Apparemment le telecodage est sécurisé, y'a t-il une solution ?
I'm also working on this as a bigger future project, we should work togetherPas certain de la compatibilité hardware du RCC / NAC Chinois avec Android Auto malheureusement
Buy an iPhone ?![]()
That means your input contains invalid characters. What exactly are you typing in the terminal?Hi, Sorry i dont speak french so i write in english.
I followed the instructions however i only get 7f0000 when using the terminal.
What have i done wrong?
Many Thanks
more info and any photo?Tha will finally finish my swap in 208![]()
@lorddevereux HeyI'm also working on this as a bigger future project, we should work together
Bonjour @Misticrep
A mon avis c'est plus un réglage physique de la caméra à effectuer... tout du moins pour la partie droite-gauche.
Pour ma part, je vois également un bout du pare-choc avec ma 508 équipé d'origine.
@Misticrep It also depends on the type of system you have, if you have a 360 view then it is an instrument cluster configuration problem
Hi guys. Im trying this with Arduino Uno v3 and newest canshield v3.
Cant connect. If i use CS_PIN_CAN0 to 9, when i try to connect or send the test comands, nothing happens. If i use CS_PIN_CAN0 to 10, when i try the above, all 4 green lights Turn on but also nothing on the NAC unit and no messages Arduino software.
Any tip?
Tu avais une caméra d'origine ?
Dans tous les cas, étant donné que la caméra est connectée au combiné, le menu Visiopark du NAC n'aura aucun effet (déjà qu'il n'a quasiment aucun effet en temps normal)
@levanid : Wave3 NACs never have been installed on DS4, the tool is not erasing anything and a backup is restoring raw data directly.
Where you using the same theme before ? (because it seems related to that)
What is the origin of the NAC ?
What did you do with the soft exactly ?
Where did you buy a "V3" ? If you are talking about the SunFlower CAN Shield V3 it is a cheap copy of the 1.2 with a 8Mhz Crystal, so you must keep CS_PIN 10 and change 16MHZ to 8MHZ
Done and succesfully comnected. Thanks. Câmera is now ok. Im just missing the fuel info on the NAC. Can you tell me where to enable it? ThanksCheck the sketch source code, you will find where![]()
