[TUTO] Adaptateur pour SMEG/NAC/Matrice CAN2010 sur BSI CAN2004
You're not quite right. I wrote you letters with proposals for joint activities, but I have not received a response. Moreover, I offered to help solve specific issues and asked where and how to transfer funds for work, but you also have not responded. Now you have chosen an opportune moment ... ha!
If you are interested, I personally from these devices I get only compensation for my production costs. If you are interested, then I am ready to give you all the documentation and you can place it in your GitHub or wherever you like.
A bad peace is always better than a good war.
Hello,
Do you make Can adaptor? I am interested to buy one for my 407 in order to can install a NAC radio, i have no skills to do it myself. I want to make the conversion from RT5 to NAC, but as i saw i don t have the info from the AC on the screen.
Tks for the answer
Reactions: PapaOG
L'image du SMEG + avec les 3 boutons est la suivante Bientôt avec nac
ici le lien avec le code des 3 boutons:
https://docs.google.com/document/d/1AGmuKyYUuqSJ7dOFlR4-XNLwU2NPba5j1aOSlJbpBq8/edit?usp=sharing
Hi!
How can I get your sketch?
I'm planning to install NAC Wave2 instead of SMEG+ iv2 with menu vol +- buttons in the same Peugeot 308.
Thank you
Hello,
Hi!
I once passed through Bucharest and some other Romanian cities. Very good memories :)
Yes, I can do it, but I have no idea how to send the finished product to you. I am from Russia and Russia is under sanctions and in complete isolation at the moment. It is impossible to make cross-border payments and send goods.
Bad times...
But you can use VLud instructions from first page. This method requires almost no soldering.
Reactions: olivian diaconescu
hello,
I am impressed with your work.
I have arduino ready.
My car is 407, installed a meter and a color screen from 508.
He wants to mount NAC soon.
i have a few problems can someone help me?
I do not know what parameters I should change in arduino so that everything works as it should.
I think it would be better in private messages not to clutter the forum.
thank you very much.
hello I already have NAC navigation and the counter from 508 installed.
Is there anyone who can help me with the arduino?
counter 508:
there is an active block:
STOP, check engine, handbrake.
The counter does not indicate that the handbrake is active.
the screen does not show the automatic transmission positions.
The PDC OFF and ESP OFF buttons do not work.
need to send nac radio to setting?
can this be forced on the arduino?
NAC configuration - I have a JBL sound system - smeg does not give sound ..
peugeot 407
What about (tele)coding your ECUs correctly first ... ?
If you don't want to debug things yourself just don't do any retrofit.
Help plz. I’m not so smart to reverse engineer )
Does your NAC in RCZ work with jbl amp?
Today I’ve installed arduino converter made by your instruction. It works great, but have some sound issues. Totally no bass.
My car is 308 t7 2011, stock JBL sound system with multiplex amplifier, NAC wave 2. Smeg+ iv2 works ok with this spec. Switched "Multiplex gen1" in PSA-Arduino-Nac. Sounds much better, but still no as good as smeg+jbl.
PS I’m so amazed about job you’ve done with psa electronics
PPS 2nd photo is my smeg+ iv2 can2004 and NAC wave2 customised to fit it like stock smeg (Argentina and Russia version)
PPS My installation on drive2.ru >> https://www.drive2.ru/l/621182014447430082/
Pièces jointes
    230.7 Ko · Affichages: 64
    298.3 Ko · Affichages: 63
Problem solved. I just mixed up 2 wires in NAC connector. Now sound system works fine
Reactions: PapaOG
bonjour a tous ,
voila je possède une c3 Picasso de 2011 avec un RNEG et j'ai switcher sur un NAC avec un dgt7 , celui-ci démarre correctement mais en anglais avec impossibilité de modifié la langue et l'heure ne s'affiche pas .j'ai donc installer cette interface mais rien ne change .
avez vous une idée ?[/QUOTE
Salut @elec320 je n’ai pas la solution à ton problème cependant tu as peut être la solution pour le mien est ce toi sur le forum megane 3 ?
Cordialement
Hello, sorry for English. First of all - good job with this! It’s impressive to get Wave working on my 407. But I have question. Does anybody of you have issue with No sound on nac? When i’ve installing Wave2 everything work great. But i want change it to Wave4 and there is some strange issue. Sound of radio/bt/usb not working. I can hear wrong vin beep, or touching. Like something tell to nac „hey! Shut up”. Sometimes not working bt connection, on usb not play audio (time stay at 0:00). I have 407 with stock jbl which is enabled in bsi (it’s not multiplexed version) Maybe something try to communicate with amplifier and pause all? I know that is not issue with sketch, but maybe in „retrofiting” group someone have some experience. On C5 X7 without amplifier configured everything works great through adapter. I’m not sure that i’ve tried disable amplifier
Hi, did you find a solution?
I have the economy mode turned off, but when I try to update, I want to start the engine.
Hi All ,
Is it possible to help to update NAC unit on bench ?
CAR Peugeot 508 NAC ...
For now i make all conection with used BSI and unit full working but when i tray to update FW or MAP i have mesage that engine mast run !
How I emulate that engine run ?
Which can data mast send to BSI ... to solved this problem ...
Or Is it need some more on bench near BSI , ECU , some sensor ... ?
Does some have expirion ...
Regards
Zeca
Hi
I’m using NAC wave2 in my 308 T7.
Got some questions.
1) No altitude info on cluster screen
2) Very often pops up strange symbols like on photo. Sometimes it shows info with crossings roads, but it’s totally wrong. Does somebody try to fix that?
Pièces jointes
    180.5 Ko · Affichages: 47
    209 Ko · Affichages: 49
One more thing. If somebody wants to connect analogic buttons (Menu Vol +-).
NAC W2 from Peugeot 208 + calibration Peugeot 308 T9 (got from vlud.net)
Menu button didn't work.
I edited 330 string in Ludwig's sketch from this
Code:
          canMsgSnd.data[0] = 0x02;
to this
Code:
          canMsgSnd.data[0] = 0x80;
And now Menu button works perfect
Hi friends I want to ask is there someone who sell ready box with everything with all chips together? I want to buy it ready to use made it by someone who know what is he doing :D Thank's a lot! :)
Hi
Got some questions.
Question #2 solved by myself.
Found a video on youtube
As we can see - navi pics for cluster has can frame id 0x229, 2nd byte A6, and the last byte value changes pictures (00, 01, 02 ..**).
I've edited Ludwig's sketch 1564-1566 strings from this
Code:
      if (id == 0x260 || id == 0x361) {
        // Do not send back converted frames between networks
to this
Code:
if (id == 0x260 || id == 0x361 || id == 0x229) {
Tested for 15 minutes, no more random navi pictures in cluster screen.
Code:
to this
Code:
Hello, would you know how to solve the problem that it does not show the altitude on the dashboard?
Can this information be returned?
Cheers!
Reactions: Manuel Pérez
Hello. NAC mounted, everything works as it should. The only problem is the PDC sensors are too loud.
how to set the rear view camera in Arduino? In NAC, it is active but will not turn on.
peugoet 407
