Petite question:
est il possible de mappé un bouton physique ?
en gros j aimerais changé l attribution d un bouton .
Did you connect Android phone (with Andorid Auto installed) to USB port?
And in Chinese, a message appears about loading the module and weighs infinitely.
Tu a fait comment ?je n y arrive pas,
Might be some radio problems, it shouldn't hang like this.
So in it, when you activate Android Auto, even the icon did not appear. There was an A1 version
A1 version doesn't support AndroidAuto at all unfortunately.
You can code it also with arduino, but on new flash version is not possible to change VIN all other options you can change with arduino on BSIhello i have a question can you help me Is it possible to code bsi using original diagbox with colon lexia?
@marcins
C'est vrai, mais difficile de trouver les bonnes zones... Et ensuite les bons bits !
It's true, but it's hard to find the right zones... And then the right bits !
What firmware version is installed on RCC ?
English: RCC European, collects BOCSH
Chinese RCC, collects Continental
I tried it. Does not work. Loading is in place. Please help me@Colobok_m : Flash a .cal file instead and it should bring it back
use older version of cirocco tool to load .calI tried it. Does not work. Loading is in place. Please help me
don't think this will work , and make no sense as every ecu same family can have differ data in zones depending of calibration and coding, best option is to get used parts and connect on bench to test and play before you go to car
Will you give me a link? For older versions.use older version of cirocco tool to load .cal
