C'est normal, le Mirascript doit être adapté pour mettre ton VIN.
1. Enregistre sur un USB le MiraScript dézipé et change dans le dossier CMD : RT6_VIN.CMD en RT6_VIN.txt
2. Tu auras ce que tu vois ci-dessous, change la dedans uniquement "1234567890123457" (ici en rouge) en ton VIN par ex. "VFxxxxxxxxxxxxxxxxx" en laissant bien les guillemets avant et après !!!
3. Enregistre le fichier changé
4. Maintenant sur ton USB change dans le dossier CMD : RT6_VIN.TXT en RT6_VIN.CMD
5. Execute Mirascript/Setteing/commande RT6_VIN... confirme et puis reboot ton RT6
______________________________________
* RT6_VIN written by mira308sw
* script to read/write user_com.dat file from usb device and update VIN
* in DB boot.
* WARNING:
* VIN code must me written in the file user_config.dat and also in the
* line #define VIN "1234567890123457" below, before run this script.
* v01.00 : 03/11/2012
#define VIN "12345678901234567" // VIN number to write
#define DBSYSTEM_FILE "/bd0/dbsystem.bin"
#define FLASH_DIR "/F/user_data/User_profile"
#define RTX_DIR "/SDI/user_data/User_profile"
#define USB_DIR "/bd0"
#define DAT_FILE "/User_config.dat"
#define INF_FILE DAT_FILE ".inf"
#define NO 0
#define YES 1
#define OK 0
#define ERROR -1
int GetFileSize (char* file, int* size);
int ShowNavigationQuestionScreen (char* text, int* answer);
int UPGCopy ( char *src,char *dst,int cut );
void RebootSystem ( void );
void* UPGFindSymbol ( char *sym );
int AddUPGHistoryCommentary ( void *funptr,... ); // max 7 parameters
#define GFC AddUPGHistoryCommentary
void BackupDBSystem ( void )
int answ;
void *fp=UPGFindSymbol( "BackupDBSystem__FPCc" );
if( !fp )
ShowNavigationQuestionScreen( "Error in FindSymbol(BackupDBSystem)",&answ );
else
if( GFC( fp,DBSYSTEM_FILE )!=OK )
ShowNavigationQuestionScreen( "Error in BackupDBSystem(file)",&answ );
void SetSBSystemCodeVIN ( void )
int answ;
void *pf=UPGFindSymbol( "InterSetSBSystemCodeVIN__FPCUc" );
if( !pf )
ShowNavigationQuestionScreen( "Error in UPGFindSymbol(InterSetSBSystemCodeVIN)",&answ );
else
if( GFC( pf,VIN )!=OK )
ShowNavigationQuestionScreen( "Error in InterSetSBSystemCodeVIN(vin)",&answ );
int main ( int argc,char* argv[] )
int size;
int answ=NO;
if( GetFileSize( USB_DIR DAT_FILE,&size )==OK )
ShowNavigationQuestionScreen( "WRITE user_cofig.dat ?",&answ );
if( answ==YES )
UPGCopy( USB_DIR DAT_FILE,RTX_DIR DAT_FILE,0 );
UPGCopy( USB_DIR INF_FILE,RTX_DIR INF_FILE,0 );
UPGCopy( USB_DIR DAT_FILE,FLASH_DIR DAT_FILE,0 );
UPGCopy( USB_DIR INF_FILE,FLASH_DIR INF_FILE,0 );
BackupDBSystem();
SetSBSystemCodeVIN();
ShowNavigationQuestionScreen( "Files copied. Reboot ?",&answ );
if( answ==YES )
RebootSystem();
else
ShowNavigationQuestionScreen( "READ user_config.dat ?",&answ );
if( answ==YES )
UPGCopy( RTX_DIR DAT_FILE,USB_DIR DAT_FILE,0 );
UPGCopy( RTX_DIR INF_FILE,USB_DIR INF_FILE,0 );
BackupDBSystem();
ShowNavigationQuestionScreen( "Copy completed.",&answ );
else
ShowNavigationQuestionScreen( "Finish.",&answ );
return OK;
