OK can you send me the command or ready file yat for using it to enable park assist on 3008 gt 2020 with 12 sensores i read on it i saw that have AAS_UDS_G5 right?? and the restyled 3008 from 2021 have AAS_UDS_G6 that's right ??
Use the file that I already attached on this forum. If you not sure about what ECU's your car has, read the stored data from each ECU and put it here.
Hi, I have already activated many options like new color schemes etc.
Last time I saw on Polish FB group photo of non hybrid 3008 II with range under fuel gauge like on the screen.
Is there an option to activate in 3008II diesel?
bonjour, est-ce que quelqu´un peut m´expliquer comment faire le telecodage par diagbox avec arduino en dump mode svp? j´ai achete le Y obd cable, j´ai injecte le seed mais quand je clique sur telecodage manuel dans diagbox, j´ai toujours le message que je n´ai pas la connection internet.. merci pour votre aide
Hola alguien me puede explicar como hacer telecodificacion por diagbox con arduino en modo dump por favor? Compré el cable Y obd, inyecté la semilla pero cuando hago clic en telecodificación manual en diagbox, siempre me sale el mensaje de que no tengo conexión a internet.. gracias por tu ayuda.
I think you are mixing different things.
DIAGBOX coding from 2016-> = internet+OFFICIAL DIAGBOX+TOKEN PAID TO PSA+DIAGNOSIS INTERFACE FOR DIAGBOX.
ARDUINO coding=ARDUINO+SCUDO CAN+VLUD SKETCH+ANY OF THE TOOLS ONLINE BASED ON VLUD'S WORK.
No seed is needed, the y-cable is to connect arduino and diagbox at the same time and see the data traffic of diagbox with the arduino console but to code you either use diagbox or you use arduino.
If I'm not mistaken this is like this.
Je pense que tu mélanges différentes choses.
Codage DIAGBOX de 2016->= internet + DIAGBOX OFFICIEL + JETON PAYÉ À PSA + INTERFACE DE DIAGNOSTIC POUR DIAGBOX.
Codage ARDUINO = ARDUINO + SCUDO CAN + VLUD SKETCH + N'IMPORTE QUEL OUTIL EN LIGNE BASÉ SUR LE TRAVAIL DE VLUD.
Aucune graine n'est nécessaire, le câble en Y sert à connecter Arduino et Diagbox en même temps et à voir le trafic de données Diagbox avec la console Arduino mais pour coder, vous utilisez soit Diagbox soit Arduino.
Si je ne me trompe pas, c'est comme ça.
Hello. This is the edited version of the YAT file that I used to activate Park assist on my Peugeot 3008 from 2018.
Now, on each ECU you have only 2 buttons, one for Read and one for Write.
Press Read button to find what value is stored in your car ECUs.
If your data are different than data that I have in my car ECUs you need to edit the write command(s) before send.
Hello that not working on my peugeot 2020 with 12 sensore i aplayed all setting but in the park assist touche it start but when it start it turned off directly
Je vais me lancer car j'ai acheté le matériel nécessaire pour l'arduino.
Par contre, si l'on pouvait juste m'aider car il y a une chose où j'ai du mal.
Entre la carte Arduino Uno et la carte shield 2.0, j'ai vu qu'il y avait un schéma de câblage du module 8Mhz avec Arduino Nano.
Mais doit-on faire des soudures ou relier des fils ? Car c'est la seule partie que je ne comprends pas et je n'ai pas vu de photos indiquant cela.
Merci pour votre aide.
j'ai pas encore testé le mien mais si tu es en arduino UNO + Shield 2.0 tu n'as pas de modif à faire.
le schéma est pour un arduino Nano + shield MCP2515 pour le can mais il est en 8Mhz.
Quelqu'un sait me dire, si je peux démarrer un NAC sur table sans bsi ? :
PIN 11 - + 12V
PIN 22 - GND
PIN 10 - CAN High
PIN 21 - CAN Low
Salut tu peux envoyer ta config stp?
J'ai pris le matériel indiqué au début du tuto, à savoir :
Et également une prise odb mâle avec fils :
Hi
From logs I can see that there are some troubles with coding DAE and BSI.
It returns the errors codes
  • 7F3E03 ECU Connection lost | No resistor ? CAN-BUS wires bad ?
  • 7F2E22 Failed Configuration Write
It seems that is something wrong with your Sketch, it losing connection when it try to code.
Hi,
Put here log from YAT, it should be in C:\3008\YAT projects\
you can contact Yacine PSA, he have answers for that, is
you can contact Yacine PSA, he have answers for that, is good man, he help me to activate my car...
hello, I would like to retrofit the "Parfumeur d'ambiance" in my Peugeot 3008. I already have the parts purchased, but I would like to ask in which ECUs and zones it needs to be activated, apart from the NAC? Thank you.
hi, I encoded the data as described but the voice came out in the park assistant on the nac but it won't let me log in, can you help me
Thank you
these are the readings from yat
>752:652
ok
500300C80014
222300
62230033
>75D:65D
OK
1003
5003
222101
622101BD
>6B5:695
OK
81
C1D08F
21A0
61A005C0CCFD00000019
Peugeot 5008 (P87) 2019
If we activate the BSG trailer module in BSI, does that also activate the trailer stability program automatically? Or do we need to activate another component in the esp as well?
French translated :
Si nous activons le module de remorque BSG dans le BSI, cela active-t-il également automatiquement le programme de stabilité de la remorque ? Ou devons-nous également activer un autre composant dans l'ESP ?
French translated :
Yes, if you use a 13-pin connection, it is activated only when the ignition is turned on, but in BSI there is only one area to activate the BSG trailer as long as you use the original trailer control unit.
If you activate this area, it will detect the trailer, but I cannot guarantee that everything is configured for what you indicate.
If you want everything to be properly coded, you have to enter Diagbox and activate the BSG towbar. In this step, it will ask you to indicate what type of trailer hitch you have and it will code the entire system, of course, after paying a TOKEN to PSA or going to the workshop.
With the Arduino method, you only activate the trailer control unit in the BSI, but I have not found information to know if you can code the type of hitch or any other option in this BSG control unit.
Oui, si vous utilisez un bloc de connexion à treize broches, il n'est activé que lorsque le contact est mis, mais dans BSI, il n'y a qu'une seule zone pour activer la remorque BSG tant que vous utilisez l'unité de commande de remorque d'origine.
Si vous activez cette zone elle détectera la remorque mais je ne peux pas vous assurer que tout est configuré pour ce que vous indiquez.
Si vous voulez que tout soit correctement codé, vous devez entrer dans Diagbox et activer la boule d'attelage BSG. Dans cette étape, il vous demandera d'indiquer quel type d'attelage vous avez et il codera l'ensemble du système, bien sûr après avoir payé un TOKEN à PSA ou être allé à l'atelier.
Avec la méthode Arduino, vous activez uniquement l'unité de contrôle de la remorque dans le BSI mais je n'ai pas trouvé d'informations pour savoir si le type d'attelage ou toute autre option peut être codé dans cette unité de contrôle BSG.
Hi,
What is BECB_GEN2 unlock key? I want to change amper 70 to 75. This option does not appear in the menus.
or How can i find key?
The battery amperage is set in zone 2333 of the BSI but you still have to enter with DIAGBOX to tell the system to take into account the battery change and the type of the same AGM, STANDARD, EFB.
2333 hex Type of battery
Params:
0 42 ah
1 50 ah
2 60 ah
3 64 ah
4 70 ah
5 75 ah
6 95 ah
7 55 ah
8 80 ah
9 82 ah
A 90 ah
L'ampérage de la batterie est configuré dans la zone 2333 du BSI mais dans tous les cas il faut entrer avec DIAGBOX pour indiquer au système de prendre en compte le changement de batterie et son type : AGM, STANDARD, EFB.
Type de batterie hexagonale 2333
Paramètres :
0 42 h
1 50 Ah
2 60 Ah
3 64 Ah
4 70 Ah
5 75 Ah
6 95 Ah
7 55 Ah
8 80 Ah
9 82 Ah
À 90 heures du matin
Hello to all,
I've made major retrofits for my 508 2013, i make all the front and rear facelift model 2015+ , with full led headlight and all function active, also, made digital dash i cockpit, also all working and activate, but...I have a little problem, the gear ration is not showing on my ciroco instrumental dash, my model is a hybrid car, i don't know whay.... can enyone help me ? I pay his efort, thanks a lot !
@jeverds
Thank you for reply.
I have already done what is seen in the bsi and video.
However, changing the amperage from BSI does not affect the becb unit. If you change the amperage from Bsi and enter the standard measurement parameters section in the becb unit, you will see that that region does not change.
While there was a column required to change the amperage in the becb unit in old vehicles, they have removed that column in new vehicles. So I'm looking for the key to the unit to code it manually.
Hi everyone
Do you know if this works on Fiat 500x radio?
Salut tout le monde
Savez-vous si cela fonctionne sur les autos radio Fiat plus précisément modèle 500x ?
