Every file that was attached using the forum is broken, will that be fixed? I get error on every one of them
Using the software tool for the nac, with the arduino kit you can re-enable the amplify menu and trip computer.
The amplify cockpit you can activate in zone 212D and for the trip computer you will find it in zone 2125.?
Great, Iam building the arduino and already have the compiled software to load, but do you know which function exactly will enable it again?
Sorry if I am too basic but this is my first experience with NAC sofware. Thanks
All files are working here for me, make sure you are signed in to the forum.Every file that was attached using the forum is broken, will that be fixed? I get error on every one of them
Thank youThe amplify cockpit you can activate in zone 212D and for the trip computer you will find it in zone 2125.
Russian: После нескольких экспериментов выяснилось, что ошибка выскакивает только на RCC Euro.How to fix ?
First the thread is not dead, I am waiting for some frames before pushing a final.@VLud sorry for the english.
I got this work perfect for config my NAC that i used to replace smeg+ on my 2016 308. I Also manager to install the cirocco/icockpit.
All is working except i cant Change themes/modes on the cirocco. The thread regarding the sketch to make a button work for mode Change seems to BE death.
Can you help with this please? I already have both canshields if needed. My attempt was cutting the can low and can night behind the cirocco, conect to.lower shield, and conect upper shield to canH and CanL but I cant make it work.
How to fix ?
Well, cant find the epprom chip (supposed to be 95640) on the board, wtf?
Any clue anyone how to read mileage from this board (Icockpit 3008)?
@Alcor72
The epprom is below the shield you just have to remove it
It is a 95160 (ATMLP738)
Bonjour dessoler je me suis mal exprimer , donc j ai brancher tout les fils comme indiquer sur le forum après j ai essayer de faire le codage avec l Arduino , >764:664 PUIS 1003 J ai activer la camera dans la zone 2106 après j ai valider mais la camera ne fonctionne toujours pasNon, il faudrait déjà commencer par dire ce que tu as fait et expliquer clairement ton problème, autrement que par J’ARRIVE PAS À CODER
La caméra 130 ne s’affichera pas sans codage du BSI par exemple![]()
Bonjour a tous j ai installer une camera
Coding option for zone 2300XX Type d'aide au stationnement in BSI2010_EV
where XX
- 00 (aucune fonction)
01 (fonction AAS Arriere seul)
02 (fonction AAS Avant seul)
03 (fonction AAS Avant et arriere)
04 (MPD sur AAS Actif seul)
05 (MPD sur AAS avec fonction AAS Arriere )
06 (MPD sur AAS avec fonction AAS Avant)
07 (MPD sur AAS avec fonction AAS Avant et arriere)
08 (MPD sur SAM Actif seul)
09 (MPD sur SAM avec fonction AAS Arriere )
0A (MPD sur SAM avec fonction AAS Avant)
0B (MPD sur SAM avec fonction AAS Avant et arriere)
10 (Aide Visuelle au Recul seul)
11 (Aide Visuelle au Recul et avec fonction AAS Arriere)
12 (Aide Visuelle au Recul et avec fonction AAS Avant)
13 (Aide Visuelle au Recul et avec le fonction AAS Arriere et Avant)
14 (Aide Visuelle au Recul et MPD sur AAS Actif seul)
15 (Aide Visuelle au Recul et MPD sur AAS avec fonction AAS Arriere )
16 (Aide Visuelle au Recul et MPD sur AAS avec fonction AAS Avant)
17 (Aide Visuelle au Recul et MPD sur AAS avec fonction AAS Avant et arriere)
18 (Aide Visuelle au Recul et MPD sur SAM Actif seul)
19 (Aide Visuelle au Recul et MPD sur SAM avec fonction AAS Arriere )
1A (Aide Visuelle au Recul et MPD sur SAM avec fonction AAS Avant)
1B (Aide Visuelle au Recul et MPD sur SAM avec fonction AAS Avant et arriere)
23 (City Park et avec fonction AAS Arriere et Avant)
24 (City Park et MPD sur AAS Actif seul)
25 (City Park et MPD sur AAS avec fonction AAS Arriere )
26 (City Park et MPD sur AAS avec fonction AAS Avant)
27 (City Park et MPD sur AAS avec fonction AAS Avant et arriere)
28 (City Park et MPD sur SAM Actif seul)
29 (City Park et MPD sur SAM avec fonction AAS Arriere )
2A (City Park et MPD sur SAM avec fonction AAS Avant)
2B (City Park et MPD sur SAM avec fonction AAS Avant et arriere)
33 (City Park et Aide Visuelle au Recul et avec fonction AAS Arriere et Avant)
34 (City Park et Aide Visuelle au Recul et MPD sur AAS Actif seul)
35 (City Park et Aide Visuelle au Recul et MPD sur AAS avec fonction AAS Arriere )
36 (City Park et Aide Visuelle au Recul et MPD sur AAS avec fonction AAS Avant)
37 (City Park et Aide Visuelle au Recul et MPD sur AAS avec fonction AAS Avant et arriere)
38 (City Park et Aide Visuelle au Recul et MPD sur SAM Actif seul)
39 (City Park et Aide Visuelle au Recul et MPD sur SAM avec fonction AAS Arriere )
3A (City Park et Aide Visuelle au Recul et MPD sur SAM avec fonction AAS Avant)
3B (City Park et Aide Visuelle au Recul et MPD sur SAM avec fonction AAS Avant et arriere)
63 (City Park AMSP et avec fonction AAS Arriere et Avant)
64 (City Park AMSP et MPD sur AAS Actif seul)
65 (City Park AMSP et MPD sur AAS avec fonction AAS Arriere )
66 (City Park AMSP et MPD sur AAS avec fonction AAS Avant)
67 (City Park AMSP et MPD sur AAS avec fonction AAS Avant et arriere)
68 (City Park AMSP et MPD sur SAM Actif seul)
69 (City Park AMSP et MPD sur SAM avec fonction AAS Arriere )
6A (City Park AMSP et MPD sur SAM avec fonction AAS Avant)
6B (City Park AMSP et MPD sur SAM avec fonction AAS Avant et arriere)
73 (City Park AMSP et Aide Visuelle au Recul et avec fonction AAS Arriere et Avant)
74 (City Park AMSP et Aide Visuelle au Recul et MPD sur AAS Actif seul)
75 (City Park AMSP et Aide Visuelle au Recul et MPD sur AAS avec fonction AAS Arriere )
76 (City Park AMSP et Aide Visuelle au Recul et MPD sur AAS avec fonction AAS Avant)
77 (City Park AMSP et Aide Visuelle au Recul et MPD sur AAS avec fonction AAS Avant et arriere)
78 (City Park AMSP et Aide Visuelle au Recul et MPD sur SAM Actif seul)
79 (City Park AMSP et Aide Visuelle au Recul et MPD sur SAM avec fonction AAS Arriere )
7A (City Park AMSP et Aide Visuelle au Recul et MPD sur SAM avec fonction AAS Avant)
7B (City Park AMSP et Aide Visuelle au Recul et MPD sur SAM avec fonction AAS Avant et arriere)
80 (Vision Latérale Japon (VLJ) seule)
81 (VLJ, AAS_AR)
82 (VLJ, AAS_AV)
83 (VLJ, AAS_AV, AAS_AV)
84 (VLJ, MPD_AAS)
85 (VLJ, MPD_AAS, AAS_AR)
86 (VLJ, MPD_AAS, AAS_AV)
87 (VLJ, MPD_AAS, AAS_AV, AAS_AR)
88 (VLJ, MPD_SAM)
89 (VLJ, MPD_SAM, AAS_AR)
8A (VLJ, MPD_SAM, AAS_AV)
8B (VLJ, MPD_SAM, AAS_AV, AAS_AR)
90 (VLJ, AVR)
91 (VLJ, AVR, AAS_AR)
92 (VLJ, AVR, AAS_AV)
93 (VLJ, AVR, AAS_AV, AAS_AR)
94 (VLJ, AVR, MPD_AAS)
95 (VLJ, AVR, MPD_AAS, AAS_AR)
96 (VLJ, AVR, MPD_AAS, AAS_AV)
97 (VLJ, AVR, MPD_AAS, AAS_AV, AAS_AR)
98 (VLJ, AVR, MPD_SAM)
99 (VLJ, AVR, MPD_SAM, AAS_AR)
9A (VLJ, AVR, MPD_SAM, AAS_AV)
9B (VLJ, AVR, MPD_SAM, AAS_AV, AAS_AR)
A0 (VLJ, CP)
A1 (VLJ, CP, AAS_AR)
A2 (VLJ, CP, AAS_AV)
A3 (VLJ, CP, AAS_AV, AAS_AR)
A4 (VLJ, CP, MPD_AAS)
A5 (VLJ, CP, MPD_AAS, AAS_AR)
A6 (VLJ, CP, MPD_AAS, AAS_AV)
A7 (VLJ, CP, MPD_AAS, AAS_AV, AAS_AR)
A8 (VLJ, CP, MPD_SAM)
A9 (VLJ, CP, MPD_SAM, AAS_AR)
AA (VLJ, CP, MPD_SAM, AAS_AV)
AB (VLJ, CP, MPD_SAM, AAS_AV, AAS_AR)
B0 (VLJ, CP, AVR)
B1 (VLJ, CP, AVR, AAS_AR)
B2 (VLJ, CP, AVR, AAS_AV)
B3 (VLJ, CP, AVR, AAS_AV, AAS_AR)
B4 (VLJ, CP, AVR, MPD_AAS)
B5 (VLJ, CP, AVR, MPD_AAS, AAS_AR)
B6 (VLJ, CP, AVR, MPD_AAS, AAS_AV)
B7 (VLJ, CP, AVR, MPD_AAS, AAS_AV, AAS_AR)
B8 (VLJ, CP, AVR, MPD_SAM)
B9 (VLJ, CP, AVR, MPD_SAM, AAS_AR)
BA (VLJ, CP, AVR, MPD_SAM, AAS_AV)
BB (VLJ, CP, AVR, MPD_SAM, AAS_AV, AAS_AR)
E0 (VLJ, CP_AMSP, CP)
E1 (VLJ, CP_AMSP, CP, AAS_AR)
E2 (VLJ, CP_AMSP, CP, AAS_AV)
E3 (VLJ, CP_AMSP, CP, AAS_AV, AAS_AR)
E4 (VLJ, CP_AMSP, CP, MPD_AAS)
E5 (VLJ, CP_AMSP, CP, MPD_AAS, AAS_AR)
E6 (VLJ, CP_AMSP, CP, MPD_AAS, AAS_AV)
E7 (VLJ, CP_AMSP, CP, MPD_AAS, AAS_AV, AAS_AR)
E8 (VLJ, CP_AMSP, CP, MPD_SAM)
E9 (VLJ, CP_AMSP, CP, MPD_SAM, AAS_AR)
EA (VLJ, CP_AMSP, CP, MPD_SAM, AAS_AV)
EB (VLJ, CP_AMSP, CP, MPD_SAM, AAS_AV, AAS_AR)
F0 (VLJ, CP_AMSP, CP, AVR)
F1 (VLJ, CP_AMSP, CP, AVR, AAS_AR)
F2 (VLJ, CP_AMSP, CP, AVR, AAS_AV)
F3 (VLJ, CP_AMSP, CP, AVR, AAS_AV, AAS_AR)
F4 (VLJ, CP_AMSP, CP, AVR, MPD_AAS)
F5 (VLJ, CP_AMSP, CP, AVR, MPD_AAS, AAS_AR)
F6 (VLJ, CP_AMSP, CP, AVR, MPD_AAS, AAS_AV)
F7 (VLJ, CP_AMSP, CP, AVR, MPD_AAS, AAS_AV, AAS_AR)
F8 (VLJ, CP_AMSP, CP, AVR, MPD_SAM)
F9 (VLJ, CP_AMSP, CP, AVR, MPD_SAM, AAS_AR)
FA (VLJ, CP_AMSP, CP, AVR, MPD_SAM, AAS_AV)
FB (VLJ, CP_AMSP, CP, AVR, MPD_SAM, AAS_AV, AAS_AR )
>752:652
222300
>752:652
:B4E0:03:03
2E2300XX
Sure, but full tuto will be released with a final version, when it will be only plug & play, actually that’s not possible cause the published program is not the final release.[QUOTE = "Keryan, post: 2656538, member: 126947"] First the thread is not dead, I am waiting for some frames before pushing a final.
Second, you have all you need on this thread to do it, you and the other asking me everyday, you should all open your eyes, I think you're all blind
Regards [/ QUOTE]
I cant answer for other person but im not blind. I Said dead thread because it doesnt have any answer there for months, it has two Pages, One beta tester and a guy that couldnt make it work. On the OP you redirect to a [USER = 108646] @VLud [/ USER] thread for an adapter to bsi2004 to 2010.
Not all people understand Arduino like you and others.
Reading this thread i was able to do just fine the Arduino + shield to calibrate config NAC and cirocco.
Regarding the button for mode Change o dont know what to do and ive made an effort. I have two shields, Arduino, tried behind cirocco, behind NAC. Nothing.
I admire your work but a full Tutto for that would be perfect.
Yes possible and also was here explained where to edit and what to use , You just din't read the full thread or skipped the pagesOk thanks, i see this IC under the shield but ,i was not sure it s the eeprom. So it s possible to read with programmer like pony and other , but i m don't khnow how identify the mileage on the dump. Somebody have an idea ?
