[TUTO] Télécodage et calibration d'un NAC / RCC / CIROCCO / CMB_NUM SANS Diagbox via Arduino
Hi all, I posted a couple weeks ago about a rather unusual change I wanted to do to my car. I have a 2021 T9 308. I managed to get a switch panel from a 308 Active trim (physical AC controls, photo of the thing attached). It works just fine for controlling the AC (which was my obsession goal) since I made all the necessary changes in NAC and BSI to accommodate for the swap (yay).
The only issue I have now is that the touch buttons for the NAC screen don't work. I've read every entry on this thread regarding FMUX but since nobody has done this swap I'm a little lost. I understand that for some mods you need to upload a new calibration to the NAC, but all those mods involved changing some part of the system (be it screen or the telematic unit itself). That's kinda not the case here, so I'm not sure how to fix it.
Maybe @VLud or @marcins you guys could point me in the right direction. Thank you so much in advance.
Pièces jointes
    729.5 Ko · Affichages: 57
Pouvez-vous partager STL ?
Oui, pas de soucis! Il faut juste que je les récupère sur le PC du boulot :p
If I had found it, I wouldn't have bothered to draw it. :calimero:
Hallo,
Mijn camera aan de achterzijde werkt niet, springt eraf en geeft geen video-uitvoer weer.
Moet ik de camera vervangen of is het iets om te kalibreren of door software te veranderen?
Pièces jointes
    78.5 Ko · Affichages: 6
    63.7 Ko · Affichages: 7
Olá. Você pode me ajudar, por favor? Não consigo ligar a luz automática (HBA) na minha câmera cvm2. 2E2100BC40 não funciona. Talvez eu precise de outro comando 2E2100???? ? Ou preciso alterar o software da minha câmera? Talvez você saiba como?
PWhen I installed the first cvm2 in my 3008 II it was exactly this and even though everything was fine, it didn't work, only the high beam switching. It only worked when I switched to a version that has the acronym BBK. Today I know that the acronyms EK, BBK, EJ and BBJ work all options. When I put the BBK version I didn't need to change anything and everything worked. It may be that in your case it is the same as what happened to me.
Desculpe, mas não consigo entender sua ficha, por exemplo se quero ativar o ACC, com sistema de estacionamento semiautomático, com controle de descida e com frenagem automática em caso de risco de colisão, como ficará meu código e como usarei sua ficha ?
leia sua zona esp. cole-o na primeira linha. em seguida, altere os itens desejados e o código da segunda linha será o código que você deve inserir na zona esp. Lembrando que fiz essa planilha para meu carro Peugeot 3008 II, não sei se funciona para todos.
Minha zona original 2101 62210106FBFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBFFFF77FFFFBFFFFEEFBA6EFF
2 CFG_000_FREIN_UCPR_CITY_PARK (CFG_000_FREIN_UCPR_CITY_PARK)EF
: Sistema de estacionamento semiautomático
: Com sensor de ângulo do volante U+ 3
: 2 PODE
: Sem controle de rastreamento
3 CFG_000_FREIN_UDS_UCPR_HADC (CFG_000_FREIN_UDS_UCPR_HADC)BA
: O sistema de controle de descida
: Para operação automática no caso de risco do pacote U+ (operado com câmera de vídeo multifuncional)
: voando para a esquerda
: Sensor de velocidade da haste para detectar detecção de rotação da haste
: ECU de controle elétrico para caixa de velocidade automática
: Como o sistema de assistência é organizado e incorrido
Observe que seu arquivo EXCEL deve ser testado para obter o bit EF número 2, que indica que seu veículo é suportado apenas por armazenamento semiautomático. Agora, este não é o seu veículo correto com EF na zona 2101 e você pode encontrar estacionamento semiautomático que está errado no EXCEL.
Este não é o seu item EXCEL, que é operado para obter o bit EF nº 2, que indica que seu veículo é suportado por estacionamento semiautomático. Agora, este não é o seu veículo correto com EF na zona 2101 e você pode encontrar estacionamento semiautomático que está errado no EXCEL.
Nenhum bit 3 indica que não há transmissão automática controlada pela ECU quando não há EATN8 verde
Nenhum bit 3 indica que não há transmissão automática controlada pelo computador quando o EATN8 é real.
Como falei, não sei se funciona para todos os ESPs, no meu funciona perfeitamente. É um módulo muito delicado, qualquer alteração pode representar um risco à segurança, portanto só altere se tiver confiança. Se desejar também pode usar o software desenvolvido pelo Marc, está em desenvolvimento, mas já tem o módulo esp90 e testei no meu e funcionou tudo bem. siga o link https://github.com/Barracuda09/PyPSADiag
How did you flash it to CVM
Hello, this is the photo of my BSI, the car is 3008 2017 2.0HDi. Is it possible to install radar and code system to have ACC? By factory I have blind spot detection, High beam change, park assist I already activate and my camera is CVM2.
Hi,
I'm quite new here, I searched on this forum but I counld't fint the answer to my doubt. I own a Peugeot 3008, 12 sensors, blind spot, line keeping and rear camera. The thing is that it has a RCC wave 3, can I turn on Park assist? If yes, can some one explain me how? I saw many explanations but for NAC.
Hi,
I'm quite new here, I searched on this forum but I count't fint the answer to my doubt. I own a Peugeot 3008, 12 sensors, blind spot, line keeping and rear camera. The thing is that it has a RCC wave 3, can I turn on Park assist? If yes, can some one explain to me how? I saw many explanations but for NAC.
RCC is mostly NAC. The difference is that NAC has navigation
bsr svp esk il ya un Secured Traceability pour KWP2000 (IS - 500 Kbits)
comme uds .
hi evry one i need secured traceability for kwp2000 (IS - 500 Kbits) if There is
PКогда я установил первый cvm2 в свой 3008 II, он был именно таким, и хотя все было хорошо, он не работал, только переключение дальнего света. Он работал только тогда, когда я перешел на версию с аббревиатурой BBK. Сегодня я знаю, что аббревиатуры EK, BBK, EJ и BBJ работают со всеми опциями. Когда я поставил версию BBK, мне не нужно было ничего менять, и все работало. Возможно, в вашем случае это то же самое, что произошло со мной.
Спасибо за ответ. Можете ли вы рассказать, как вы изменили версию в своем cvm2? вы меняли софт ? или камеру целиком?
You need to modify also: DAE, AAS and BSI.
You can use my file for YAT from here https://www.forum-peugeot.com/Forum/threads/tuto-t%C3%A9l%C3%A9codage-et-calibration-dun-nac-rcc-cirocco-cmb_num -sans-diagbox-via-arduino.121767/post-2764425
I used this instruction to create the file.
I use it on Peugeot 3008 from 2018
Thank you! My Peugeot 3008 it is from 2020. I'm waiting for my arduino can shield. By let me ask you, I read your post and the one where you got the instructions, still, I don't know how to use you YAT file. Which software will read that file? Sorry if it is a noob question.
Bonjour à tous, tout d'abord je précise que j'utilise un traducteur. J'ai une 3008 gt line hdi 2.0 tiptronic 2018 avec nac wave2. Si vous pouvez m'aider, essayez de chercher, mais peut-être qu'en raison de problèmes de traduction, je ne pourrai pas trouver comment ajouter de nouvelles couleurs aux thèmes bleu et cuivre. J'ai utilisé le psa-arduino-nac mais lorsque j'ai essayé d'activer les couleurs l'icône des thèmes a disparu dans le profil. Je souhaitais également demander de l'aide pour télécharger et partager mon fichier 9692812080.cal. J'espère ne violer aucune règle du forum et je vous remercie d'avance pour votre aide et votre compréhension.
