[TUTO] Télécodage et calibration d'un NAC / RCC / CIROCCO / CMB_NUM SANS Diagbox via Arduino
[QUOTE = "VLud, gönderi: 2597984, üye: 108646"] Ekran görüntünüzde ikinci ayar devre dışı bırakıldı .. [/ QUOTE]
how can i activate
here is my backup file with parameters
The features that are not available in my 2019 model 2020 gtline vehicle are: evaluate the parameters accordingly. Advantage grip control, perfume system, i cockpit amplify
211D=15
211C=F0
212D=10
210E=92
2121=40
2131=80
2126=00
2107=C0
2117=9E003AE0
2127=03784420030F0001000000000000061704000000000000000709101A00000000000014181C00000000000000
212A=0E440BF4033E070801C70708030502BB068B02580804020807D0802802570001F30077726900006464
2100=0F60
212F=18
2110=01
210D=EC77C034
2120=88
2101=0A
2130=C0
0106=50455547454F540000000000000000000000000000000000000000000000
2125=0034340F00
2106=00
2116=2F38080000
2129=C030
211B=00B428B41EB42810
210C=C110
211F=02
2124=00
2105=06F4
210A=00
2115=02
2128=40
2109=84
F190=5646334D4359485A524B53353132373933
2119=A0
211A=4C
212E=00
210B=00
2113=280005121F2C3946535F64
2123=00
2104=C4FED7B2
212C=20
2114=B000
2108=9A0014209056AC010C
2118=1100
2112=C0
210F=10
2103=2020
F18C=3044303131463139423944344632314643434333
@levanid : Got my hands on a W3 non-HD like yours, found the issue on the car type, they moved all other settings from the concerned byte on W3/W4, I'm currently fixing this
Reactions: levanid
Thank you, really appreciate and waiting for applying fix
I believe that options in 2127 for menu bar are also broken for Wave3 (W4?) also
Hey @VLud I have another strange thing with my NAC
As I mentioned it was taken from C4 Cactus
However if I install My Citroen (or My DS) app on my iPhone and depending on the car model setting in configuration NAC tries to connect to appropriate app, and the model name is different here
it says "opel_ZAFIRA DS4" wants to connect to MyDS (or My Citroen if I change car model here).
Do you know where that name might be? "DS4" name changes to correspondence of BT name.
However I don't know where opel_ZAFIRA with lots of spaces comes from
Is it possible to change that name with your tool?
Options inside 2127 are displayed only if related BSI settings are activated, it is not broken at all.
Concerning the Opel_Zafira I don't know, probably a firmware issue because there is no such setting, are you sure about the Citroen origin ?
@VLud Thank you for supporting.
I need these answers;
1) Can i replace my RCC with NAC which is taken from different brand and model car. Like Opel or Citroen? My car is Peugeot 3008.
2) If yes, can i make adaptation for my car with Aurdino?
3) Can i activate GT line theme with Aurdino.
4) After replace my RCC with NAC, can i use Mypeugeot app with new NAC?
5) What is latest calibration file version for Peugeot 3008? Is all Peugeot 3008 calibration file same?
6) Can i use calibration file and configuration file taken from different Peugeot 3008?
Reactions: TiborB
Hi, I want to share with you another little upgrade to my mk1 208.
I found in Italy a NAC wave4 (the latest NAC which can be found on new 208/2008/508 etc) from a c5 aircross, with the help of Vlud tool I was able to change the calibration file, using a custom one made by me to restore the MENU and SRC buttons and telecode it for my 208.
Inside the new 42.x firmware there are also older car such as the 208/308 and 508, this means the image of my own car can be successfully restored. Everything works fine, from the steering commands to the parking sensors/reverse camera. The new software is good looking than the old one I had on my wave 2 and some bugs have been fixed. Now it's possible to use SIRI directly with the bluetooth and CarPlay shows the song photo in the music page. The hardware is new and you can really feel the difference in performance compared to the wave2 above all in the morning when you start the car.
I've attached some photos to explain everything better.
Good job.
It's wave4 without HD I think ?
Your last picture looks like the image of the wave2 china version.
Yes, w4 non-HD from c5 aircross. Resolution setting can be changed with the tool. Originally the c5 has a 8” screen while my 208 has the 7”.
The last image is the camera view right? It’s exactly the same as the w2. I’ve added the 180 camera, that’s why you see the top view of the car, it works like the 308 :)
Reactions: hangway2
Thank you for update, I'll take a look in the morning
Any images related to DS?
Maybe you could show full lust here w/o overloading menu?
For option in 2127 I see, I'll try to add appropriate options which are available in my DS
Speaking of Opel_Zafira and Citroen origin, obviously now I am not sure at all if it really comes from Citroen, the VIN on headunit is from C4 Picasso, but it seems that initial version was not from it
Could that name be hardcoded with calibration? As my current calibration is 9693726480 I am not sure if I can use DS4 calibration from this thread and if anything would be broken if I upload it
Hey guys, I'm going to convert my RCCA1 to A2 on C4 GP.
the RCC A2 is coming from P 208.
my current calibration is 9692633180, i noticed that on frontpage the C4 GP calibration is 9692633080, is it safe for me to upload that calibration into the RCC A2 ?
hi guys. still looking in to the issue of my CIROCCO display that does not want to dimm at night.
is there anyone that wants to share his config and calibration file of a C4 II from one that does work?
You have to test it, but at worst it won't break much. Vlud needs to know exactly what the calibration file contains (apart from the audio theme).
@VLud , quel est le risque de changer le modèle de la voiture sur le NAC ? Cela agit sur quels ensemble de données ? (L'affichage je suppose, mais y en a t-il d'autres).
Dans ma recherche des lags de l'affichage de la caméra arrière, en modifiant cette options je remarque des temps de chargement qui varies du simple ou double.
Merci, et d'ici là bonne fêtes de fin d'année à tous !
@Ringelberg : The problem is how your CIROCCO is configured. Change the setting using CIROCCO soft ...
@Idan Harel : Nothing wrong will happen ... most of times only small changes in Arkamys parameters / Visiopark parameters that won't change your life and in your case they are EXACTLY similar, just the calibration number displayed is changing.
You can't dump a calibration I already told this on the topic and if it was possible it would already be available since it would be useful (only partial calibs can be dumped)
You are asking yourself too many questions ... make the switch and see yourself !
@Lusitanos67 : Juste des .png de tailles différentes en fonction des voitures et de la quantité d'images pour chaque option (il doit surement tout charger d'un coup). Ta quête de rapidité ne te mènera à rien, tu perds ton temps, le NAC Wave2 est un peu lent mais c'est largement supportable. Si tu veux plus rapide change de NAC (encore que je n'ai pas senti de grande différence, ça reste lent au démarrage)
You will be able to unlock the display of the setting, the rest has to be activated on the BSI (using Diagbox) and your multifunction camera CVM must support this functionality.
Thanks for the reply.
So any additional function need to be done via diagbox ?i have seen someone had done it in my country using diagbox (Same model and no additional hardware needed).. wondering this can also unlock the functions
@VLud Can you tell me the setting to look for?
my file looks like
0200=A0307FC00F01DC644480DC00F06D14320000020305070A0E1319222E3D526D91C0FF04800A141E28141E2832600005121F2C3946535F64A05600011388186A508CFE13
2100=76C09808000000000000000C6200001A08018B0780
2200=08000000010000
2300=00EC3054BBC0
0900=01020406090D1219212D3D516C90C0FFF0
F18C=00000127
2101=00000000000000000000000000000002
@VLud
C'est subjectif, je n'ai pas de temps de référence malheureusement, mais autant de latence ce n'est pas possible (je ne cherche pas non plus une machine de guerre en terme de rapidité), je dois avoir 10 fps sur la vue cam arrière, sans parler des 10secondes pour afficher complètement l'image arrière (en ayant auparavant attendu que tous les modules du nac soient chargés). C'est dangereux et pas utilisable en l'état, d'où mes questions sur la référence du temps.
Il arrive aussi, que par miracle, tout s'affiche nettement plus rapidement (toujours après un premier démarrage), mais c'est très rare.
Mais je sais qu'en changeant le modèle de voiture je gagne moitié du temps, je vais donc voir de ce côté et tester.
Je ferai un retour.
Great job Hallahub! Could you share the NAC unit part number?
My C4P mounts a NAC W2 and I use SIRI directly with bluetooth.
"CarPlay shows the song photo in the music page" ... do you mean using the Music app on the iPhone or the music menu of the NAC?
Thanks.
Hi do we know if activation process of connected services have changed recently. Currently have Nav wave 2 and NAC wave 4 showing as connected services activated but are never available. Tried BTA 2 and BTA 3S also Bluetooth and wifi data connection.
I enabled the cockpit amplify option,
but in the menu i could not find a touch button to
enter the cockpit amplify section.
Pièces jointes
    66 Ko · Affichages: 66
    62.1 Ko · Affichages: 61
