407 2.0 essence 5 vitesses swap avec boîte 6 vitesses
407mk
19 Juillet 2024
Macedonia
Hello everyone, as you can see from my French, I use Google Translate.
Thank you for your patience, I have an idea and I need help. I have a 407 2.0 petrol with a 5-speed manual. At a motorway speed of 130 km/h the revs are too high in my opinion. My idea is to replace the gearbox with the one from the 2.2 petrol 6-speed? (with a bit of luck I will find a used one)
The question is whether this is feasible and what modification might be necessary? Thanks!
Hi if you have ML5C, an ML6C is fully compatible.
With lock ring for rear gear and rear gear on top letf corner.
You need to check on gearbox your model number, like 20DM29 for example.
Needed gearbox and the command cable attach to gear lever.
Merci pour la réponse rapide. J'ai quelques questions concernant ce sujet si vous pouvez m'aider. D'abord si possible lire sur la boîte de vitesses pour vérifier le modèle ? Deuxièmement et des informations sur les rapports de démultiplication et le rapport final pour que je puisse calculer le régime de croisière ? Merci d'avance!
