Woow super boulot, mille bravo !!
C'est compatible avec un E 2008 2020 ? On peut faire des choses avec ?
Cordialement,
Cordialement,
merci pour votre réponse rapide ! sujet vraiment intéressant et passionnent ! merci encore !@abdelfettah : La même chose que @Tiph (voir ses posts)
Seems like i bricked my head unit by changing themes settings.
Under 2127: Telecoding_Fct_HMI i had enabled all eveilible themes, an then attempted to select one of those themes in configuration menu of head unit. For first 3 it was ok (blue, copper and red) but 4th was blank, it selected ok but nothing changed. And next day when i turned on my car, "Ambiance not configured" message was stuck on my screen (while music from usb was playing and wheel keys worked fine).
I still can change settings with arduino and i aatempted to disable themes or upload saved settings, but nothing helped.
Is there any way to reset user and theme settings to stock values? Any advice?
I just broke RCC in Toyota : cry:
After i change in 2127 default Ambience i when it's booting i see only this screen.
"Ambience not configured"
I suspect that i have to do factory reset but how?
I try to Restore backup for configuration. No change
I did. Unfortunately still not working. Reuploaded saved settings - also did nothingsee if you have configured default theme depending of car 0/1/2/3/4
These are the instrument cluster dumps of the C4GP I purchased. With a simple comparison program you can identify the lines that have been modified. Does your instrument cluster come from a C4P or C4GP? In the case of a C4P could you share the extracted dump?
check nr of your callibration and send it again to unitI did. Unfortunately still not working. Reuploaded saved settings - also did nothing
thx @VLud you cal file is added https://github.com/ludwig-v/arduino-psa-nac_rcc_cirocco/tree/master/Calibrations/RCCmine nr is 9692987580 there is no cal file with such nr here
Are you talking about navigation? If yes, you should replace your RCC with NAC.how can enable this ?
If you see this sign, you can have lane assist camera. You can enable it from car settings.
- This is my car
when @jordan87 locked own RCC they restored this config from the post https://www.forum-peugeot.com/Forum/threads/tuto-télécodage-et-calibration-dun-nac-rcc-cirocco-sans-diagbox-via-arduino.121767/page-21#post-2581477Head unit just refuses to accept calibration
> 1001
< 500100C80014
> 1002
< 500200C80014
> 2701
< 7F2783
seems like those guys with official tools were right. headunit gone for good(
ask @jordan87 what they modified
you can't delete calibration when you din't getting key for unlock of download , first is unlock then erase command
check 2108 what you have in default theme (number)
you car is with Cirocco display? or analog speedo cluster?
I do have access to parameters and can change any of those. But i can't upload calibration. When i try to upload calibration i always recieve 7F2783you can access parameters? very hard to comunicate with you ... what sketch you use? 1.4
