1.2.1 released, fix for Wave3/4 car type, a lot of "old" cars are present inside the non-HD version (I didn't list everything, it is time wasting):
Je viens d'essayer sur mon C4 Picasso II, ça fonctionne très bien, ça vient donc bien de ma version de mon CIROCCO
@Tiph , si tu as accès à DB, pourquoi ne pas tester directement depuis la avec un vin qui va bien avec. Dans le pire des cas, reprend ton vin pour télécoder à nouveau ton combiné
Hi, this is my NAC and CIROCCO original files of my C4 Grand Picasso II Shine (2017), hope that it can help youHi Tiph, does your C4 Picasso II have NAC as a native system? If so, could you tell me if your CIROCCO panel has the automatic backlight working and share the configuration downloaded through the tool? Thanks in advance.
Ok merci pour la réponse! Oui effectivement c'est une version hors ligne (d'ailleurs pour certains télécodages j'ai un message pas de connexion internet qui apparait)@Tiph : Le sketch est bon c'est juste l'appli que je dois mettre à jour, mais la détection des variantes est un point assez embêtant
Diagbox 9.68 = version hors ligne = aucun télécodage car tout est déverrouillé en ligne
[QUOTE = "Miguel Angel, post: 2586474, member: 129980"] [USER = 130538] @Ringelberg [/ USER] [USER = 128842] @ James78 [/ USER], I also have the calibration 9692618180 and the cirocco attenuates very little, almost negligible, but something does attenuate. Surely as Ringelberg says, it is something from the calibration file, or some reading address that can be configured by arduino, since there are many more addresses that can be read and they are not in the Vlud program. Let's not forget that it is a first version of the software and there may still be updates that include this and other points to adjust. [/ QUOTE]
I anyone is interested. In the config file of the cirocco the fifth number of the 0200 line is the brightness setting for the cirocco at night.
like the 5 in the example: 0200=A0305
if someone can share me a config file of a cirocco that auto dimms i can look if i can find the setting on autodimm.
just checked and writing 1 dimm the display and radio. Can be 7-brightest 1-lowest but found that's 8 and 0 is more darker than 1My CIROCCO has the value of the fifth digit of line 0200:
0200 = A0307
In my case, the instrument cluster dims almost negligibly. While in the file posted by Tiph I see a value of 1:
0200 = A0301
if @Tiph confirms that his C4PII has the automatic brightness of the qaudro instruments, maybe we have solved it.
