTEUR RADIO RECEPTEUR RADIO SMEG ANALOGIQUE
RÉGULATEUR DE VITESSES REGULATEUR ET LIMITEUR VITESSE PROGRAMMABLE
REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE PARALLELE+AV
RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR-NUIT ELECTROCHROME
SURTAPIS (ASPECT) SURTAPIS MOQUETTE LOGO GT
RANGEMENT VOLUME CHARGEMENT SANGLE GARNITURE LATERALE COFFRE
TUNER-RADIO MONO TUNER RADIO
TÉMOIN DE NIVEAU DE LIQUIDE DE REFROIDISSEMENT SANS TEMOIN NIVEAU LIQUIDE REFROIDISSEMENT
DÉTECTION D’OBSTACLE DETECTEUR OBSTACLE RADAR AV AR + CAMERA AR+PK AUTO
STORES LATÉRAUX SANS STORES LATERAUX
SURTAPIS SURTAPIS AVANT+ARRIERE
AMPLI-ÉQUALISEUR AVEC AMPLI EQUALISEUR
FRÉQUENCE RADIO FREQUENCE RADIO EUROPE OCCIDENTALE
COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION + AUTOMATIQUE
VOLANT VOLANT SPORT CUIR
VARIANTE ASSOCIÉE ASSISE BASSE
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) MAINTIEN LOMBAIRE MANUEL
PRISE AUXILIAIRE PACK AUDIO AVEC 1 PRISE JACK + USB
BOITIER TELEMATIQUE BOITIER TELEMATIQUE AUTONOME EVOLUTION 2.0
Electricité
ALTERNATEUR ALTERNATEUR ISTT41
BATTERIE BATTERIE L3 760 VRLA2 EN AGM
DÉMARREUR DEMARREUR CLASSE 5
ECLAIREMENT PARTICULIER FEUX DIURNE AV
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FREQUENCE TELECDE CONDA 433,92 MHZ HETERODYNE
MULTIPLEXAGE ARCHITECTURE ELECTRIQUE FULL
ALLUMAGE FEUX ALLUMAGE FEUX AUTOMATIQUE
Marques d'équipements
Divers
ATMOSPHÈRE ATMOSPHERE NORMALE
PLAQUE CONSTRUCTEUR PLAQUE CONSTRUCTION UNION EUROPEENNE + NRE
ETIQUETTE SANS ETIQUETTE
PRISE D’ÉCOUTE RADIO PRISE ACCESSOIRES 220V +ACCESSOIRE DOUBLE
JEUX DE CLÉS JEU DE CLES BADGE + CLE SECOURS
JOINT ANTISALISSURE JOINT ANTI-SALISSURES AMELIORE + AV PORTE AV
LIQUIDE RÉFRIGÉRANT LIQUIDE REFRIGERANT 1234 YF
EQUIPEMENT DE SECOURS KIT ANTI CREVAISON
ROULAGE BONNE ROUTE
BOÎTIER SERVITUDE BSI + COM 2008 + SON POLY
