Hi,
I have successfully tried changing the language in bta3s with the following commands in arduino:
>77C:67C ==> Arduino Answer: OK
2º : DC3B:83:C0 ==> Arduino Answer:
50C0
678376817681
6784
21B5 ==> Arduino Answer:
61B58100010001
3BB50C03010001
The BTA3s speak in spanish and diesel fuel.
I checked with diagbox and I have the F303 error in Bta ecu.
The SOS light is on orange, it does not turn off
It seems I have to write the zone A0 as indicated on Vlud's GitHub, but I don't know what commands I should indicate in Arduino:
https://github.com/ludwig-v/arduino-psa-diag/tree/master
KWP
After each configuration writing you must write A0 zone for the so called "Secured Traceability" to avoid F303 DTC error in the ECU
Command
Zone
Site
Day
Month
Year
Number of secured writings
Number of non-secured writings
3BA0FFFD0000000101012A00
WriteTraceabilityAftersalesFactory01January2001420
Number of secured writings "should" be increased after each writing
Quick & dirty command that works everytime:
3BA0FFFD0000000101010000
I have also tried to eliminate the F303 error without success with the following command:
>77C:67C
: DC3B:83:C0
Could someone tell me what codes I have to put in Arduino to write the A0 security zone?
Thanks
Hi,
can anyone help?
Thank you
Yes, with the Arduino.
For NAC:
Code:
>764:664
1003
22212B
For Cirocco:
Code:
>75F:65F
1003
222100
NAC
500300C80014
62212B748080FC30320FE0403F4CC46017060800000000000000030F050A2400000000000407091A10000000000015181C2200000000000016000FA0CA008015C6FEDFD200C09A00143090561EE00114840080C1109210C0180004101C2834404C5864B00000AF380802001E003AE011C0A04CF05CB428B41EB428100E440BF4033E070801C70708030502BB068B02580804020807D0804002560001F300777269000064648806F4EC77C03401C03060700018C0800000
Cirocco
5003
62210074C09C0C000000000000008F6680803B8803A3078080
Aqui está o resultado dos dois comandos.
Obrigado
Actually you can turn off both DRLs from the touchscreen, I had to change some other zone information in order to make the DRL toggle in NAC to function properly. Can send you those if you want to.
I will be grateful.
Regarding Sound Harmony, sadly I could not enable it. 23B4 is set to 01, same with the NAC but no Sound Harmony menu..
There is no zone 23B4 in my BSI. I can only change "sound harmony" by changing zone 23AB. In NAC it's the same as in yours.
hello
j'ai activé les thèmes sur nac wave 4 mais j'ai un problème quand je démarre le thème bleu reviens par défaut si quelqu'un av une solution je suis preneur
Hello
I activated the themes on nac wave 4 but I have a problem when I start the blue theme comes back by default if anyone has a solution I am interested
hi, marcins, i need your help please, To install i-cockpit 3008__2023 On a Peugeot 208 from 2016, there was a problem with the tightness of the mounting valve Although the dashboard has been modified
never seen 2023 cockpit , so you willbe first with this install...
hello
Hello
quelqu'un de sympa svp me repondre merci
Yes possible and was explained few times here , search FMUX in this thread
Hi,
Thank you for your response, I studied the entire topic from the 1st post to the word fmux, unfortunately I did not find any calibration for Toyota Proace that activates the buttons. But I found a post by my friend Vlud who posted such a calibration for the Peugeot 508. Will I damage the unit or the car by uploading this file? I also read information about the line that is responsible for the type of buttons - 010E - but I don't know what to change in it to make the calibration from the NAC catalog for Toyota Proace work? Thank you for your help
NAC
500300C80014
Cirocco
5003
Obrigado
@rui.saraiva
Hi,
yes read the fmux zone in old unit 010E and write in new unit
Reactions: Bult
Can anyone explain step by step how to read lines 010E from the old navigation and add them to the configuration file so that the buttons work in the new NAC unit?
if you loaded .cal for Proace and is not working means something not connected on fmux maybe you forgot to connect cable as proace and expert share same fmux setting.. check cables from frame where you have buttons.
hi marcins, You have installed i-cockpit 3008
in your car 208 GTI I want to know how to install it in the counter location counter....
yes but older plastic frame where can be easy cutted etc , you can't just fit stright it without rework
Hi marcins ,I made modifications to the dashboard at the bottom. I only inserted a screen without the electronic card. However, when the front side of the dashboard is installed, the entire data on the i-cockpit does not appear.
Don't know how to help you as is custom job , i have cuted so much until i can fit the unit....
Help please @VLud @marcins
j'ai changer ma calibration 9693638280 par Calibration 508_R8-9693370980.cal j'ai eu un problème sur la camera panoramique
qualité vraiment médiocre en plus des traits sont pas comment avant j'ai mis camera 180 il ajouter un trait de plus comme j'avais avant voir les photos merci d'avance
I changed my calibration 9693638280 to Calibration 508_R8-9693370980.cal I had a problem with the panoramic camera
really poor quality in addition to the lines are not like before I put camera 180 it add one more line like I had before see the photos thank you in advanceIMG_0967.jpgIMG_0968(1).jpgCapture d'écran 2024-05-09 144231.jpgIMG_0966.jpg
It is not a fault of the connection, because the knob (volume, power on/off) works but not properly. When pressed, the radio is muted instead of turned off. I ask again how to read the 010E parameters from the old unit in order to upload them to the new navigation as .cal?
Cruise control Malfunction: After changing the Cirocco to a new 2023 Cirocco whit metal backing and after made some changes in order to show multimédia info on Cirocco, must have messed up something because my cruise control is not working at 100%.
I can set the speed I want, increase or decrease it using the control behind the steering wheel, but if the CVM detects a sign indicating a higher or lower speed than the speed I am going, I cannot set the cruise control to take over the detected speed.
The message "mem" appears next to the speed/cruise control icon, but when I press the "mem" button on my control, nothing happens.
Already loaded backup that i made before but didn´t fix`it.
I´ve loaded original configs but the result is the same. Been looking all over the zones with vlud´s app but can´t see what is wrong to preventing the cruise control from working normally.
P.S. I don´t have radar, just normal cruise control, now without memorizing the speed recognized...
2017 Peugeot 3008 2.0 GT with Wave4 nac
@marcins @rui.saraiva @VLud
Thank you for any help.
really poor quality in addition to the lines are not like before I put camera 180 it add one more line like I had before see the photos thank you in advanceVoir la pièce jointe 36489Voir la pièce jointe 36490Voir la pièce jointe 36491Voir la pièce jointe 36492
SVP PLEASE HELP
You can try in this way:
Use Arduino app or another terminal app to read the zone from old unit.
>764:664
1003
22010E
1001
Open .cal file you want to upload to new unit in notepad++.
Find this zone and edit it with data from old unit.
Thank you all for your help, the problem with the buttons not working was the air conditioning panel not being connected. I don't know what it has to do with anything but now everything works. Regards
good morning. I'm involved in another modification, I'm going to change the halogen headlights and put in the LED front fog lights, along with the Corning function. Let's see if you can help me with the Arduino coding? thank you
Hello there
After mounting a nac w4 hd with 10 inch screen on my 3008 and coding it with arduino
All is working only 3 problems
1)
Rear camera view issue, I tested the config of vlud but when I activate reverse, the camera activates automatically, but in the "zoom rear view" mode when it should be the "standard rear view" mode. , I tested differents conf, but impossible to have the "standard rear view" mode by default
2)
Impossible to activate the diagnostic button, it remains grayed out
3)
I can't activate the nac themes
I check the right boxes but I don't even have the theme choice button in profiles anymore.
attached photos of the problems encountered as well as the config on arduino
Thanks a lot for your help
Pièces jointes
    255.1 Ko · Affichages: 26
    300.8 Ko · Affichages: 25
