I asked Albatros24
Mr. Albatros24 gave me the solution
But it was a problem on the page when the page came back, page 90 was deleted
Thank you for Albatross24 treating him well
Here is the original photo
that i took pictures on facebook i'm a small image size
https://mega.nz/file/rn5UiZBB#nApT4nwKBLDt0wZ8puA66COwf6w1hwGUb51AOa2MpsI
https://mega.nz/file/SmxwkDDK#_InXNpnZqO6LQNN1cAhAV6LUihTPc8N7Q2Jg1Arvl1I
Mr. marcins
can you help me with arduino psa solution?
Hello, I have problem with response from radio. If I wrote 764:664 to terminal and got response 7F0000. To code 1003 I got response 5003. When I start car that display is still off.
And in log is still repeat:
> 10C0
< 7F1012
Where can be problem?
Thank you
bonjour, quelqu'un sait si on peut activé la température sur android auto/ apple carplay en haut a gauche comme sur la photo sur une 208 ?
Pièces jointes
    107.6 Ko · Affichages: 123
Trying to revert my EV cluster. Unfortunately CIROCCO app does not recognize the CAL files for UDS_EV.
EDIT:
Ive fooled the software editing the 2nd line from CAL file and reverting it before the dialog box confirmation. It starts to flash but hangs on unlocking confirmation. The sketch does not retry unlocking even turning on the flag for it. It needs at least 7 retries to get the key and start the flash:
Log from Cirocco app:
Code:
> 00
< 7F0011
> >75F:65F
> 1003
< OK
< 7F1012
> 1002
< 500200C80014
> 22F0FE
< 62F0FEFFFF000026FC00000001024C3F0F0C14FE00000001945938
> 22F080
< 62F08098207749800002982077498006470000000011860199
> 22F18C
< 7F2231
> 1001
< 500100C80014
> 1002
< 500200C80014
> 2701
< 7F2737
Log after forcing 7 retries of 2701 command under console:
Code:
7F2737
7F2737
7F2737
7F2737
7F2737
7F2737
67010B58169E
Google translate: Bonjour; Je l'ai vu sur la 3008 voiture d'un ami. Lorsque vous passez en marche arrière, les rétroviseurs sont orientés vers le bas. Existe-t-il un paramètre connu pour cela? Je suppose que BSI. Merci.
C'est une option qui est avec les sièges à mémoire. Il faut des rétroviseurs à mémoire et des sièges à mémoire. Ce n'est pas seulement dans le BSI.
Hi All ,
Does any now how put NAC unit ( Nac Wave2 b2 dmt ) in emergency recovery mode ?
Is it general possible ?
I have broken flash Nand dump and wish repair this unit .
Or some solution to repair this unit .
Best Regrards
@Hallahub
"What is the problem? What you mean with “I can’t change anything?”"
With Diagbox, you cannot modify the options ...
@Keryan
"Je confirme que le VP2 fonctionne sur 308 T9"
Content pour toi !
@nico1080
"Par contre je vais surement utiliser une camera standard grand angle plutôt que la camera Peugeot (forme plus simple)"
Ça ne donnera pas une image correcte !
Je n'avais aucun précâblage...
J'ai percé cette pièce en plastique... (Genre de gros bouchon !) Située derrière la batterie.
Reactions: Keryan
De mémoire tu ne peux pas utiliser des caméras externes en visiopark 1, alors je ne sais pas si ça ira en VP2
Lorsque que j'ai installé la camera 180 arrière( à la place du 130) je l'ai branché sur un écran standard (video composite= RCA jaune) et elle sort un signal NTSC standard.
Je n'ai pas fait la manip de brancher une camera standard sur le NAC, mais je ne voit pas pourquoi ca ne marcherai pas.
Le seul point a vérifier est si la camera inverse l'image (gauche/droite), mais j'ai pris une camera réglable (un fil a couper pour inverser)
Je tenterai la manip lorsque que j'installerai le calculateur VP2 (j'espère le recevoir bientôt)
la caméra 180° d'origine est une caméra fisheye avec image inversée. Le NAC fait ensuite son traitement d'image pour aplatir l'image et l'inverser.
D'où la remarque qu'une caméra 180° lambda ne fera potentiellement pas l'affaire
Hi brothers, great respect for your work, i have a problem with the peugeot 3008 odometer, i wanted to update the meter with a .ulp file and now i have a DNx FLASHER message, can it be fixed somehow?
haha
problem with reading you have.... you not first and not last ..read back
@Hallahub
[QUOTE = "Hallahub, post: 2647155, member: 114118"] What is the problem? What you mean with “I can't change anything?” [/ QUOTE]
I think he means that there's no mentioning of parkassist anywhere in the menus, even on the authentic Diagbox with a valid token.
I can't find anything to enable neither that has to do with parkassist under BSI, DAE, AAS, or car preparation menu where you can enable other extra stuff with a valid token.
