Hello, I am trying to install a backup camera for my peugeot 2008. The Nac/RCC program is running as can be seen in the screenshot. CIROCCO does not open for some reason. what would you recommend me to do? NAC/RCC 2106 Are the encodings I marked sufficient? When I put the reverse gear, the camera image did not appear.
Pièces jointes
    27.2 Ko · Affichages: 85
    58.8 Ko · Affichages: 81
Hello again!
Unfortunately I apparently don`t have zone 2360...:(
Did you managed to find out something else from your config.?
Hi! Sorry for the late response, apparently i don't have zone 2360 too. More surprisingly is that i don't have 2324 Corner light type. I checked the following and i received a not found/out of bounds message:
2360 The presence of the function of additional head lighting using fog lights
2426 Type of direction indicator control with a smooth increase in brightness (not related but just for the sake of it)
244D Additional headlight function
240D The presence of additional static head lighting
I assume that JSON is for the new BSI models only and it just happens that 80% of the zones coincides with previous BSI model or so. Looking at your car, you've got the late model. I have a 2018 BSI2010. Regarding of additional module, i really don't know... This is a simplified diagram of my car and i cant see any module for the lights. But i am somewhat sure that BSI controls them via relays, so it should be a BSI thing. I am sorry that i cannot help further... :(
Reactions: MPC98
Anyone who installed a VP2 module, please? Maybe @VLud . I have some questions regarding the calibration:
1. Do you calibrate them separately or together?
2. When you start to calibrate them, you should be in the front of the parking space and then just back up to the middle of it? (just found this photo, i don't have a diagbox until friday for like 1hr to use http://vlud.net/comments/upload/comment/2023/03/TVrk0wxCaE6b0BoC4JVL.jpg )
3. Usually it's enough to do one calibration?
I will pay somebody to do this and i don't think he knows more that reading errors and clicking on stuff, and as i will have a limited time for this i would like to know ahead what to expect and do in case he doesn't know anything about this. Thanks!!
Thanks for the response and for taking a look, I believe I have the same BSI as yours, more or less, need to mention one more time, I am looking for my father's 3008, it's an early model 2018, RCC with halogen lights and front halogen fog lights. My 508 from the pic already had static LED cornering lights from factory incorporated in the headlights.
I did try all the zones related to lightning...same as you, many of them were non-existing...All I found is that if I activated 244D and 240D zones, the fog lights wouldn't work anymore :)), and that's pretty much it. Tried all the values from 2324 zones, nothing else...
Reactions: weirdcactus
Any idea, please?
And maybe some extra info? I tried a fullchip in the past and it didn't recognize my car (2018 second gen c4 cactus). Something that i should be aware before?
Thanks!
Hello, I replaced my RT6 with Nac W2 in Peugeot 508 ph1, i saw that I can change monotouch to multitouch option for touch screen, but in diagbox I can't see touch screen in available ECU's, my screen reference is 9831665880, and in NAC parametres DGT7C is configured, if somebody can help me what do I need to do? And I can't see mirror link option on Nac but it is enabled in parametres? Regards
Bonjour à tous s'il vous plaît j'ai pas trouvé la solution pour télécodage post radio 208 Aio je veux Sketch arduino pour elle merci à tout.......:spamafote: Ou avec AnyDesk je peux payer la prestation!
salut à tous, après avoir changé le combiné d'instruments je peux me connecter sans problème au NAC mais pas au CIROCCO, quand je clique sur CMB ACCESS ça devient gris et je ne peux rien faire. J'ai essayé >764:664 1003 et >75F:65F 1003 mais rien
Bonjour; salut. Grâce à ce magnifique et d'autres guides créés par @VLud j'ai pu monter le NAC sur mon 2008 de 2017 qui montait un SMEG+IV2.
Maintenant j'ai remplacé le NAC par un DAB avec le code 98 204 692 80 dérivé de Peugeot 3008.
J'ai fait les différents réglages via arduino mais je n'arrive pas à faire fonctionner les boutons SRC et MENU, la molette de volume fonctionne donc le NAC reçoit le signal mais n'accepte pas celui des deux boutons.
Quelqu'un peut-il me conseiller quoi faire?
Merci.
Merci.
J'ai réussi à résoudre le problème que j'avais rencontré en chargeant le fichier de calibration 2008.
Hi, is there any setting so that LKA will not be automatically blocked from use when attaching a trailer? I use a hook-mounted bicycle carrier and it's a pity that then the use of LKA is not possible...
i messed up somewhere and now my minimum bightness on cirocco is to low/dark when lights turn on. how can i change the minimum bightness level for cirocco?
I enabled it using diagbox so I don’t know zones need to be write.
I think you missed to enable something but what ?:voyons:
I have the same in zone « 2348 »
62234805
Hi, did you activate using diagbox and another VIN? is there another option using diagbox and canbus shield?
Salut à tous,
N'ayant pas trouvé une section "Présentation" sur le forum, je me permets de briser la glace ici !
Je suis originaire du sud et je suis l'heureux acquéreur (depuis très très peu) d'un 5008 GT de fin 2019. J'étais jusqu’à présent habitué des voitures allemandes, et en toute franchise les françaises n'ont plus rien à envier à leurs cousines Allemandes.
Je tiens d’abord à vous féliciter pour ce magnifique forum qui nous permettra de partager nos expériences respectives avec nos belles Lionnes. Et une spéciale dédicace à @VLud & @bagou91 pour leur travail pharaonique. Merci à toi de le partager sans rien demander en retour.
J’ai hâte de parcourir la totalité des rubriques du forum pour découvrir vos différents postes, je m'en inspirerais surement pour pourvoir activer des features (Full software) et/ou rajouter de nouvelles Options qui nécessitent l'installation du Hardware.
Un petit descriptif de mon 5008:
Modèle : 5008 GT ETA8 S&S
Motorisation : 2.0L BlueHDI 180cv
Options d'origine :
  • Sièges Électriques, chauffants & massants
  • i cockpit amplify
  • Radat av/ar (12 en tout)
  • Caméra de recul
  • Régulateur de vitesse adaptatif
  • Attelage démontable sans outils spéciaux
  • Sièges cuir
  • Allumage automatique des feux
  • Phares à LED
  • Active Brake-Assist
  • Coffre électrique
  • Capteur de somnolence
  • Détecteur d'angle mort
  • Assistant maintien de trajectoire
  • Ouverture des portes sans clé
Options à activer (SW) :
  • Park Assist
  • Driver Welcome
  • Quelques Thèmes additionnels
  • Grip control (Je ne sais pas si c'est faisable si on n'a pas la petite molette à côté de la boite à vitesse)
  • Affichage du media display sur le i cockpit (J'au vu quelque part sur le forum que ça été fait par quelqu'un)
Options à activer (SW & HW) :
  • Caméra Av
Au plaisir de discuter avec vous.
Theamy
Premières questions sur le Forum.
  • Je me demandais s'il y avait un site ou un logiciel qui nous permettrait d'identifier l'emplacement des différents ECU en fonction des modèles de voitures. Comme ça avant de se lancer à tête baissée dans le démontage de la voiture, au moins on démonte au bon endroit,
  • Y a t il moyen ou un document qui décrit la décom ou le contenu de l'ensemble des zones ? exemple 2415 ou 2348 je sais qu'on peut faire appel à @marcins mais on peut éviter de le déranger à chaque fois ...
First questions on the Forum.
  • I was wondering if there was a website and/or software/application that would allow us to identify the location of the different ECUs based on our car models.
  • Is there a way or a document that describes the content of all the zones? example 2415 or 2348 ! I know we can ask @marcins but if we can avoid disturbing him each time we have a question related this subject that could be good ...
There is a JSON doc, check like ~10 previous pages.
2415 Presence and type of perception of traffic signaling
2348 Availability and type of governor/speed limiter
Data type hex (or as i call it, enum - multiple options)
Reactions: Theamy
Do you know if E-REMOTE function from My Peugeot/Citroen apps are something specific to newer RCC/NAC waves? Is it for electric or hybrid only? Is it worth it or just a PR thing? I see other functions like alarm, lights, lock & unlock which would be nice to have with the phone only.
i was wondering if its possible to capture the data from the bluetooth (assuming it s using bluetooth only) and create a custom app. I see that this is a paid service, only first 6 months are free. What do you think?
Edit: just found that this is possible only with NAC and they have an API and Sdk for mobile apps. You can also build apps for NAC apparently which are web views, so its JS. Dont know about bluetooth yet, i tried to sniff the data but no success yet. Funny how car infotainments are now web views, even porsches are like that and their apps are built with Angular
What about VTH_UDS? On C3 Aircross it displays SLI.
Currently trying to make it work on 508 W2 with Wave4. SLI shows well on NAC & MATT_C_2010 but not on VTH_UDS from C3 Aircross.
On the original VTH_UDS that came with the car it's impossible to display it at all.
How do you activated SLI on matt_C_2010 ? I'm trying to find this option but it's hard to find, I've only found how to show it from camera, but I neet the SLI from NAC because I don't have camera
Please let me know
HI
Quelqu'un peut-il me dire quelle zone changer pour que la radio fonctionne. J'ai changé pour un plus récent dans JUMPY. J'ai entré le VIN. Il n'y a pas de bip, mais le volume de la radio et les boutons latéraux ne fonctionnent pas. le volume fonctionne sur le volant. La radio est une Toyota Proace.
HI
Can anyone tell me what zone to change to make the radio work. I changed to a newer one in JUMPY. I entered the VIN. There is no beep, but the volume on the radio and the side buttons do not work. the volume works on the steering wheel. The radio is a Toyota Proace.
Pièces jointes
    70.4 Ko · Affichages: 44
    30.7 Ko · Affichages: 42
VP2 can't be calibrated (video settings are inside ECU calibration and not documented), only VP1 can be calibrated, if you try to calibrate VP2 from the NAC or RCC you will loose your time
How about with Diagbox? I asked somebody to do the procedure a few minutes ago on my car but no success. It required internet access. I feel like i lost a lot of time installing a VP2 module :( Isn't there a way to find the video settings inside AVP module?
