can u send me config please ?on my car esp not workingHi,
Thanks for the job very usefull. I am looking for the peugeot sport 508II icockpit calibration.
Can someone help me.
Thanks in advance.
Please ... I already explained this to you in private, what other answer do you expect ? ...
There is NOTHING more to explain
- You save your current RCC config using the soft
- You swap the unit physically
- You flash the calibration file for Grand Picasso from the topic (C4_GRAND_PICASSO-9692633080.cal) on your 208 RCC
- You restore the config from your previous RCC
- You manually activate Android Auto
- You are done.
- You are done.
you need to have special hardware (if I am not mistaken diagbox cable) to be able to calibrate you NAC. Do you have it?
@levanid Yes, I have diagbox cable. Can you do it via remote
Helo @VLud, may I ask if you had any progress in that bytes move hack for Wave3?
Is it possible to do it with Aurdino How let me knowFinally the themes activated
My mind is small, but I make it work hard
Which package is it for NAC?Here is the configuration file of peugeot 3008, maybe it can help someone
Arduino cirocco for icockpit and Arduino NAC/rcc for NAC our rccIs it possible to do it with Aurdino How let me know
is theme settings in i-cocpit? Or BSIArduino cirocco for icockpit and Arduino NAC/rcc for NAC our rcc
i-cokpit only has 2 themes, just activate the themes in nac and icokpit with arduino and it's alreadyis theme settings in i-cocpit? Or BSI
Hi,Thank you very much for your sharing, dear VLud. I connected with db9-obd pins according to the link you shared. My car is using a 2019 model peugeot 3008 gtline copper theme right now. I do not have a red theme on my car. How can I enable it. I made a backup of the parameter file. How can I activate watching video in motion.
Hi,
Where did you get DB9 and ODB socket. And also Aurdino.
212A=0EF40BF30320070801E7070802C8026C065402560804020608028028021F0001FA0063646400006464
212A=0DAC0BF302D4070801E7070802C8034A06C2021C08040206076C8028021F0001F5006A646400006464
@VLud merci pour ton aide.Il faut importer la zone 212A (Visiopark) de la config dispo sur le topic (tu peux éditer ton backup directement par ex pour le restaurer avec la zone modifiée ) et ça devrait fonctionner
My vehicle is the 2020 3008 GT series. The i cockpit amplify, which is in 2019 models, is not in my vehicle, how can I activate it.
My 2127 HMI codes are here
https://bbcode0.com/full/2020/12/30/273a060861bae5ac16861801a82f2b03-full.png.html
Cher Vlud, merci beaucoup pour votre intérêt, mes codes dans la zone de 2126 n'ont pas de partie pour activer cette façon.Zone 2126, setting "Instrument panel themes" will enable i-Cockpit Amplify inside "Apps" menu
