Disclaimer: I WILL NOT BE RESPONSIBLE IN CASE OF DAMAGE IN YOUR CAR.
This topic is here to share solutions for your cluster retrofit.
I made three sketches, all have a different behavior for what you want to do, you can even make your own one, and adapt the setup for your configuration.
Make sure to know the basis, THIS IS NOT A TUTORIAL.
The tutorial for the complete 308 Cluster Retrofit is going to be the subject of another topic, which is coming very soon. (I am 99%, just need to implement a sensor, you'll see why later).
- First Sketch:
Arduino in DUAL CANBUS Configuration for [SOURCE] to [MODE] steering key retrofit :
Arduino is placed between COM2008 & CAN CAR.
Arduino is catching SOURCE frame, and replacing it with MODE.
- Second Sketch:
Arduino in SINGLE CANBUS Configuration for SPEED SIGNS :
Arduino is implemented into the CAN INFO DIV, catching matrix sign from the nac, and transforming it to a CVM Frame.
- Third Sketch:
This sketch is specific for VISTEON Clusters
It's an All In One Sketch, implemented in DUAL CANBUS.
Every Functions of the 308 Digital i-Cockpit are retrofitted.
Arduino is placed between Cluster & CAN INFO DIV.
Speesign, ARTIV, Modes, Peugeot Animation is retrofitted.
Thanks @VLud for code inspiration, feel free to consult his topic to learn more about dual canbus.
Thanks @marcins @FelixdeVuist for beeing beta tester, and sharing some frames.
- First Sketch:
- Second Sketch:
- Third Sketch:
