It was returning to blue theme. But, I don't have this issue anymore.
What need to be done:
Having the same number of activated theme on NAC and cirocco (in my case 3)
Only the 2 first theme on NAC will be persitent after car restart(I think it is because 3008 cirocco only have 2 theme)
If you use the 3rd NAC theme it will go back to theme 2 after restarting the car.
When you choose;
  • theme 1 in NAC (purple) you will have theme 1 on cirocco (blue)
  • theme 2 in NAC (red) you will have theme 2 on cirocco (bronze)
  • theme 3 in NAC (gold) you will have theme 2 on cirocco (bronze) but not persistent after retsart (go back to NAC 2 / cirocco 2)
Take a closer look at canny.ru products. it works stably in automotive conditions. There are ready-made gates.
Try to change calibration at your NAC. It was help me with Cirocco from 3008.
For the arrow problem in navigation mode, you probably have a bad calibration / configuration of the nac, first try to set calibration and configuration of 508 and see if the problem still arises
After changing the calibration to Peugeot 508, the map was resized to fit the 508 cluster.
However, the main screen became all black, no information showed.
After that, I used the @VLud Zones Table and edited the 011B zone to match the older calibration.
Now everything looks fine.
I'll perform more tests to make sure that all functions are working as expected.
@Laleksss, @nico1080 and @RuLe thank you very much
Reactions: RuLe and Laleksss
Hi,
I have a C5x7 with Nac w2
Nac has Peugeot 208 configuration installed
Is it possible to change Wave 2 Sd for Wave 3 HD on a 7" screen?
Thanks
Hi,
Thanks
I just changed wave2 for wave 4 sd, I have put custom Peugeot 208 configuration, and I have achieved improvements in the menu key, which changes between the main fields, although I had to modify the sketch because it did it in an uncontrolled way. I have also not found a similar saloon model to place in the images, right now it is left as a Peugeot 508 brand on my Citroen C5X7.
No, you dont need to modyfy anything on BSI. For checking, you can replace canMsgSnd.data[0] = 0xFF; in sketch to canMsgSnd.data[0] = 0x05; - if your scirocco and nac settings is ok, you will see some sign (as I remember - 5 KMH) on scirocco in the place, where NAC has no any information of the speed limit (and speed limit is not showed at the nac).
About resistor - sorry, but I don't know. In the sketch i was wrote:
// No support No question please //
Thank you, is working perfect!
Reactions: Laleksss
i have my diag adapter working now
can someone tell me where to get the cirroco calibration program i used it once but can no longer find it
thank you
Dear Friends! I'm started to learning the procedure based on the first page from Vlud (big respect) but I have some doubt Can somebody explain for me what do I need to do in this step?
Etape 2 - Modification de la Shield
Ajoutez de l'isolant (ruban adhésif, etc) sous le connecteur DB9 (1) pour éviter le contact des PINs du connecteur avec la masse du port USB de l'Arduino (qui est juste en dessous).
Mettez également l’interrupteur sur OFF si vous n'utilisez pas ce port.
La résistance de terminaison de 120 Ohms (terminaison resistor) doit être activée sur votre carte (P1 non coupé sur v2.0 - rien à toucher -, Jumper J1 connecté - soudure ou cavalier - sur module 8Mhz)
Is there anybody who has a video from the procedure, started from sitting in the car and change some parameter, save it etc...it would be a big help to see how it works
Many thnks
Regards
Hello, Thanks to this usefull tool I was able to properly telecode the standard NAC w3 I had at home for DS3 since it's original unit after 42.x software update has lost all the images of the ds3.
I bought a standard w3 NAC from peugeot partner, changed the calibration and manually enabled all the important things. I'm actually using the original ds3 capacitive display but it's possible to use a 208/2008 display too by changing a simple value inside the screen configuration to change the resolution otherwise artifacts will appear on the screen.
I have included the dump of my configuration to share with you.
Thanks again to my friend Vlud.
Hi,
Could you please send me the reference of the ds3 capacitive display ?
Thank you
Dear Friends! Is it necessery during the telecoding procedure to run the engine or ignition in is enough?
Question simple: Est ce qu'il est possible avec l'outil de passer un NAC Wave4 d'un 5008 de 2021 avec le theme de DS (au lieux des deux peugeot Blue et Copper) que je trouve plus joli ?
MErci
please help
when i try to upload the arduiono pasa diag.ino file i have a lot of errors, for example:
arduino-psa-diag-low-speed:157:68: error: stray '\302' in program
<title>arduino-psa-diag/arduino-psa-diag-low-speed.ino at master · ludwig-v/arduino-psa-diag · GitHub</title>
arduino-psa-diag-low-speed:157:69: error: stray '\267' in program
what is the problem?
Etape 6 - Compiler le Sketch Arduino
Récupérez le sketch arduino-psa-diag.ino (Version 1.9 - 10 / 01 / 2022)
Vous avez le choix entre copier le code source depuis le RAW et enregistrer le fichier .ino ou bien récupérer le ZIP du master pour directement récupérer le .ino et les ZIP des librairies
Open RAW with browser, copy all content and paste in artduino scetch. Another way is download ZIP and unzip, and get file from arduino-psa-diag-master folder.
Köszönöm Barátom türelmét és segítségét. A RAW fájl feltöltve
Van Arduino Uno és CB shield 2.és szeretném használni egy vadonatúj 5008-ban.
2 kábelt fogok használni az oldalsó csatlakozótól az OBD2 + földhöz
Egy régi bejegyzésben Mike azt mondta, hogy karcolja meg a P1 portot, és az megöli a 120 ohmot.
Említette ezt? /mivel nincs más P1 port/
Köszönöm.
szóval melyiket kell levágnom?[/ATTACH]
Pièces jointes
    574.7 Ko · Affichages: 79
Many thanks Vlud. The google translation was so ambiguous. From the original tutorial. So i will not cut it
MErci
Hello,
C'est possible sur Wave 2 donc c'est plus que probable que ce le soit aussi sur Wave 4 ;).
I have mounted a windshield dab antenna and I have activated the dab option in nac (wave 2) with the Vlud App.
Now it does tune to dab stations, but the volume is lower than the normal antenna. Are there any other settings I haven't seen?
Hello,
please forgive me as I do not speak French, I'm the developer of a tool called VXUtility, it is aimed only at Vauxhall / Opel models but I am implementing support for PSA models such as Grandland X / Corsa-F with NAC units.
I have found your github extremely useful and it has taught me much but I am having some issues I hope you can help with.
on NAC unit I write 2E210680 and camera is enabled on NAC no issues, however when I try activate on BSI in zone 2300, it acknowledges that it has wrote the value successfully, then when I read it again about 30 seconds later it's either not the correct value or exactly the same, do you have any ideas? Here is my log:
[04:26:31.119] RX: 752
[04:26:31.119] TX: 00-00-07-52-27-04-1F-6C-75-6B
[04:26:31.141] RX: 652 6704
[04:26:31.184] TX: 00-00-07-52-2E-23-00-11
[04:26:31.184] RX: 752
[04:26:31.209] RX: 652 6e2300
[04:26:31.211] TX: 00-00-07-52-22-23-00
[04:26:31.212] RX: 752
[04:26:31.233] RX: 652 62230011
[04:26:31.235] TX: 00-00-07-52-2E-29-01-FD-00-00-00-10-0C-15
[04:26:31.239] RX: 752
[04:26:31.259] RX: 652 6e2901
[04:26:31.261] TX: 00-00-07-52-10-01
[04:26:31.262] RX: 752
[04:26:31.286] RX: 652 500100c80014
[04:26:31.288] TX: 00-00-07-52-11-42
[04:26:31.288] RX: 752
[04:26:31.312] RX: 652 5142
Thanks!
Hello,
Thanks!
as you writing in the ram , switch off for 3min and power on then check..
