2.secondary issue is about revers camera scale.
The scale of car is too big , so I can't identify the correct position.
(The image showed car is out of the parking space, but it's still have 20cm between wheel and line)
I have tried to set 2105 but it's helpless.
Anybody could share your exprience to fix it or provide me some hints?
Thank a lot.
/Nick
212A and 012A
Reference:
Very appreciate all guys to provide so much great info here.
I tried to update my Peugeot 2008 P24 head unit from RCC to NAC serval days ago.
I met two issues
1.
At begining, I could not enable NAVI screen on my 3D speedometer using vlud for 2100 and 2300.
I forgot to modify which item the map item is coming but no map showed.
Then I asked the friend of China who provide me the vaule for 2100 and 2300 as below:
Key(speedometer)A13C
2100F4C0A29C000000000000000D6600800A0000A035002024
23008808FC0053BB82FF00
the map will be showed on the speedometer, but no arrow icon.
I know that's should be in NAC 0112 and 2116 but is still not working.
Key(NAC W4)D91C
0112005A34D6800007403002880157001E0158130001E0007E032013000157001E0158130080
2116FF30080140
Thank a lot.
/Nick
Thanks for @afu1986 to provide me the hint.
I try to change the type of car form unknow-4 to new 2008 of Dashboard 2100 item.
The arrow icon has be showed .
@VLud @JonnyMnemonic
Very apprecaite your guideline ,I follow your step to try serval times but it's still not working for me.
The reverse image is also in the same situation. (I also modified "real top view height 1000 <> 2550 mm" for 212A)
I am not sure what step I am doing wrong.
/Nick
Bonjour à tous! J’ai un souci pr compiler le fichier, j’explique ce que j’ai fait :
-J’ai installé le logiciel Arduino sur Windows 7
- j’ai DL le fichier zip du master et je l’extrait (https://github.com/ludwig-v/arduino-psa-diag/archive/refs/heads/master.zip)
-j’ouvre le dossier arduino-psa-diag et je lance le fichier arduino-psa-diag.ino (en tant qu’admin)
- j’upload arduino-mcp2515.zip et ArduinoThread.zip en faisant Sketch-> include library -> Add zip…
-j’ai un Elegoo UNO R3 et Can Bus Shield 2.0 donc je change la valeur en 9 à la place du 10
- je clique sur compile et PAF : voir photo
J’ai installé java en dernière version, j’ai lancé le tout en admin, j’ai changé de chemin d’installation rien n’y fait ….
Pièces jointes
    55.7 Ko · Affichages: 19
I thank you for the time you have dedicated to me. I managed to activate it. Now I will be able to help other people on the Italian forum "Passione Peugeot". Thanks again.
Hello Raffo89 , can you tell me how you solve the problem with coding of ASS, I had the same situation like you:
OK
5003
622101A5
5003
7F3E03
67037962CA52
6704
7F2E31
7F2E31
622101A5
I have AAS_UDS_G5 and for unlocking I use D1F5.
Programming with ignition ON and engine off worked like a charm, in some situations. I was able to program the BSI.
BSI: Modify Zone 234C (Driver welcome): 00 > 01 (added option in NAC too)
BSI: Modify Zone 2300: 13 > 33 (Parking system type)
I carried out these operations successfully, and they work as usual.
Thank you for your time!
Lisez la Zone A0 de ce calculateur : DAE_BVH2...
>6B5:695
81
21A0 -> 61A005C0DD0002000000
si vous obtenez la même chose que moi, alors continuez avec :
:2305:83:C0
34A00000000605CCFD000000F8A7
sinon dites ce que vous obtenez, je vous calculerai le checksum.
Hello Albatros24, can you help me with coding of DAE_BVH2,
When I read zone A0 :
>6B5:695
81
21A0 -> 61A005C0CD0002000001
I got this answer, so in this case can I use 34A00000000605C8FD000000E88A, or must be some different code?
Thanks
Hi,
is this for a P24, 2008 EAT8 ?
Yes, I have tried this code to disable STT successfully on
Peugeot 2008P24/308T9/3008P84/5008P87/508R8
Citrone C4P/C4GP/Berlingo
OPEL Mokka/Astra
But I am not using arduino tool for this purpose, I use the clone diagnostic tool from China , It's the same just a different tool.
Do you have a clone diagnostic tool from China for Diagbox using?
FYI,thanks.
Did you solve the popup problem? The problem is in the sketch, something removes notifications before they appear. I used another sketch and the notifications are displayed perfectly there, unfortunately that sketch is not very refined in terms of car settings, etc.
Not yet because my car is for new paint . I have tried on older Citroen C5 from 2006 and there it's worked . On my 2009 I have change the BSI from Citroen C5 x7 2014 for rear camera and I don't have the CAN ID frame 0x120. Can you shame me the code sketch ? I have tried to PM to you o_O
OPEL Mokka/Astra
FYI,thanks.
Hi
Thanks for your reply.
No I'm using Arduino and I have enabled various menus and options in NAC/CIROCCO but nothing in BSI or other ECUs. However, I think that the codes are the same and can be used in the console. When you say clone diagnostic, you mean the lexia clone, right ?
Have you tried other telecoding like HBA or Grip modes ?
Thanks in advance!
Hello.
It isn't a lie, if I told you I've searched all internet to solve this problem.
I bought and RCC radio (9833500080) and display from C3 Aircross (propably). Everything is OK, I can change VIN, but problem the problem is when I want to change calibration to 308 T9 ( 308_T9-9692810980.cal ). When I upload it it download and then ZL FLASH ERASING ERROR ( Picture nr 1) .
When I try diffrent calibration ( diffrent to 308 or to diffrent car) it's saying Calibration file Invalid, but sometimes is everything okay and the calibration will update without problem ( 5008_P87E-9693020580 ). Have someone had identical problem? Can you please help me?
Pièces jointes
    19.2 Ko · Affichages: 9
    24.8 Ko · Affichages: 9
It has to exist, cause some 308's origin has Rcc.
Hello.
Maybe I'm wrong, but there are also different versions of WAVE in RCC, for example the calibrations in the VLUD repository for RCC 308 T9 start with 9692 and the one that does let you install 5008_P87E-9693020580 starts with 9693, so it would be for RCC WAVE3. If you have a WAVE 3 and you try to load a calibration that is for a different RCC, that may be your problem. Try to load calibrations that start with 9693 and try again.
If I'm wrong, someone who knows more about the subject can correct me.
salut tu peux m’aider svp j’ai une peugeot 3008 Gt 2021 Diesel Eat 8 j’ai eu un problème après avoir fait la procedure de Drive Assist l’angle mort ne marche plus quand je met On ca reviens sur OFF
Może się mylę, ale w RCC są też różne wersje WAVE, np. kalibracje w repozytorium VLUD dla RCC 308 T9 zaczynają się od 9692, a ta, która pozwala zainstalować 5008_P87E-9693020580 zaczyna się od 9693, więc byłoby bądź dla RCC WAVE3. Jeśli masz WAVE 3 i próbujesz załadować kalibrację dla innego RCC, może to być Twój problem. Spróbuj załadować kalibracje zaczynające się od 9693 i spróbuj ponownie.
Jeśli się mylę, niech ktoś bardziej obeznany w temacie mnie poprawi.
Here is log from flashing 308 t9 unit 9692. I don't understand it but maybe you can help me.
Pièces jointes
может у кого есть фотографии блоков предохранителей и реле с названием их назначения для peugeot 5008 2G 2020 1.5 bluehdi DV5R
quelqu'un peut-il avoir des photos des boîtes à fusibles et des relais avec le nom de leur destination pour peugeot 5008 2G 2020 1.5 bluehdi DV5R
