Faut pas faire fuir le client… le micro paiement est sans douleur, mais attention à effet boule de neige !Tu serais mauvais au niveau marges, toi ! Multiplie tes prix par 10 à minima, voyons
openssl smime -verify -in MediaHeader/MediaVersion.ini -signer Certificates/PSA-OVIP-CS-G1.crt -noverify
> openssl smime -in MediaHeader/MediaVersion.ini -pk7out | openssl pkcs7 -print_certs -text | head
Certificate:
Data:
Version: 3 (0x2)
Serial Number: 14 (0xe)
Signature Algorithm: sha256WithRSAEncryption
Issuer: C=FR, L=Paris, O=PSA Peugeot Citroen, OU=Certificate Authorities, OU=(c) PSA Peugeot Citroen - For authorized use only, OU=0002 319187308, CN=PSA - OVIP - Code signing - G1
Validity
Not Before: Nov 3 14:38:04 2021 GMT
Not After : Nov 3 14:38:04 2024 GMT
Subject: C=FR, L=Paris, O=PSA Peugeot Citroen, OU=Open Vehicle Infotainment Platform, OU=(c) PSA Peugeot Citroen - For authorized use only, CN=Continental \/ NAC \/ 1
Subject Public Key Info:
Public Key Algorithm: rsaEncryption
Public-Key: (2048 bit)
[MediaHeader]
; Up to 18 characters
MediaVersion=001315031613548831
; Up to 32 characters
MediaCreationDate=20210217090032
; Up to 64 characters
Description=21.08.87.32_NAC-r1
; Path to the license key or leave empty if not available.
; Path example: $(MEDIAROOT)/license/license_$(uin)_$(mediaVersion).key
LocalEncryptionKeyLocation="$(MEDIAROOT)/license/license_$(uin)_$(mediaVersion).key"
; URL where the key can be found
ServerEncryptionKeyURL="$(ATT_OTA_URL)LicenseDownload?mediaVersion=$(mediaVersion)&uin=$(uin)"
; The hash of the HashList.ini file
HashListChecksum=8b9f5a2431573b2bcf92db9b42c7c05e46260fe1d084606a02ff2213ae498c34
Verification failure
[MediaHeader]
Verification successful
Certificate:
Data:
Version: 3 (0x2)
Validity
Now they just have to do the same with the firmware for NAC Wave 1 and Wave 3...
Yes, it works.Any one make the test to tell is the new filew work??
Pour ma curiosité, tu me diras si tu as le clavier grec.thanks !!I try it
Résultat de la mise à jour
Avant :
Après :
Voir la pièce jointe 29687 Voir la pièce jointe 29688
Ca semble bon !
cependant la dernière version daterait donc de Février 2021 ?
pour info, y a il des patchnote des versions depuis 2018 quelque part ?
Pour mon info personnel, sur le SMEG+ la mise à jour permettrait "d'optimiser" en proposant entre autre une défragmentation (sic!) et souvent le système paraissait plus rapide après une mise à jour.@vebririonC'est pourquoi il faut bien répéter que pour ceux qui sont déjà au niveau 21.08.87.32, il n'y a strictement aucun intérêt à installer cette version juste parée de nouveaux certificats. D'ailleurs les canaux de diffusion habituels (MyPeugeot, Peugeot Update...) ne leur proposeront pas.
Par curiosité, tu as encore les lignes dans la camera de marche arrière après l'update ?
je te confirme, j’ai les lignes sur la caméra arrière et avant aussi
