do I need to output this in the arduino console? How do I get to these values?no
As Marcins said, before unlock you need to access to the ECU
Hi guys, someone knows the commands to activate the navigation touch screen botton? Voir la pièce jointe 22019
>736:716
L47
:FD69:03:03
2E21007E
2E211080
Thanks a lot for your support!So I bruteforced the key of the screen and added it to the repo.
Here is how to enable navigation button on DGT7CFF via Arduino (Latest Sketch mandatory due to LIN communication with this ECU, the one from March, v1.6 - in case you don't have the good one -):
Code:>736:716 L47 :FD69:03:03 2E21007E 2E211080
>736:716 = Access to DGT screen
L47 = ECU Access Code for LIN encapsulation over UDS
:FD69:03:03 = Unlocking
2E21007E & 2E211080 = Write zones 2100 and 2110 to enable all buttons and multitouch
FMUX must be plugged in because it is the one forwarding messages from CAN-BUS to LIN
You can also do it via Diagbox
To do what?@Hallahub hello can you help me, in the bsi which field should I enter and which voice should I enable? since you did it on your 208?
Can someone make a video instruction on how to use KWP command?
>77C:67C
:DC3B:83:C0
21B0
3BB05646333030303030303030303030303030
Hi again!
My progress so far.
I noticed that as soon as:
1. I upload the sketch via Arduino IDE
2. Go to PSA -Arduino-NAC/RCC interface
3. Arduino Connect
4. Read Parameters
5. Parameters
I am able to access and telecode if I am very fast.
I managed to change the VIN and configure park assistance (now radio works without beep-beep )
But if I spend too much time configuring and then Save
The communication seems "hang up" the progress bar on the application just fills till middle, or don't fill at all and just sits there.
Could it be that I need to change some of these in order to work properly?
For example max data length
or can speed
or can rcv buffer
or can default delay ?
#define SKETCH_VERSION "1.6"
#define CAN_RCV_BUFFER 40
#define CAN_DEFAULT_DELAY 5 // Delay between multiframes
#define MAX_DATA_LENGTH 512
#define CS_PIN_CAN0 10
#define SERIAL_SPEED 115200
#define CAN_SPEED CAN_500KBPS // Diagnostic CAN bus - High Speed
#define CAN_FREQ MCP_16MHZ // Switch to 8MHZ if you have a 8Mhz module
My Arduino is genuineDo you have 2.0 Shield ? If so, nothing has to be modified on it.
Is your Arduino original or Chinese copy ?
If it works during a certain amount of time :
120 Ohm resistor issue / Arduino memory issue = crashing
I was told by the company selling the CAN Shield that I need to, in order to enable. I have tried without it, but I was never been able to connect to the NAC without.The resistor is already enabled by default, why are you adding an additional resistor ? Did you try without ?
I thought this card is considered CAN BUS 2.0 shield
The console is silent when you enter this command. No answer. Does she have to react somehow?Please make some effort, everything is written on the repo ...
Example for VF300000000000000:
Code:>77C:67C :DC3B:83:C0 21B0 3BB05646333030303030303030303030303030
So I need another one ?
Hard coding Dump is useless because you can switch between both modes inputting X and N
And dump mode is not really necessary here
If no reply the ECU is not connected to CAN-BUS (try with Diagbox) or your Arduino have some issue (or an old sketch, you have to use the latest one) - try another ECU to confirm it is working
Problem solved!Hard coding Dump is useless because you can switch between both modes inputting X and N
If no reply the ECU is not connected to CAN-BUS (try with Diagbox) or your Arduino have some issue (or an old sketch, you have to use the latest one) - try another ECU to confirm it is working -
It is not the 2.0 but this card should work just fine
Applying the 508 nac put the logo, but the screen freeze on Peugeot Logo.@W1zard : First time I'm seeing this, happy for you ! Upload a 508 config as a base and change the calibration of the NAC too
Sketch not updatedwhen I enter the frame >77С:67С he is silent. Why?
can you share the correct program for arduino? (where false and true are correctly placed)
SKETCH_VERSION “1.6 - isn't it the last one?Everything, we show you each line you must input you are sending 2 at once ...
Plus the sketch should be displaying 7F0000 due to this and it is not, so you are probably not using the latest sketch available.
Somehow afther the second load it was OK.@W1zard : It can freeze if maps are corrupt or absent, just use menu buttons to exit navigation and (re)install them
Hi @Hallahub I have to activate the park assist in the Opel Corsa F I already have the 12 sensors I read here on the forum that you have already activated the function on your car can you help me? At opel we managed to enter the bsi of the Opel Corsa F, the only problem x the activation of the assisted parking we go into repair then manual telecoding then vehicle configuration and other submenus come out you can tell me which menu I have to enter and which item I have to kindly activateTo do what?
I have SMEG+ at the moment, but the shortcut keys are not working for switch to NAVI, MEDIA etc.You must change your RT6 panel to SMEG or NAC panel (same), no other way at the moment
