J'ai bien 12 capteurs au total.Hello @cybertom87 !
D'un point de vue matériel, il doit te manquer les 4 capteurs latéraux (12 capteurs au total pour disposer du park assist).
witch bite to modify ? witch line ?no longer needed, just change the FF to F0 byte and the counter works
Of course there’s not, diagbox in manual coding shows something like 10% of all the possible parameters that can be modified. I already explained how I successfully enabled park assist and other features using the original diagbox: Auto coding using another VIN. But this is risky, I don’t recommend anyone making those tests if you don’t know exactly what you are doing. Anyway this thread is related to arduino, not to diagbox and it’s operation method. You can find some answers on another vlud’s tutorial, the one to retrofit a NAC on the 308, it’s really well explained how to use diagbox since in the time beginning arduino tool was not released yet.@Hallahub
[QUOTE = "Hallahub, post: 2647155, member: 114118"] What is the problem? What you mean with “I can't change anything?” [/ QUOTE]
I think he means that there's no mentioning of parkassist anywhere in the menus, even on the authentic Diagbox with a valid token.
I can't find anything to enable neither that has to do with parkassist under BSI, DAE, AAS, or car preparation menu where you can enable other extra stuff with a valid token.
This corect but the source VIN shoud have same ecus like yours ref nr, otherwise will not telecode[QUOTE = "Albatros24, post: 2648451, member: 129705"] [USER = 140453] @costads [/ USER]
Difficult to understand how he did it!
With Diagbox? Without Diagbox?
In my opinion: with Diagbox this is not feasible! [/ QUOTE]
If you get the VIN from a car that has same properties as yours + automatic park, then you can replace your VIN in Diagbox, and then do an automatic programming, then Diagbox will add the features from the new VIN, to your car I think.
line 0x10 byte 0cwitch bite to modify ? witch line ?
308 phase 1 uses the amplifier to make the fake engine sounds, it has nothing to do with the nac. The page you’ve posted is totally useless for you.Voir la pièce jointe 23791
Je fais appel a vos lumières, j’ai une 308 gt 205ch de 2016, avec un nac que j’ai monté à la place du SMEG d’origine, il fonctionne nickel, mais je souhaite supprimer le faux bruit dans les hauts parleur à l’activation du mode sport,
Un membre l’a fait pour son 3008 il me semble mais je ne trouve pas l’option à désactiver pour retirer ce faux bruit
merci d’avance à vous !
Venant d'équiper ma 308 avec un NAC d'occasion en remplaçant mon vieux SMEG je rencontre un problème suite au telecodage par la personne qui me l'a vendu une erreur c'est glissé sur le VIN. J'ai essayer toutefois de le changer via un Arduino/ Shield 2.0 et en me brancher sur les pin 3 et 8 j'ai un message d'erreur m'indiquant RCC/NAC UNLOCKING FAILED. J'ai essayer en mode terminal sur l'ide Arduino mais rien à faire. Je sollicite votre aide afin de pouvoir remédier à ce problème et ces incessant bip.
En vous remerciant par avance pour votre aide
Oui il est bien connecté par contre j'utilise une machine virtuelle ça pourrais poser un problème ?Bonjour
Votre ordinateur est-il bien connecté a internet ?
Ça a fonctionné merciOui ça peut, peut-être venir de là, vaudrait mieux essayé sur un "vrai pc" directement
You need the uk calibration to reverse them.Hello, I live in England and I have a Citreon DS5, i installed NAC wave 2 (before RT6). I calibrated to DS5 and restored parameters for DS5.That I live in England (right hand drive) my FMUX(restyle) buttons are in the wrong location. Button Media is Telephone, Button Telephone is Media, and the same for every other button.They work the same like the left hand drive FMUX.Everything else works fine instead FMUX.If you can, can you help me with this problem?
left hand Drive
Diagbox button test show normal.
I know. I can't fine ds5 with Nac, and good owner how can believe me, for conect computer for his car. I BUY token, for online diagbox. And fine VIN number right HAND DRIVE CAR with NAC.You need the uk calibration to reverse them.
