Vlud sorry if I still break you which calibration of the 308 should I try to insert since I saw that there are 2 which one should I try possibly I was wrong to download which one should I use to try?@diluca80: I don't have access to any Opel calibration so I can't help you.
Find someone with an Opel Corsa 7" and copy its FMUX zone using console:
Code:>764:664 22010E
Then put the same data on your NAC:
Code:>764:664 :D91C:03:03 2B010EXXXXXXXXXXXXXXXXXX
Where XXXXXXXXXXXXXXXXXX is the previously read zone.
Did you try a 308 calibration ? Since it is the same screen it should work
Hi @VLud and sorry if I break you I tried to do some tests but it does not go to rewrite the field as you told me@diluca80: I don't have access to any Opel calibration so I can't help you.
line 12(RCC) in calibrations is FMUXOn my 02/2021 208 GT pack I only managed to change themes successfully with cirocco tool, the rest of the parameters can’t be changed, even if I select some options and do the coding in the next reading they are exactly like before. I also noticed missing parameters compared to another combine_uds I’ve worked on 6 months ago. It seems that visteon or PSA changed something with the parameters zone.
InterestedHello ,
Si ça intéresse des membres sérieux j ai fait un fichier pour lire config complète bsi delphi Ev.
Ça fonctionne un déverrouillage puis lecture toutes les zones ( environ 1 minute pour lecture).
Écriture ok aussi tester sur 3008 II et 508 II.
Je cherche à identifier exactement les zones a la méthode Vlud ( thanks au passage).
Écu moteur uds lecture écriture aussi ok juste un dtc fugitif de telecodage sécurisé il doit y avoir une traçabilité à rentrer.
Cdlt
I did it like this:
> 764: 664
22010E
and he answers me
62010E1E1A382220394B000000000000000000000000000000000000003A00000000000000000000000000000000
to rewrite these commands in the console
> 764: 664
: D91C: 03: 03
2B010E62010E1E1A382220394B000000000000000000000000000000000000003A0000000000000000000000000000000000
my original had
> 764: 664
22010E
62010E0000000000000000000000000000000000001A1E20003900003A3800004B00000000000000000000000000
and after writing it remains so
where am i wrong?
However, also try all the calibrations present for the 308 and it doesn't go ...
you need to activate in BSI front and rear +cameraHi all, i have a question about parking sensors, i have retro camera with rear bump sensors installed from vendor (i can allready see proximity singns on my display), i need to add front sensors and integrate them with my RCC, i bought the sensors module yet for front and read (6+6 sensors).
the question is, if i replace the sensor's ECU actualy suited (6 sensors) with this one, i need to activate something in BSI (or simply on my RCC) to integrate front sensors with my infotainment or simply install sensors an loom, replace ECU and everything will work fine?
You now have only 4 rear sensors, if you swap the AAS ecu with 6+6 one and you don’t connect to it a total 12 sensors, you’ll see the parking assistance fault on the dash. Manual coding of the AAS_UDS_gen6 (which is the parking asisstance ecu of new Peugeot 208/2008 opel corsa etc) is not possible, there’s not even a menu inside diagbox for that. I think that if you don’t add all the extra sensors you won’t have the system work.Hi all, i have a question about parking sensors, i have retro camera with rear bump sensors installed from vendor (i can allready see proximity singns on my display), i need to add front sensors and integrate them with my RCC, i bought the sensors module yet for front and read (6+6 sensors).
Sauf évolution à ce sujet, il n'est pas encore possible de faire cela. Tu dois sûrement avoir un BSI2010. Sur BSI2010 le bouton de l'ESP ou ESC est branché au compteur et le compteur envoie la trame nécessaire pour activer/désactiver l'ESP. Le CIROCCO ne sait pas gérer l'ESP/ESC.
Le NAC envoie une autre trame pour activer/désactiver l'ESP.
La solution à aujourd'hui c'est d'intercepter la trame envoyée par le NAC et la traduire ensuite via arduino en une trame envoyée par le compteur.
Peut-être que @RuLe a avancé sur ce sujet
Hi @filippo.sara , I'm working with marcinis on this problem, we hope to be able to do something good soonBonjour @VLud pouvez-vous m'aider à activer esp dans les paramètres cirocco pour une citroen c4 grand picasso 2014 car via nac il ne s'active pas si je mets cirocco d'origine cela fonctionne via le bouton esp merci beaucoup
bientôt je l'espèreHi @filippo.sara , I'm working with marcinis on this problem, we hope to be able to do something good soon
@marcins hello! Is your steering wheel buttons working to change the cluster « modes »?
would use right stalk top button to map this frame , the button normally enable trip computer when pushed fast ( 221 len7 00 FF FF 00 7D 00 00 that's on HOLD, and when pressed 08 FF FF 00 7D 00 00 , but when pressed 1sec can be mapped to change modes sending this frame above
