2 ème partie
Carrosserie Equipements
ENJOLIVEMENT LATÉRAL (DIMENSION) SANS PROTECTEURS LATERAUX
ENJOLIVEUR ROUE (STYLE) SANS ENJOLIVEUR DE ROUE
PROTECTION SOUS CAISSE SANS PROTECTION SOUS CAISSE
FEU DE RECUL AVEC 2 FEUX DE RECUL
ANNEAU D’ARRIMAGE EXTÉRIEUR (RAPPORTÉ) SANS ANNEAU ARRIMAGE EXTERIEUR RAPPORTE
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVISEUR EXTERIEUR RABATTABLE ELECTRIQUE+DIODE
PARE-BOUE PARE-BOUE STANDARD AVEC MOUSSE AV
INSONORISATION COTÉ MOTEUR INSONO TABLIER + CAPOT + PASS ROUE + GMP AC
ESSUIE-VITRE ARRIÈRE AVEC ESSUIE-VITRE AR
PARE-CHOCS PARE-CHOCS AV CC + JONC CHROME ET PC AR CC
PLAQUE POLICE SANS PLAQUE POLICE
PORTE-BAGAGES MONTAGE SANS BARRES DE TOIT LONGITUDINALES
ROUE DE SECOURS SANS ROUE DE SECOURS
ACCESSOIRES EXTÉRIEURS POIGNEE EXT C CAISSE + CHROMEE
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) GLACE RETRO EXT BOMBE
VITRE (ASPECT) VITRE TEINTEE
VITRE (TYPE) PARE-BRISE FEUILLETE ACCOUSTIQUE + VITRE AR TREMPE
ACCÈS ET DÉMARRAGE MAINS LIBRES AVEC ACCES/DEMARRAGE MAINS LIBRES
Equipement intérieur
TYPE D’HABILLAGE INTÉRIEUR CUIR CLUB "8D"
ALLUME-CIGARE SANS ALLUME CIGARE
DETECTION ANGLEMORT AVEC SURVEILLANCE ANGLE MORT
ACCOUDOIR ASSISE ARRIÈRE AVEC ACCOUDOIR AR
ARRIMAGE INTÉRIEUR AVEC ARRIMAGE INTERIEUR
CACHE-BAGAGES TABLETTE
CEINTURE DE SÉCURITÉ ARRIÈRE CEINT SECU AR 3 ENROULEURS 3 PTS + TEMOIN BOUCLAGE
CEINTURE DE SÉCURITÉ AVANT ENROULEUR ALARME BOUCLAGE CONDUCTEUR + PASSAGER
CENDRIER SANS CENDRIER
CLIMAT (TEMPERATURE AMBIANTE) PAYS FROIDS
COMMANDE DE VITESSES COMMANDE VITESSE AU PLANCHER
CHAUFFAGE ADDITIONNEL SANS CHAUFFAGE ADDITIONNEL
VARIATION D’HABILLAGE D’ÉQUIPEMENT INTÉRIEUR SANS PRISE ACCESSOIRES
FEUX INT. DIVERS LC AV/AR A LEDS SANS LED AMB AVEC ECL AMB
GARNISSAGE VOLUME CHARGEMENT TAPIS + FOND + COTES MOQUETTE
COMBINÉ (CARACTÉRISTIQUES) COMBINE AVEC MATRICE
ANCRAGE SIÈGE ENFANT SANS ANCRAGE SIEGES ENFANTS AVEC ISO AR
HAUT-PARLEUR 4 HP AV (2TW+2HP) + 5 HP AR (2TW+2HP+1C BASSE)
COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE
INSONORISATION HABITACLE INSONORISATION (HABITACLE)TABLIER 2,8 KG
REHAUSSE ASSISE AVANT PASSAGER REHAUSSE PASSAGER REGLAGE PARALLELE+AV
COMMANDE ASSISE AVANT CONDUCTEUR CDE SIEGE AV A MEMOIRE CONDUCTEUR
RÉGLAGE ASSISE AVANT CONDUCTEUR REGLAGE LOMBAIRE CONDUCTEUR MANUEL
RÉGLAGE ASSISE AVANT PASSAGER MAINTIEN LOMBAIRE PASSAGER
ACCOUDOIR ASSISE AVANT ACCOUDOIR CENTRAL
COMPACT DISQUE MONTAGE COMPACT DISQUES
SYSTÈME DE NAVIGATION NAVIGATION 2 ECRANS COULEUR
LAMPES DE PROJECTEURS LAMPE A LED
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR ELECTRIQUE CDE SEQUENTIELLE
AFFICHEUR ECRAN DIGITAL TACTILE
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
INDICATEUR D’HUILE INDICATEUR NIVEAU HUILE
MONTAGE APPUI-TÊTE ARRIÈRE MONTAGE 3 APPUI-TETE AR
NAPPE CHAUFFANTE SIEGES CHAUFFANTS
ECLAIRAGE BAS HABITACLE ECLAIRAGE CAVE A PIEDS COND + PASS AV
PROTECTION PASSAGER ARRIÈRE SANS PROTECTION PASSAGER AR
NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION AIRBAG MANUELLE
PLANCHER ARRIÈRE CHARGE SANS PLANCHER AR CHARGE
PROJECTEUR CORRECTEUR ASSIETTE REGLAGE AUTOMATIQUE PROJECTEURS
PARE-SOLEIL AVANT COTE CONDUCTEUR+PASSAGER AVEC PORTE CARTE+INSCRIP
RÉCEPTEUR RADIO RECEPTEUR RADIO SMEG ANALOGIQUE
RÉGULATEUR DE VITESSES REGULATEUR LIMITATEUR ET MAINTIEN DISTANCE
REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE PARALLELE+AV
RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR-NUIT ELECTROCHROME
RANGEMENT VOLUME CHARGEMENT SANGLE GARNITURE LATERALE COFFRE
TUNER-RADIO MONO TUNER RADIO
TÉMOIN DE NIVEAU DE LIQUIDE DE REFROIDISSEMENT SANS TEMOIN NIVEAU LIQUIDE REFROIDISSEMENT
DÉTECTION D’OBSTACLE DETECTEUR OBSTACLE RADAR AV AR + CAMERA AR
STORES LATÉRAUX SANS STORES LATERAUX
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE DETECTION SOUS GONFLAGE INDIRECT AVEC LOCALISATION
SURTAPIS SURTAPIS AVANT+ARRIERE
AMPLI-ÉQUALISEUR AVEC AMPLI EQUALISEUR
FRÉQUENCE RADIO FREQUENCE RADIO EUROPE OCCIDENTALE
COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION + AUTOMATIQUE
VOLANT VOLANT CUIR PLEINE FLEUR
VENTILATEUR 1 VENTILATEUR 2 VITESSES 95W AERO VOLET DYNAMIQUE
VARIANTE ASSOCIÉE ASSISE BASSE
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) MAINTIEN LOMBAIRE CONDUCTEUR+PASSAGER ELECTRIQUE
PRISE AUXILIAIRE PACK AUDIO 1 PRISE JACK + 2 USB
BOITIER TELEMATIQUE SANS BOITIER TELEMATIQUE
Electricité
ALTERNATEUR ALTERNATEUR ISTT51
BATTERIE BATTERIE L3 760 ETANCHE(L3 760 VRLA 760 EN AGM)
DÉMARREUR DEMARREUR CLASSE 6
ECLAIREMENT PARTICULIER FEUX DIURNE AV
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FREQUENCE TELECDE CONDA 433,92 MHZ HETERODYNE
MULTIPLEXAGE ARCHITECTURE ELECTRIQUE FULL
ALLUMAGE FEUX ALLUMAGE FEUX AUTOMATIQUE
Marques d'équipements
VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION SIEMENS
Divers
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION BASSE CONSOMMATION
ATMOSPHÈRE ATMOSPHERE NORMALE
PLAQUE CONSTRUCTEUR PLAQUE CONSTRUCTION UNION EUROPEENNE + NRE
ETIQUETTE SANS ETIQUETTE
PRISE D’ÉCOUTE RADIO PRISE ACCESSOIRES 220V +ACCESSOIRE DOUBLE
JEUX DE CLÉS JEU DE CLES BADGE + CLE SECOURS
JOINT ANTISALISSURE JOINT ANTI-SALISSURES AMELIORE + AV PORTE AV
LIQUIDE RÉFRIGÉRANT LIQUIDE REFRIGERANT 1234 YF
EQUIPEMENT DE SECOURS KIT ANTI CREVAISON
ROULAGE BONNE ROUTE
BOÎTIER SERVITUDE BSI + COM 2008 + SON POLY
