[TUTO] Télécodage et calibration d'un NAC / RCC / CIROCCO / CMB_NUM SANS Diagbox via Arduino
Mon véhicule est encore sous garantie et devrais passer par les mains d'un PSA pour réparation.
Le SMEG a été remplacé par un NAC (via Arduino). Est-ce que je me risque à ce que la concession brique le NAC avec un télécodage automatique (puisque seul le SMEG d'origine est déclaré) ?
En gros, si la télécodage automatique est fait, qu'est-ce qui écrase quoi... Cloud PSA -> Voiture ou l'inverse ?
Est-ce que l'un d'entre vous s'est retrouvé dans cette situation depuis la publication du programme via Arduino ?
@VLud , tu aurais une intuition ?
AIO is not supported by the soft, AIO is a KWP ECU while the NAC is UDS, everything has to be rewrited since all settings seems to be inside one big zone :sweat:
You can write the VIN using the console
Code:
>764:664
:D91C:83:C0
3BB0XXXXXXXXXXXXXXXX
Where XXXXXXXXXXXXXXXX is your full VIN converted in hex
@VLud
Hi. I want to install a BTA2 on e Peugeot 2008 but i need to set vin code on BTA2.
I need to set NAC donor car vin to BTA or my car vin?
Can i write the vin from console with this command?
77C: 67C
:F4F4:03:03
Thank you.
Reactions: Laleksss and Dravos
:) would use right stalk top button to map this frame , the button normally enable trip computer when pushed fast ( 221 len7 00 FF FF 00 7D 00 00 that's on HOLD, and when pressed 08 FF FF 00 7D 00 00 , but when pressed 1sec can be mapped to change modes sending this frame above
Right! For that you’ll using dual arduino + MCP2515 placed in the car?
To read the data with canhacker you’ve already that after the OBD2 port, right?
to read with canhacker or python script you need to be conected in info can behind NAC or cluster at 125KBPs..
Reactions: Keryan
Yup you’re right! I was just asking that to be sure, cause I’ve seen your all-in-one OBD with the MCP which makes me confused :D
that's dual purpose pcb i designed ,can wor like only 1can shield +nano in obd2 case or as dual can comfort emulator with nano in custom case i need design :)
Reactions: Keryan
Merci pour ces supers tuto!
Petite question, est ce qu’on peut rajouter l’affichage de la chanson en cours sur le compteur quand on a un 3008 comme font les 5008 quand on lit les clés usb?
merci
Bonjour! First of all, You have done a huge job, so congratulations.
Now, I am reading the whole post and I have a question. Is it possible to disable the sound when an electric door opens? For me is anoying and I would like to disable.
Ciaoall, i'm trying to restore a backup of a NAC on my RCC, everything went fine but when i try to change my VIN to eliminate the annoyng beeps, the software says that my bluetooth name is wrong, even if it seems the same and if i try to modify it.
is it due the difference between NAC and RCC (impossible to restore from different hardware) o something else?
hello,
Avant de me lancer, je voudrais être certain qu'à partir du moment où on a fait une sauvegarde préalable de sa configuration, on peut toujours y revenir sans se retrouver bloqué avec une config foireuse, c'est pas 100% clair sur la première page s'il suffit d'avoir toujours bien sa sauvegarde pour se sortir de toutes les situations ?
@Fender J'ai un peu manipulé l'outil sur ma e208 et j'ai toujours retrouvé tout comme avant avec la fonction "Restore parameters" quand j'utilise mon fichier de backup d'origine.
merci :)
et y'en a qui ont déjà joué avec le RCC des 208P21E (électriques) ? je me demandais si y'avait possibilité d'activer le menu des couleurs d'i-cockpit et le menu électrique (avec le petit histogramme)
les deux ou un seul des deux ? j'ai l'impression que sur ton 2008 c'est pas le RCC des e208 hors gt/gt-line
J'ai activé plusieurs thèmes sur mon E 2008 GT, le thème du i cockpit change également avec l'écran centrale, par contre pour le menu électrique j'ai pas fais attention, je ne sais s'il change de couleur
bonjour a tous voici mon arduino avec db9 et odb . Pour l’interrupteur doit être sur on ou off ?.
peut on changer le serial du nac ? merci
Pièces jointes
    395.2 Ko · Affichages: 64
l'interrupteur doit être sur "OFF"
qu'entends tu par changer le serial du NAC ? tu veux dire changer le VIN du NAC pour stopper les bips incessant ?
That is something I will need to know in the future as I am looking to change my NAC Wave2 to a Wave3 or even a Wave4...
Mon retour d'experience sur DS4 équipée d'origine d'un SMEG iv2:
Besoin de changer l'écran pour un 9825028980 (remarque, cet écran et dur a trouver en casse, il est possible de récupérer la coque de l'écran SMEG et de le fixer sur un écran de dgt7c de 208, il faudra juste prévoir une découpe pour laisser passer certains cable, pas tester dans mon cas)
NAC, j'ai pris un dab double LVDS (9820469280 )
Les adaptateurs chinois: prendre la version colorée et commander également le faiscreau NAC du cangeur de CD)
Ma DS4 est équipée d'origine en double antenne FM--> bien prendre le faisceau double antenne
A reception des adaptateurs, bien vérifier que le pin out est correct (dans mon cas la masse de l'entrée aux était sur la broche 47 et non 48, de plus une pin était mal clipée)
L'écran est a connecter sur la sortie LVDS la plus à l'extérieur du NAC (de toute façon le détrompage rend impossible de ce connecter à la 2nd sortie)
La programmation par arduino c'est tres bien passée flashage de la calibration et la config.
Dans mon cas le 1er démarrage à été très long (10min environ, mais au bout de 30s j'avais de la musique mais bloqué sur l'écran de démarrage, il faut juste être patient)
La configuration sur le github pour la DS4 est 100% fonctionnelle (radar, camera de recul 130°) j'ai juste eu a rentré mon VIN (pour enlever le bip) et activer la radio numérique (mais si je n'ai pas encore d'antenne DAB)
J'ai également commander plusieurs cable USB:
Android auto ne fonctionne que sur le port USB1
Les fichiers musicaux/maj système fonctionnent sur les ports USB 1 et 2
Le port USB vert (prévu pour le BTA) ne fonctionne pas (à moins qu'il faille le configurer autrement)
Prochaines étapes:
  • Refaire m'archer l'application My ds (sauvegarde des trajet localisation du véhicule, pour le moment je pas réussi a faire marche My DS ou My peugeot, nac pris sur un 3008)
  • Voir pour connecter mon BTA 2.0 (équipement d'origine, mais ref différente de celle donnée dans les tutos)
  • Installation camera 180°, voir visiopark 360°
Reactions: Almeria63
Hello,
First, congratulations for the great work!
I am trying to activate Android auto a a proace with 076C software
Android auto option has appeared in the car, however, even if the connection is established, the app does not start and the car does not appear in the movile app.
Has anyone had this problem before?
Sur 508 avec Wave 2 : non. J'ai essayé d'activer l'option, j'ai eu une erreur de télécodage.
Tu peux le désactiver de manière permanente avec Diagbox dans BSI -> Personnalisation client.
En attendant de recevoir mon BSI2010 pour faire mes essais de codage sur le CIROCCO, je l'ai posé à blanc sans LVDS pour voir ce que cela donne :
Résultat des courses : la plupart des choses ont l'air OK.
Me reste à faire dans le CIROCCO :
  • Désactiver AFIL
  • Activer le contrôle de niveau d'urée
  • Activer les thèmes
  • Activer l'affichage des Medias
En bref, je dois le télécoder à ma sauce et ensuite vient la partie intéressante : l'intégration dans le tableau de bord :)
Hello my friend, I have a 508 plase 1 , can I do that on my dials as you ? Thanks a lot !
[QUOTE = "erdo_celik, gönderi: 2600050, üye: 132173"] 2300 bölgesinde tema seçimi açıldı. Ama cirocco yazarken, program kendi kendine kapanıyor. Programı tekrar başlatıp okuduğumda cirocco 2300 bölgemde ambiyans 7 ve 8'in etkin olduğunu görüyorum. Ambiyans 1 ve 2'yi etkinleştirdim. Bölge 2127'de menü-4'ü açtım. Maalesef tema seçim düğmesi kayboldu. Ccirocco ve nac'ın yedeklerini yaptım. tekrar geldi. [ATTACH = dolu] 18609 [/ ATTACH] [/ QUOTE]
Hocam size nasil ulasabilirim
No TR here, eng at least
Reactions: aliosman377
Hello,
Do you get any message on the car's display when connecting your Android phone?
