https://mega.nz/file/akdnkYTa#TsZ_dIJI5v5bekMuPKP6Ujk84jbUoiRe-ZF5FXU0EZEWill you give me a link? For older versions.
Thank you so much. loaded. Only the dashboard blinks.
i think is just overkill what you think to do and you can't add all options as some bytes are HEX and some Binary , diagbox just show you is possible or not to write ,with simulator they will accept everything and make no sense , as for every ecu is minimum few or several calibration /flash /+configs
how you stuck with dnx flasher logo? you loaded .ulp or .cal file
try load the reference .cal you have before
what you tried to do loading .cal/.ulp files? this changes nothing on display
Hi Guys,
I've just turned on the AA CP functions in my RCC Wave 2.1 and I have icons on menu but I can only connect with CP. When I try connect with AA my phone doesn't respond. I receive only information about connection with MirrorLink. I upgraded software from 073C to 076C and I still can't connect with AA. Any ideas?
means you trying upload .cal not compatible with your unit...Hi, after a long time I tried to change the calibration of my NAC to check some improvements, but it doesn't goes on. It starts to download and then stucks. I tried multiple times but it arrives max at 36% and then stops. Someone had the same problem? Any solutions? Thanks.
You have to change the FMUX tooBonsoir à tous,
Ça y est j’ai sauté le pas et commande un gps pour replacer mon autoradio sur 2008 (sans gps) par un avec GPS qui vient d’un autre 2008
me confirmez vous que c’est possible ?
j'espère que ma demande est suffisamment claire
celui ci que j’ai actuellement Voir la pièce jointe 21810
Celui ci c’est le futurVoir la pièce jointe 21811
What do you mean by FMUX ? This partYou have to change the FMUX too
Попробуй на заглушенном автомобиле.It's strange because it happens with all files... included files that I have already uploaded in the past in the same unit...
English: Try it on a dead car.
Yes and I have one available.What do you mean by FMUX ? This part
Bonsoir Keyran,Yes and I have one available.
PM me for more information
Tu dois changer l’écran et le poste autoradio au passage, les deux.
Yes, j’ai tout et même de quoi installer d’autres options, mais il faut que je puisse accéder aux différents calculateurs ce qui n’est pas le cas pour le momentTop! Tu as l’écran 10’ aussi ?
Si qqn d’autre cherche un ensemble complet d’upgrade pour 208/2008 comme @nabil2106 j’en ai un![]()
@VLud
Pouvez-vous m'aider ? Je n'arrive pas à écrire dans mon AAS !
Je n'arrive pas à le débloquer...
Merci !
:xxxx: 01: 02
:xxxx: 01: 02"7F = Negative response@marcins
OK, thanks. It's curious not to be able to write anymore...
I have a write log on this ECU, with DB 7.62 by choosing Peugeot 309
DB had changed BD to A5
75D:2703 Unlock Calculo
65D:6703DC29FD74 Key
75D:27046DEB7F5F Calculated Key
65D:6704 Key OK !
75D:2E2101A5 Write A5 in 2101
65D:7F2E78 Configuration Write in progress
65D:6E2101 Well write A5 in 2101
75D:222101 Read 2101
65D:622101A5 Well read 2101 = A5
I don't understand this sentence :
"where key is valid as you can unlock for download:xxxx: 01: 02"
Thanks for your help !
Bonsoir
Quelqu'un sait dans quel endroit sur l'arduino on peut réactiver le nom de la source sur la matrice ?
