please help! I already made the 360 switchboard detect me but now it.
https://photos.app.goo.gl/WyzYDcoG3jYKmFHL6
@Albatros24 @nico1080 @Alcor72
I installed the NAC WAVE 2 on my Peugeot 508 RXH HYbrid4 2012.
The VISIOPARK 2 is connected to the NAC and the BSI.
The NAC is set to PANORAMIC ASSISTANCE.
I haven't set anything in the BSI yet, neither via Arduino nor via Diagbox.
When I put the car in reverse, only the parking assist image is displayed, no camera view.
However, in the NAC menu, I do have the 360 option, but when I press it, nothing happens.
What should I do?
Zone D540 : Aide Visuelle Panoramique
BSI : Modifier Zone D540 : Remplacer 00 par 01
>752:652
1003
---- Lecture ---------
22D540 -> 00
1001
>752:652
1003
---- Ecriture --------
:B4E0:03:03
2ED54001
2E2901FD000000010101
---- Vérification ----
22D540 -> 01
1001
"2105": {
"name": "Telecoding_Fct_AVP",
"name": "DUO",
"extra_name": "PVC_TYPE_001",
"detail": {
"fr": "Type de caméra d'aide visuelle panoramique",
"en": "Type of panoramic visual assistance camera",
"ru": "Тип панорамной камеры визуальной помощи"
"pos": "05",
"mask": "18",
"maskBinary": "00011000",
"listbox": [
"value": "00",
"text": {
"fr": "Caméra d'aide visuelle panoramique",
"en": "Panoramic visual assistance camera",
"ru": "Панорамная камера визуальной помощи"
"value": "08",
"text": {
"fr": "Caméra d'aide visuelle au recul 180°",
"en": "Virtual reversing assistance camera 180°",
"ru": "Виртуальная камера заднего вида помощи 180°"
"value": "10",
"text": {
"fr": "Caméra d'aide visuelle à la manoeuvre",
"en": "Reversing assistance camera",
"ru": "Камера помощи при движении задним ходом"
"size": 1
"name": "E82",
"extra_name": "PANORAMIC_VC",
"detail": {
"fr": "Présence de la caméra d'aide visuelle panoramique",
"en": "Presence of the panoramic visual assistance camera",
"ru": "Наличие панорамной камеры визуальной помощи"
"pos": "05",
"mask": "04",
"maskBinary": "00000100",
"size": 1
Hello!
I coded my VP with arduino and it works ok, but the image is not costructed when i am moving around. Tried a calibration file for C4 cactus but it says that the file is invalid. What can be the cause?
212A in which module?I saw somewhere in this topic that zone 212A is responsible for capturing the image, but i cannot determine which parameter. Help please?
My C5 was not pre-wired!
For the ParkAssist, you NEED 12 sensors, ok?
If you have the same calculators as me:
Code:DAE_BVH2: Modify Zone A0: Replace DD by CC ======== >6B5:695 81 21A0 -> 61 A0 05C0DD0002000000 :2305:83:C0 34A00000000605CCFD000000F8A7 21A0 -> 61 A0 05C0CC0002000001 82 For the Check Sum, we take EVERYTHING: 34A00000000605CCFD000000 and we calculate a CRC-16/X-25, then we exchange the 2 bytes... BSI: Modify Zone 2300: Replace 13 by 33 === >752:652 1003 222300 :B4E0:03:03 2E230033 2E2901FD000000010101 222300 1001 AAS_UDS: Modify Zone 2101: Replace A5 by BD ======= >75D:65D 1003 222101 :D1F5:03:03 2E2101BD 2E2901FD000000010101 222101 1001 NAC: Modify Zone 210C: Replace 0010 by C010 === >764:664 1003 22210C :D91C:03:03 2E210CC010 22210C 1001
I have a 130 camera with 180 camera telecoding, is it possible to just replace the camera and everything will work fine or do I also need to replace all the wiring ?
Je vais passer commande, mais je n'ai pas trouvé le code promo dont tu parles ? Mais vue la date du post, il n'est peut être plus d'actualité !?sinon, pour ceux que ça intéresse, le pack complet pour 80€ :
Porte-clip / Porte-module / Verrou-connecteur / Clip-faisceau (il en faut 4) / Support de caméra / Enjoliveur de caméra /
Câble de la caméra / Caméra de recul 180°
comptez 2h de travail, le temps de comprendre comment ça marche et de faire le câblage
n'oubliez pas aussi le code promo de vlud pour les frais de port gratuit (voir le message de vlud en première page)
Merci pour le retour VLud, mais après avoir parcouru les 20 pages du tuto concernant la caméra 180°, j'avoue avoir envie d'avoir également cette vue dans mon futur NAC !Tu peux garder ta caméra 130° sans problème avec le VIN d'une voiture équipée en 130°, et en configuration 180° mais une caméra 130° oui l'image est inversée, la gauche à l'écran est la droite de ta voiture, c'est très perturbant et assez dangereux quand on se gare
Je veux dire, le support et l'enjoliveur sont les mêmes, nul besoin de les changer ?
Egalement, le fichier de configuration "308_T9.nac (Wave2)" dispo dans to,n tuto contient il la caméra 180°
Oui, c'est exactement ça! Le plus difficile étant de confectionner le faisceau spécifique, mais rien d'impossible pour quelqu'un de minutieux.J'aurais juste besoin de la caméra avec le connecteur adéquat et le télécodage du NAC
